Old 24th October 2007, 09:36   #1
Default SWIFT-VXI brake issue
Dear friends,
Since yesterday evening I am facing a starnge problem in the brake.Once I press the brake and while releasing it i can hear a strange sound like"cut-cut".Though it is very small sound but still I can feel that coming from the brake pedal.
Today morning after reaching the office,I tried it in the parking and yes...the sound is there.There is no issue with the performance of braking though.
Please suggest me friends,do i need to go to workshop immediately?
Thanks and regards.
raja748 is offline   Reply With Quote
Old 24th October 2007, 14:18   #2
Thanked: 7 Times
Are you specifically observing the sound on inclined ground surface ?
I have observed this while using the car after few days of non-use, and have assumed it to be some mechanical part which has become a bit rusty.
emkay456 is offline   Reply With Quote
Old 24th October 2007, 15:08   #3
No.In normal running condition also the sound is there and I am using car daily.
Old 24th October 2007, 15:23   #4
Jaggu's Avatar
Thanked: 7,476 Times
This was reported by Geeksrik in his long term report, its a wet brake pad. Will go away after the pad dries.
Old 25th October 2007, 09:46   #5
I don't know how can brake pad become wet.There are no rains now a days and I don't remember running my car on watery surface.
Old 25th October 2007, 10:32   #6
bblost's Avatar
Thanked: 6,663 Times
1. Any dogs around your parking area?
2. Is the car parked near a watering area, like a garden.
Old 25th October 2007, 10:48   #7
WhiteKnight's Avatar
Thanked: 73 Times
Have you been to a service center recently, in last few days?
A wet brakepad should become dry within ~10 min of driving, as it gets heated up on every braking. If you have a persisting problem, the reason is something else.
WhiteKnight is offline   Reply With Quote
Old 25th October 2007, 11:14   #8
vivek_pinkoo's Avatar
Please check for any possibility about stone stuck in between wheel and brake. That could be the reason.
vivek_pinkoo is offline   Reply With Quote
Attention: New Maruti Suzuki Swift Brake Issue moralfibre Technical Stuff 326 3rd October 2017 17:00
Swift Half Clutch/Brake Issue lambuhere1 Technical Stuff 6 26th August 2009 09:39
swift-vxi,logan-dlx,esteem-vxi which one is better ???? uvais Hatchbacks 4 17th October 2007 10:17
Swift vxi or Esteem vxi ? bsm3477 Hatchbacks 11 15th October 2006 13:38
