Thread Tools
Old 27th October 2007, 00:44   #16 (permalink)
Team-BHP Moderator
Rehaan's Avatar
Originally Posted by Mpower View Post
...After that check the sparkpulg gasket. ...
Do you mean to say oil could be leaking in from outisde the engine in this case ?? (ie oil deposited in the spark plug insets on the outside of the engine?)
cya
R
Old 27th October 2007, 01:56   #17 (permalink)
hellspawn's Avatar
even i'm facing the same problem since the last couple of days.whenever i start my zen in the morning after parking overnight,white smoke is emitted from the exhaust.And it has particularly started after i fit a free flow with headers(4x2x1).also i can smell oil/fuel in the exhaust gas.
__________________
Kenwood KDC-MP6539,Image Dynamics Q450.4,Image Dynamics CTX65cs,IDQ15
hellspawn is offline   Reply With Quote
Old 27th October 2007, 18:00   #18 (permalink)
ok. more or less i confirmed that engine should be disengaged. Can anyone tell how much it costs? is it worth the cost ? or should i sell the car. i'm confused.
dvinod is offline   Reply With Quote
Old 29th October 2007, 22:59   #19 (permalink)
MC Mayank's Avatar
Last couple of days only? Could the weather getting cooler in Noida be a part of the problem?
Also, for how long is the smoke staying? Is the exhaust spitting any liquid ..small amounts?
MC Mayank is offline   Reply With Quote
Old 2nd November 2007, 07:59   #20 (permalink)
hi guys
Thanks to all of you for the advice. Finally yesterday i got my vehicle with valve stem seal and rings changed. Today when i start in the morning there is no smoke. It cost me around Rs.5000 with oil service. Also engine noise reduces and greater pickup.
bye
Old 2nd November 2007, 11:00   #21 (permalink)
Originally Posted by dvinod View Post
hi guys
bye
Can you please give some detail e.g. how much KM car has run and what was the reason behind this fault?
vivek_pinkoo is offline   Reply With Quote
Old 2nd November 2007, 12:18   #22 (permalink)
turbolader's Avatar
Smoke which is basically the visible products of cumbustion is due to poor combustion.
Now if your car emmits bluish OR white smoke during cold star, it could be caused by burning of lubricating oil, but this is only during cold start and its normal. Also if lubricating oil flows past ur piston rings, it results in blue-white smoke, so if u car emmits blue-white smoke other than cold-starting, indicates the piston rings are worn out.
Again quality of fuel affects the white smoke produced in an engine during cold start.
Incase of black smoke, its simply because of improper air-fuel ratio, black smoke increases when the load is increased and the avilable air is depleted.
__________________
You go to a race meeting with one idea:pole,fastest lap,victory?
turbolader is offline   Reply With Quote
Old 3rd November 2007, 19:13   #23 (permalink)
My car runs 85000 km. I am the second owner. Mechanic told that smoke is due to no proper oil service regularly.
Old 4th November 2007, 01:42   #24 (permalink)
rohan_fonseca's Avatar
Noticed that fro a 800 recently when it challenged me on a road race! Ofcourse i was not interested.
rohan_fonseca is offline   Reply With Quote
Thread Tools
White instrument cluster on a baleno w/pics! binz Modifications & Accessories 45 25th May 2008 07:03
Hyundai Accent - White whatcanthisbe Test-Drives & Initial Ownership Reports 31 9th April 2008 17:32
Spotted a White Maserati SohailPistawala Super-Cars & Imports in India 6 18th February 2007 05:15
white smoke from exhaust...its Turbo baleno neo_trace Technical Stuff 21 21st September 2006 15:03
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
