Old 2nd November 2007, 15:26   #1
swapnil.rahate's Avatar
Thanked: 7 Times
Default Fuel pump issue in my Accent
Hi All,
I was having a second hand Hyundai accent 2001 model for 1.5 years and in that period the fuel pump stopped working twice. Once i was going to my native place and we got stuck in the middle of the road. Luckily my cousin brother who is a mechanic opened the fuel pump, the problem was a lot of carbon was deposited thats why no electric current was passing to fuel pump.he just cleaned the pump and the car started.
I work in lower parel mumbai and i saw twice once a Hyundai santro and other time a Hyundai accent stopped working at the same place(near icici atm-opp kamala mills).When i went to notice i saw the mechanic with the fuel pump in his hand.
So the conclusion is that there is some fault with the fuel pumps of hyundai cars..........
swapnil.rahate is offline   Reply With Quote
Old 2nd November 2007, 17:27   #2
Firebird's Avatar
Thanked: 61 Times
Well 3 cars does not represent the entire Hyundai lot. So I do not agree on this.
In your case, it was carbon deposite and contacts were cleaned.
Firebird is offline   Reply With Quote
Old 2nd November 2007, 18:30   #3
ramie2400's Avatar
Thanked: 58 Times
Carbon on the contact terminals are a common probem of all the working electricals in the car,the same thing happened with my OHC,my Ikon and my little zen many of times,so just keep a check on it regularly as a part of maintainence...
Hyundai are one of the good car makers
Old 3rd November 2007, 18:04   #4
GSMINC's Avatar
Thanked: 114 Times
Thumbs up
Originally Posted by swapnil.rahate View Post
Hi All,
Sorry cant agree with you on this.
I have a santro (March 2003) Driven 90 thousand kilometres.
till date no fuel pump problems.
I have changed brake pads once at 50k kms, No clutch problems till date, second set of tyres, second battery.
The car was under extended warranty ( 2+2 years)
So Hyundai cars come with excellent quality.
GSMINC is offline   Reply With Quote
Old 7th November 2007, 12:45   #5
joseph5600's Avatar
I dont think that Hyundai vehicles have faulty fuel pumps. Carbon deposits can occur and doing de-carbonisation can remove these deposits.
joseph5600 is offline   Reply With Quote
Old 7th November 2007, 13:04   #6
headers's Avatar
Thanked: 464 Times
Hi All,
What mileage had the cars done..It is a claimed problem after 80K kms in the Accent CRDis..
Old 7th November 2007, 13:24   #7
.anshuman's Avatar
Thanked: 9,159 Times
Nope i have never seen such issues with any of the hyundai cars i have owned or i have seen.
Old 7th November 2007, 13:28   #8
Sam Kapasi's Avatar
Thanked: 1,473 Times
I don't think you can reach a conclusion like that based on your experience.
By your story, 3 cars (one your own and 2 you saw) had a fuel pump problem. How can you make a statement saying that there is a fault with the fuel pumps of Hyundai cars?
On four different instances I saw punctured cars with Goodyear Tyres. Should I come to a conclusion that there is a problem with all Goodyear tyres?
Old 7th November 2007, 13:33   #9
adman77's Avatar
That was a good one Ramie.
adman77 is offline   Reply With Quote
Old 7th November 2007, 14:02   #10
headers's Avatar
Thanked: 464 Times
This is a classic!!
Old 7th November 2007, 14:30   #11
kpzen's Avatar
Thanked: 1,655 Times
Swapnil..
How many kms has your Accent done?
Sam u are just too much .!!!
Old 7th November 2007, 14:46   #12
gd1418's Avatar
Thanked: 656 Times
Howlarious is the word for you..
Old 7th November 2007, 18:13   #13
Thanked: 7 Times
My accent was almost 50000km done................The cars which i saw with the fuel pump problems were mostly old cars........And about the logic of comparing the tyres getting puncture to fuel pumps.............I have seen many cars of different make getting puncture.........but i have seen only hyundai cars with fuel pump problems.........so thats my observation....... ;-)
Old 8th November 2007, 02:41   #14
off topic - does the hyundai accent have a problem with springs in the door handles?
i've seen this in quite a few, and happened to my 1 yr 4 months old accent recently, there is a spring in the door handle. when it breaks it becomes loose(not very loose, but ya loose)
saintsinner is offline   Reply With Quote
Old 29th June 2009, 09:40   #15
HIGHNOON's Avatar
Thanked: 56 Times
Hi all,
Latest casualty on my acccent 1.5 is the fuel pump. I have done 53700km but the manufacturing yr. is 2002. That ll make it 7 yr old this dec. And had converted to LPG couple of yrs back.
So i guess that ought to give Hyundai benefit of doubt as far the failure of the pump is concerned.
Anyway , how much does it cost ? does anybody have a clue here in Mumbai ? I ll have it fixed out of H.A.S.S.
thanks
HIGHNOON is offline   Reply With Quote
Tyre pressure gauge and portable inflator pump / foot pump adityapd Modifications & Accessories 731 19th July 2018 12:33
Fuel pump / fuel system issue? CDM Technical Stuff 23 16th July 2015 20:38
Wanted: 2nd hand Fuel Pump / Fuel Pump Body ramie2400 Shifting gears 2 6th October 2007 11:16
palio 1.2 nv 'pressure sensor error and water pump issue' kapilsharma80 Technical Stuff 5 17th September 2007 17:58
29000 Suzuki swift being recalled for fuel pump issue - but not in India protege The Indian Car Scene 11 22nd July 2005 08:43
