Old 1st November 2007, 17:56   #1
Thanked: 9 Times
Default effect of grinding EGR valve in diesels
Since black smoke was coming from the exhaust of my diesel verna, i went to the dealer to get it fixed.
First they drained out all the fuel and put in fresh diesel suspecting that the diesel was adulterated. However the smoke did not go away. Next they ground a few mm from the EGR valve. Apparently this increases the ratio of fresh air v/s exhaust air coming into the diesel engine. This solved the problem of excessive smoke.
Googling for effect of doing so, I found that this will
- result in higher engine temperature
- more N02 emission
- may affect life of catalytic converter
Anyone did this to their diesels? did it cause any adverse effects?
- Benny
reachbennym is offline   Reply With Quote
Old 23rd December 2008, 09:05   #2
veyron-w16's Avatar
Hi Benny,
I am also facing the same problem, lot of smoke coming from my diesel Verna. this time they said it has been fixed i suspect if they have done the same with my car as well. will check and revert.
-Adi
veyron-w16 is offline   Reply With Quote
DIY: EGR Valve Cleaning (1.3L DDiS / MJD) a4anurag DIY - Do it yourself 22 12th December 2017 09:21
EGR system - What's it purpose & when does the EGR valve open/close? rranjith_kum Technical Stuff 60 14th August 2017 20:15
DIY: How to Block the EGR Valve on a Turbo DI svsantosh DIY - Do it yourself 42 19th December 2015 15:10
Truck Diesels vs. Car Diesels smashnerd Technical Stuff 7 15th January 2011 16:41
Looking for porting polishing & valve grinding in Delhi RedMM340 Modifications & Accessories 16 21st November 2008 11:31
