Old 26th October 2007, 13:21   #1
Default Zen makes krr krr.. noise
Guys from last 8/10 days, I am listing krr... krr... sound from back side ( drivers backside ) may be from tires ,, it comes when car is at 10 to 30 km / hr
What could be the reason ??
Thx in Advance !
Jitendra
nicejits is offline   Reply With Quote
Old 26th October 2007, 15:23   #2
rohan_fonseca's Avatar
Specifically which area? Metal kind of sound or plasticky?
rohan_fonseca is offline   Reply With Quote
Old 26th October 2007, 15:32   #3
metal ,,, i guess must be from rim side
Old 26th October 2007, 21:58   #4
revhappy's Avatar
Hi Jitendra,
I too have a zen and you wont believe I had the exact same problem. A krr krr sound that comes from the back wheel not the drivers side, the other side. This sound used to come and go and I lived with it for a long time. Then as days passed by the sound started coming more frequently,
and I took it to the workshop and you know what I found!
The Drum was very loose and was moving back and forth. The mechanic told me there should have been a washer(or sleeve) or something that was missing, hence when the wheel moved the drum used to hit against the wheel and hence the sound. He said the particular washer is not in stock and put some other washer and now the sound has stopped.
I am not sure that yours could be the same problem, but chances are that it is.
Cheers,
Nitin
revhappy is offline   Reply With Quote
Old 27th October 2007, 19:11   #5
ankitahuja's Avatar
Thanked: 46 Times
First I think you should get the tyres checked (wear/tear) and rotate to see if they are jammed. It could also be a bearing problem which releases the sound at low speed.
Old 7th November 2007, 15:25   #6
Originally Posted by revhappy View Post
Hi Jitendra,
Cheers,
Nitin
Hope this will not loose the brakes ?? Brakes will be as effective as they are normal ?
Old 7th November 2007, 15:32   #7
n_aditya's Avatar
Thanked: 2,779 Times
Must be gas. Sorry jit, couldnt resist.
But speaking seriously get the brakes and the related parts checked ASAP as this is the most impt part of a car.
Stebel Nautilus Horns - gargling noise? no noise? gd1418 Technical Stuff 31 23rd May 2011 21:59
Elantra rare noise (hissing noise) Please help!! manne Technical Stuff 9 28th June 2010 09:24
Strange humming noise from my Safari(EDIT: Solved, window was open hence the noise) himanshugoswami Technical Stuff 14 14th May 2008 15:00
Zen - Running in (engine noise) gchandra Technical Stuff 25 7th January 2007 17:56
Wind noise or Aerodynamic noise vivaid Technical Stuff 15 2nd July 2006 19:58
