Old 3rd November 2007, 15:51   #1
Torqueguru's Avatar
Thanked: 161 Times
Question K&N Typhoon engine sound query
Hi guys, I had fitted my car, Cedia Sport 2007 with a K&N Typhoon air filter, at 9000KMs. I got the car serviced at 10000 as per mitsubishi standards. Once i got it serviced, the surging bass noise made by the filter kinda reduced though o probs wid the cars smoothness or pick up...I am not much of an attention grabber through sound made by the vehicle either, but i some how used to like the engine sound made by this filter. Is it possible to restore the previous engine sound???
Torqueguru is offline   Reply With Quote
Old 3rd November 2007, 16:21   #2
jerish666's Avatar
Did they clean the airfilter?
jerish666 is offline   Reply With Quote
Old 3rd November 2007, 16:24   #3
Torqueguru's Avatar
Thanked: 161 Times
Nope, they havent done that for sure...but they had told me that they tuned the engine.
Old 3rd November 2007, 17:06   #4
shailu's Avatar
Thanked: 17 Times
Please check the typhoon kit with Mr.Anish at M/s Hassmiss or empror car accessories...and get it cleaned .
also request him to have a look in the kit for any damages...if any
shailu is offline   Reply With Quote
Old 3rd November 2007, 17:12   #5
Torqueguru's Avatar
Thanked: 161 Times
Thnks shailu, thats wat i was planning to do anyways...Anish had only set it up for me []
Old 4th November 2007, 02:44   #6
rohan_fonseca's Avatar
Did they reset the ecu?
rohan_fonseca is offline   Reply With Quote
Old 4th November 2007, 07:15   #7
hellspawn's Avatar
Infractions: 0/1 (10)
the same thing happens with my zen every time i get it serviced.has to do something with change in the engine oil,timing as they tune the engine.the sound will come back...don't worry about it.
hellspawn is offline   Reply With Quote
Old 4th November 2007, 09:36   #8
Torqueguru's Avatar
Thanked: 161 Times
hey cool, so thats kinda nice to hear!! How long does it take for the sound to come back after your services???
Old 4th November 2007, 09:45   #9
jerish666's Avatar
Once it is cleaned you will get the same old bass noise.Mr.Anish can do it for you.Next time when you go for service tell them avoid spraying water on the filter.
Old 4th November 2007, 09:46   #10
Torqueguru's Avatar
Thanked: 161 Times
sure to do that buddy!!!
Old 7th November 2007, 12:24   #11
Torqueguru's Avatar
Thanked: 161 Times
Guys i am at bangalore now. I will be here for a very long time. Do you guys know the best place in Bangalore to get my Typhoon cleaned? I mean both in terms of cost and service, have you got any suggestions?
Old 8th November 2007, 00:32   #12
NSF
K&N filters are said t be cleaned only after bout 20000 kms or so.I got my universal air filter cleaned after 7000kms as it was looking dirty from outside but the service guy oppened it and showed to me .It was as good as a new one from inside.he says its required to be cleaned only whe the inside to becomes as bad as outside.And always make sure to tell the service guy to cover the filter with a plastic while washing the engine.I had got my filter messed up once.
NSF is offline   Reply With Quote
Old 8th November 2007, 10:47   #13
Torqueguru's Avatar
Thanked: 161 Times
Yeah right NSF, i came to know that it must be covered while washing. Also, mustn't forget to take off the plastic!! My friend forgot that he had covered the filter and started the engine, he damaged it fully.
Old 8th November 2007, 11:36   #14
gbpscars's Avatar
shouldn't the engine have choked or stalled in a shortwhile? what kind of damage was done to your friend's car's engine?
gbpscars is offline   Reply With Quote
Old 8th November 2007, 11:39   #15
Torqueguru's Avatar
Thanked: 161 Times
He started the car and quickly realised the fact that he didnt remove the cover because of the sudden noise change. No engine damage but the filter became disfigured, unusable.
K&N Typhoon Intake Kit for Honda Civic dinu2506 Modifications & Accessories 35 20th September 2012 21:05
Civic with K&N Typhoon Kit. EDIT : Now TURBO-Charged m4ugr8 Modifications & Accessories 327 6th September 2012 12:12
Corolla K&N Typhoon intake vittalnrv Modifications & Accessories 30 1st March 2007 20:19
original K&N typhoon kits honda_dude Modifications & Accessories 12 24th June 2006 19:50
