Old 24th October 2007, 23:01   #1
Awaiting Email Confirmation
Default Muffler Rusting
Hi guys...
i own an indica v2 petrol. it might be because of the short distance run its used for but its Muffler and also the Pre silencer gets rusted off and starts to make a rattling noise. So i was thinking of changing my exhaust system to automech system. i heard it also comes in stainless steel build also. is there any other choice for Exhaust system? will changing my muffler to automech (the stainless steel one )solve the problem...
please help
Thomas T is offline   Reply With Quote
Old 25th October 2007, 00:47   #2
razor4077's Avatar
Thanked: 252 Times
If you're looking to change just your muffler, then you have quite a few options, Automech being one of them. There are also other brands like Magnaflow. Browse through this forum for more names, or get hold of a magazine like Autocar or Overdrive... lots of ads there.
There are also folks who will build you custom exhaust parts, a lot of whom are members here. Again, a quick search through the Mods & Accs section will get you their details.
If you're changing parts of the exhaust, you could also think of opting for a full free flow exhaust, which can be obtained from the same people mentioned above.
razor4077 is online now   Reply With Quote
Old 25th October 2007, 07:08   #3
jkdas's Avatar
Thanked: 1,389 Times
Live near to beach area? How old is your car?
Old 25th October 2007, 08:35   #4
jerish666's Avatar
Going for a stainless steel muffler is good.
jerish666 is offline   Reply With Quote
Old 25th October 2007, 08:46   #5
esteem_lover's Avatar
Thanked: 445 Times
Right time to invest in headers & Free flow, I'd think.
Old 25th October 2007, 18:48   #6
adheesh's Avatar
Thanked: 34 Times
Go in for either SS Muffler or if you are going for automech, get the whole exhaust system replaced including headers and FFE.
adheesh is offline   Reply With Quote
Old 25th October 2007, 19:21   #7
n_aditya's Avatar
Thanked: 2,742 Times
If its only the muffler you wanna replace it'll cost you around 5k for a SS one. But i suggest you get a header and free flow exhaust along with the end can. The performance will be an added bonus
Old 25th October 2007, 21:49   #8
It definitely is because of the short distances run. Indica V2 petrols have this silencer issue for cars that run less distances per drive.
An SS exhaust should do the trick. Let me know if it works.
I've changed the silencer only once and have had it welded back once in 82000 km. My minimum run is 20 km if I use the car. Plus, I do a lot of highway driving, which I guess has helped the silencer cause.
hrag is offline   Reply With Quote
Old 25th October 2007, 22:04   #9
the problem is that my car has run only 25k but had to change to change the pre silencer and the muffler,each once. how much will a full kit ie the headers to the end can cost...... also is it possible to get a comparison between the various options(both cost and performance)
Old 25th October 2007, 22:45   #10
dkamath's Avatar
Thanked: 85 Times
the diesel ones rust too. i was told to replace the silencer after two weld works, which made the third attempt impossible
its been about 3+ years now, and no signs of giving up yet. moreover, being in a coastal area, that it is rust prone.
please do check with the service center, as i remember being told then that the later ones are less rust prone
dkamath is offline   Reply With Quote
Old 26th October 2007, 11:15   #11
n_aditya's Avatar
Originally Posted by Thomas T View Post
how much will a full kit ie the headers to the end can cost? also is it possible to get a comparison between the various options(both cost and performance)
Thomas, The below links will give u all the info u need.
http://www.team-bhp.com/forum/techni...s-ffe-car.html (How Much did you pay for your Headers & FFE & which car ?)
http://www.team-bhp.com/forum/modifi...ry-esteem.html (mods query + esteem)
Although the 2nd link pertains to the esteem, the logic behind the header design (4x1 or 4x2x1) remains the same. Performance figures and output may vary though.
Why is the OHC Vtec exhaust muffler different? jigarmuni Technical Stuff 28 28th May 2009 18:17
SALE - honda city headers and muffler killjoy Shifting gears 1 23rd November 2005 20:51
Skoda Muffler karthik247 Modifications & Accessories 3 17th August 2005 23:47
free flow exhaust muffler for ohc club_honda Modifications & Accessories 23 14th June 2005 04:10
zen muffler for sale manson Shifting gears 31 31st January 2005 22:53
