Thread Tools
Old 5th November 2007, 12:16   #1 (permalink)
VBV
Default Car Ergonomics
Hi all,
I had a few thoughts about Car Ergonomics and I've penned them down here. Please feel free to add your thoughts on making drives comfortable and strain free.
Driving a car can be pleasure or a pain, if you do not set the right
seating posture. A good seating posture can eliminate lot of back and neck
related injuries in the longer run. With that in mind, here are a few
factors around the discussion of driving ergonomics.
A. Back rest position:
Most cars will have a tilt-able back rest. This is not just for good
support, but also for comfort. If the back rest is tilted too much to the
front, there is a chance that the lower back will get strained over time.
It also important to sit close to the backrest to get enough support to
lower back or lumbar disc.
B. Seat position:
Seats are moved to and fro, based on the driver's reach. The ideal
position as I am told is that the driver should be able to depress the
clutch fully without stretching or compressing one's legs. A bad seat
position usually leads to strain in knees and calf muscles.
C. Seat height:
Some of the newer cars have adjustable seat heights and that should be
adjusted to give complete support to inner things when the clutch is
pressed. Other factors to consider are wind screen visibility and the
meter visibility. The seat height should also be low enough to allow
atleast a fist of space between the head of the driver and the roof.
D. Steering tilt:
Steering should be tilted to give the driver a good view of the meter and
should be perpendicular to one's fist. The other factors to consider are
the space between the things and the steering wheel. If improper, this
adjustment can cause strain the hand joints.
E. Steering reach:
Some of the cars have a telescopic steering to enable people to pull/push
the wheel from them. The ideal setting is that the hands are not
outreached nor are they compressed. This avoids shoulder strain.
Apart from the above common ones, new innovations are being introduced in cars to help in achieving a better driving experience. Some of them are
lumbar disc support, inner thigh support, seat pan tilt etc., In addition
to the above, there are simple features like a proper head rest, an arm
rest, a dead pedal which have been existing for ages. All of these enable
better ergonomic seating position.
A few links on the Internet, around this area are:
Driving Ergonomics: SaferMotoring
Driving Ergonomics
title of your page
Driving Ergonomics - Posture & Ergonomics.
http://www.lanl.gov/orgs/pa/newsbull...andDriving.pdf
Ergonomics and seating comfort in driving safety- MT car magazine for motorists and drivers with latest auto reviews, light trucks and automotive news
6 Tips for Ergonomic Driving at The Ergonomenon
VBV is offline   Reply With Quote
Old 12th November 2007, 05:56   #2 (permalink)
mithun's Avatar
Car Ergonomics is one of the most important points left out by many drivers even when they are behind the wheels !
It can cause you to suffer from back, neck and shoulder pain and can cause cramping and poor circulation in your buttocks and legs. If you are not sat correctly and comfortably, it also has the potential to cause damage to your spine.
__________________
Hold fast to dreams, for if dreams dry, life is a broken-winged bird that cannot fly.
Old 12th November 2007, 11:54   #3 (permalink)
snaronikar's Avatar
Good one. I'am following most of them you have mentioned. Most of the problems will also be caused with the seats itself (in low end cars)
__________________
Love your job but Never love your company
because you never know when your company
stops loving you-NRN
snaronikar is offline   Reply With Quote
Old 12th November 2007, 12:39   #4 (permalink)
kpzen's Avatar
What about the blind spot while driving some cars?? Do they also classify as a part of the car's 'ergonomics'
__________________
Prajesh
ECLIPSEd
Old 12th November 2007, 13:21   #5 (permalink)
n_aditya's Avatar
I wonder why only premium cars like Corolla have lumbar support on the driver seat. After a long drive in my esteem, my back aches very badly and after many adjustments to the seat it still doesnt compare to the comfort of a seat with lumbar support. I wish most cars were equipped with this and also with an arm rest.
__________________
RIP Tootie !!! Missing you terribly.
Old 12th November 2007, 21:07   #6 (permalink)
H'lo
appreciate that someone has raised this topic. I am short in height ie. 5'7" but have found that while driving the honda city (old & new) I was in total control of the car but in the case of the cielo I was at loss although it had height adjustment.
I term this as driveability of a car.
Hence the cars with good driveability (with/without height adjustment) are :-
1. Honda city both new & old
2. Honda Accord
3. Opel Astra Old
4. Toyota Corolla
5. Octavia
6. Old zen 7. Old Fiat 1100
Cars with low driveability are :-
1. Opel Astra
2.Cielo
3. Palio
4. Accent
5. Esteem.
Prudently I like all the cars I have listed so no bias. I would appreciate if someone could explain this or is it just me.
Cheers and thanks
amit mohan is offline   Reply With Quote
Old 12th November 2007, 21:37   #7 (permalink)
Firebird's Avatar
I think even the ergonomics covers the reach to the controls after adjusting the seating position.
What if you have adjusted the seating position correctly, so that the left leg stretches completely for pressing clutch, but the gear lever is somewhat ahead of reach of left hand.
I have observed in old 2nd gen WagonR (may not be applicable to all people), the steering wheel obstructs the dash indicator views, and everytime to see the dash you have to lean forward.
__________________
Firebird
_________________
Matiz SG - 2000 Sold
Palio 1.6 Sport-2006
TEAM-BHP
LEAGUE OF ORDINARY PEOPLE
WITH
EXTRAORDINARY RIDES
Firebird is offline   Reply With Quote
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
