Thread Tools
Old 5th November 2007, 21:13   #1 (permalink)
breezydrive's Avatar
Question Vibrations in car
For the past couple of days, i am facing this problem in my mpfi zen (+80k on the odo)
After the engine gets warmed up & the initial high rpm comes to normal, the engine rpm becomes too low when i remove my foot from the accelerator and causes the car to vibrate.
The situation is terrible at the traffic junctions & in lower gears.
Another thing, the rpm drops further upon switching the headlamps on.
Went to MASS (while they were about to close their shutters), the service engineer told that the throttle body needs to be replaced.
Can u guys help me on this issue ?
breezydrive is offline   Reply With Quote
Old 6th November 2007, 03:09   #2 (permalink)
chetanhanda's Avatar
Looks like an alternator related issue.
Your headlamps are driven off the alternator, the alternator may not be able to provide enough juice to keep ur headlamp+engine running at same time.
The vibrations maybe due to the engine misfiring ,stumbling due to low voltage...
Do your headlights become brighter as the rpm increases ?
Also not necessary that ur actual alternator unit maybe scrwed , could be one of the components of the alternator or one of the belts or wiring, bushes etc which may be stopping ur alternator to not provide sufficient output.
Dude, get ur alternator and its related components checked up, before looking at Throttle body, I wouldn't think of TB at this stage.
chetanhanda is offline   Reply With Quote
Old 6th November 2007, 21:16   #3 (permalink)
yasw_anth's Avatar
me facing the same problem in my zen 2003 mpfi(87k kms)
fuel injectors cleaned recently and the rubber engine mounts replaced but the vibrations still persists..
please help me guys
__________________
Cheeers
Yaswanth :)
yasw_anth is offline   Reply With Quote
Old 7th November 2007, 01:47   #4 (permalink)
please help me guys
lets give this a try ..
vibration could be becoz of anything...
can u check how the engine idles in neutral ? can u step out of the car and listen to the engine and exhuast note ? is it smooth or it sounds like ur engine is struggling to keep idling ? or is the rpm too low at idle ?
Does the vibration go away when u press the thottle slightly or increase while in neutral ?
Old 7th November 2007, 07:21   #5 (permalink)
Given the description, I guess the "vibrations" are caused by very low and/or uneven RPM while idling. I think the electricals should be checked first; and the suggestion that headlamp brightness should be observed at higher RPM (while standing still) is seconded.
__________________
ɹǝʌıɹpʇɐǝsʞɔɐq
Old 7th November 2007, 07:26   #6 (permalink)
Jay
Jay's Avatar
@ Breezy drive : Faced similar problem in my santro, found out the alternator was'nt working properly and needs to be replaced. Check for this on your car.
Also check if the timing is right on your engine. Do you get any jerks at low RPM's ?
__________________
ZONDA !!!
Jay is offline   Reply With Quote
Old 7th November 2007, 11:36   #7 (permalink)
Team-BHP Moderator
Jaggu's Avatar
do a thorough tuning job along with throttle body cleaning. check/clean/replace plugs, air filer and fuel filter.
also if you havent changed the timing belt 80 k is a good point to change them.
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 7th November 2007, 13:10   #8 (permalink)
Thanks guys! very busy this week. Will get the car checked next week
However, headlight checked, brightness unaltered upon increase/decrease in rpm
Old 7th November 2007, 13:49   #9 (permalink)
gd1418's Avatar
Promarily I would suspect the injectors. If they are clogged then the engine 'shudder' could happen. Alternatively, the timing could be suspect...
__________________
Royal Enfield Bullet 1962
All Black 1998 Safari 4x4
All Black 2004 Scorpio GLx
Old 7th November 2007, 14:29   #10 (permalink)
RajaTaurus's Avatar
As you have no change in brightness of h/lamps with speed change, it is most probly low idle setting. Get tuning done and tell the mechanic the problem at that time.
__________________
RajaTaurus...
Friends come, Friends go, those tolerate stay...
RajaTaurus is offline   Reply With Quote
Old 7th November 2007, 18:16   #11 (permalink)
Is it possible to adjust tuning in mpfi engines? i thought ECM takes care of the tuning.
@Jaggu,
got the car serviced at 81467 km (odo reading), the following was done in addition to regular oil changes etc.:
Spark plugs replaced
Engine decarbonised
Injectors cleaned
Car was running smoothly, at 82000km changed tyres & went away to a 1400km trip to Himachal.Everthing was fine till about 83700km.
Now the odo is 84000 & the problem is now getting to the head
Old 7th November 2007, 19:43   #12 (permalink)
not able to picture how would a throttlebody come into this ?, when headlight is switched on the car becomes rough - doen't that sound like an alternator/electrical/ignition related issue ?
surely it seems the ignition timing is off , seems it idles pretty low after warmup..
I'd suggest alternator and ignition timing to be looked at.
ECM doesn't take care of the mechanical parts, in ur case u need to get a timing gun out and adjust the timing... u may need to advance ur timing etc. In short the distributor is driven off ur crankshaft by a pulley, the distributor is responsible for providing the spark to the cylinders, so ur distributor's rotaton must match perfectly with the rotation of the crankshaft driving it.So if u rotate the distributor a few degrees it will affect how much before or how much after the spark will ignite. there will be a mark on the timing belt + mark on the block/cover .. which will be like a reference point for u to know when the spark should ignite, u simply need to match the timing guns flash with the mark on the belt and ref point, u may need to advance/retard ur distributor to make these coincide as per specs...
Old 7th November 2007, 20:08   #13 (permalink)
yasw_anth's Avatar
while in neutral the engine sounds normal but when in neurtal for more than ~1min the rpm decrease and then gets to normal.. is this misfire ?? im using iridium(HKS) spark plugs since 10k kms.what is the life of these plugs ? requires replacement? or is it due to a block in fuel line ?
__________________
Cheeers
Yaswanth :)
Old 7th November 2007, 20:32   #14 (permalink)
yasw_anth's Avatar
yes the vibration vanishes when accelerated slightly and is more while in neutral! and i dont find any change in headlight brightness..but i can find voltage fluctuations(with a/c)observed sometimes from the intensity of light changed with a/c and also the accelerator not responsive as before..
__________________
Cheeers
Yaswanth :)
Old 7th November 2007, 21:42   #15 (permalink)
highwayblaze's Avatar
I think your idle rpm's too low. Is there an odometer on your car. On cold start (coolant temperature less than a particular value) the ECU orders additional engine rpm. After temperature rises above a certain threshold ECU orders the engine to run at that low idle which is causing the vibrations that u'r talking about. So if there's any way to increase your idle rpm to a little higher i guess this should be fixed.
__________________
Chill Pill
Blaze
highwayblaze is offline   Reply With Quote
Thread Tools
Vibrations at high speed DCEite Technical Stuff 15 12th June 2007 16:43
Scorpio Vibrations rb2399 Technical Stuff 5 17th April 2007 06:42
Vibrations after upsize Knight Rider Tyre & Alloy wheel Section 14 21st June 2006 20:56
Optra - steering vibrations over 80 km/h Boom Shiva Technical Stuff 10 23rd May 2006 11:58
vibrations in zen 97 carb. heavy_foot Technical Stuff 11 30th May 2005 11:01
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
