| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Nov 2007 Location: Thane
| Hello, I am a newbie to the forum and also happens to owns a pre-owned Palio ELX 1.2. Initially my palio 1.2 Elx did not start. The fuel injector icon used to glow continuously. On cranking the car further, the fuel injector icon would come on and then go off (behaves normally) but the car would not start. It has clocked 59000 odd KMs. One of the local mechs I called to have a look at my car said the coil needs to be changed, but later told me the problem lies elsewhere ie The mechanic found some of the wires gnawed by rats, which he taped up and then replaced a relay (that is what he told me), still the fuel injector icon was glowing after the car was cranked and running. I then took the car to Balaji Motors and they told me initially that it was a problem with the wires but later on they have told me it is a problem with one of the sensors, which needs to be replaced. The car is running fine but the injector icon lights up intermittently (when driven over potholed stretch of roads). I again took it to a local mechanic to check up the car, He checked the following; 1) for problem with the couplers 2) ECM 3) electrical wiring 4) fuel injectors still the red light was not going off, then i asked him whether he can test an ECM of another car and see. He tested the ECM of another car(Siena 1.2)and told me its the problem with the ECM, and the ECM should be changed. On further tests with the ECM he found the ECM to be OK. The problem was isolated and found to be in the electrical wiring near the front fender. The concerned wire was patched and the red injector light went OFF, what a relief, but the moment of joy was temporary. Yesterday I had taken the car to Dadar(Mumbai), while going there was absolutely no problem, I even touched 100 KmpH. While coming back I got bumper to bumper traffic (yes i was on half clutch in the bumper to bumper traffic.), AC was on, and I was getting a grating kind of a sound with in the car, I also noticed the temperature guage was steadily rising past the halfway mark, I stopped the car when the temperature needle came very near to the redline H mark on the guage. On stopping I noticed the car had really heated up and vapour was coming out of the bonnet. I let the car cool down for an hour or so and when the temperature guage was below the half way mark, I took the car back to the mechanic. He inspected the vehicle and did the following changes as mentioned below; Coolant- Changed Thermostat- Removed the valve and gave direct connection for the coolant circulation within the engine block. Fan Assembly- Says the same has to be changed. Queries: 1)Could the fan assembly be damaged due to the electrical wiring, which he was trying to fix initially? 2)Does removing the thermostat effect the performance of the car in any way? Kindly explain. 3)Can the fan assembly be repaired or do I need to go in for a new one? I am a newbie with no experience with automobiles, this is my first car. P.S: Also the mechanic has told me that the engine would not overheat because the thermostat has been removed and the coolant is allowed to circulate freely, I have notice hot air coming from underneath the car which was not the case earlier. Kindly help. Thanks in advance. KKM |
| | #2 (permalink) |
| BHPian Join Date: Oct 2007 Location: Brighton
| 1.I dont think that the fan assembly could have been damaged as it has a relay and a fuse to protect it but if someone has messed with the wires after coming through the fuse box then there is a possibility. 2.Yes removing the thermostat does effects the performance of the car. The reason for that is the optimum temp an engine needs to perform at its best. If its cooling it to much then you would not get the best performance and your Km/L will also decrease. 3.I dont know if there are any good electrician who can reapir in your city but I would recomend a new one if its damaged. The hot air coming from the car could be due to your radiator fan switched on at all times. I would seriously suggest you to take your car to any descent mechanic and not the one who says its ok to run the car without a thermostat. He is talking S**t. |
| | #3 (permalink) |
| I took back the car to the mech who had serviced the car for the 1st time, after buying the car. He checked the car and found the fan motor to have burnt off, got it replaced. I would be putting back the solenoid valve back during the next service. Thanks, KKM
__________________ KKM |
| | #5 (permalink) |
| BHPian | This is what i know. If you remove the thermostat, the fan would be running always. THe thermostatn controls the running of the fan by switching it on and off based on engine temperature. By running the fan contineously, you could end up with a burnt fan again. Still not sure why the mechanic did that. The injector lights come on when the ECU registers any malfunction. You will have to read the error using the computer at the A.S.S. I suggest you take to car to an Authorised Service centre the next time you get the injectpr lights on. One the error is read they will delete the error from the memory and rectify whatever was wrong. And why have you removed your selenoid valve!!!
__________________ "Our world is in its current state because of the choices WE made ...or failed to make" |
| | #6 (permalink) |
| I had taken my car Balaji Motors-Thane, I can tell you they are the pits. I had specifically told the advisor at Balaji about the red injector icon glowing intermittently, instead of addressing the mentioned problem he asked me to get 2-3 different things done on the car. Not only that when i went to collect the car the next day the original problem was still there and then he started singing a different tune(replacing some sensor). That is when i decided to take it to a local mech(who rectified the prob, but blew the fan and removed the solonoid valve) after these above experiences i think i should stick with the original mech who worked on my car for the 1st time. Is there any really good service centers available in mumbai-thane or else i guess i should take an appoinment with Turbosam to have a look at my car.
| | #7 (permalink) | |
| BHPian Join Date: May 2007 Location: Mumbai
| Quote:
goodluck Last edited by FERRO : 22nd November 2007 at 18:23. | |
| | #8 (permalink) |
| I am continuing with same thread, since there would be continuity. I have noticed recently on a drive through to Borivali via Ghodbunder road(which has sharp turns and hairpin bends) a squealing sound coming from the car, the same which we normally get when brakes are applied at high speeds. I was cruising in the 5th gear, the vehicle was loaded. I took couple of the sharp turns in the 5th gear when i heard the sound from the car. I am not able to figure it out. Could there be some issues with the car? Kindly help. regards, kkumarm
| | #10 (permalink) | |
| BHPian | Quote:
__________________ Taken the plunge! www. virtu. in __________________ 2002 Lancer | 2006 Palio | 2008 Trek 4300D | |
| | #11 (permalink) |
| Newbie Join Date: Jun 2006 Location: Bangalore
| The road surface wearout at such hairpin bends will be more. when you drive your car in high speed you do get a kind of sound which is unpleasent. The reason could be your caliper pin of disc brakes in your palio. To test this, give a pat to the type when the vehicle is off. If you find a slight vibration, it is a confirmation. Remidy: You need to put a copper shim near the caliper pin which is loose.Should not cost more than Rs 100 plus labor. Do let me know if your problem is solved or not. |
| | #12 (permalink) |
| Hi, A couple of days back i had noticed the brake light indicator glowing when the car was in motion, this was on and off. I consulted my mech, he told me it could be due to brake/clutch oil. Today in the morning while starting the car found the clutch pedal going all the way down to the floor. 1) What could be the issue and how do i get this fixed. 2) If there is a need to top up the brake/clutch oil, in my case, what would be the best practices involved. I had checked the net and found the following website on bleeding brakes. Bleeding Brakes Would this technique be necessary in my case. Thanks and Regards, KKM
| | #13 (permalink) |
| The mech checked out the clutch cylinder and tried bleeding it, it was partially successful. He noticed that there was problem with the clutch cylinder located near to the clutch pedal. He advised me to change both the cylinders, i got it changed. How much does a replacement of this kind cost in Fiat Palio 1.2 ELX? I was charged Rs 3650. Is this a fair charge? I have another query: what can be done when such a situation arises (no clutch) when one is driving on the road(luckily for me the problem was noticed when the car was parked ) Thanks and Regards, KKM
« A small difference between DDiS and 1.3 MJD.
palio 1.2 nv low fuel effeciency (under warranty) 12k kms done »
| Thread Tools | |
Similar Threads | ||||
| New home to my Palio-D ELX | Ketan | Shifting gears | 4 | 5th November 2007 11:21 |
| Looking for Palio 1.2 ELX model | mahen194 | Hatchbacks | 3 | 28th May 2007 12:07 |
| Fiat Petra 1.6 ELXP or Palio 1.6 sports or Palio 1.2 nv ELX? | Travel-X | Hatchbacks | 20 | 8th November 2006 17:36 |
| Accessories for Palio 1.2 NV ELX | bangboy | Ask the Gurus | 8 | 6th June 2006 17:01 |
| palio elx ps | heavy_foot | Shifting gears | 15 | 9th April 2005 16:03 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
