Old 15th November 2007, 23:05   #16
BUSA's Avatar
No 3rd or first, only with 2nd gear. I dont know why they are saying clutch but they said they checked the gearbox completely.
The car used to go in 2nd while re clutching twice or so.
Old 15th November 2007, 23:24   #17
Jaggu's Avatar
Thanked: 8,678 Times
hmm thats interesting, keep us updated once you get the car back
Old 16th November 2007, 20:17   #18
Jaggu's Avatar
any updates?? .
Old 16th November 2007, 23:14   #19
PatienceWins's Avatar
Thanked: 284 Times
Interesting problem. BUSA, keep us updated. I love the Swift diesel engine.
BTW, this problem would not have happened if you went for a Getz.
PatienceWins is offline   Reply With Quote
Old 17th November 2007, 22:49   #20
kpzen's Avatar
Thanked: 1,655 Times
BUSA
Did u get the car back?
Old 17th November 2007, 23:05   #21
Awaiting Email Confirmation
Thanked: 319 Times
Default Torque the gearbox and clutch can handle
Dear Busa,
When you get the car back do find for yourself and for the information of others as to what happens to be the maximum torque the FIAT gearbox can handle. You have a PSI box I hear. There are lot many cars in the northern part of Kerala thats been having clutch plate problems after Maruti attempted to change the original vendor.
Bye and wear your seat belts.
drpullockaran is offline   Reply With Quote
Old 17th November 2007, 23:10   #22
BUSA's Avatar
Not yet got the car back.
Went to the dealership yesterday to see the car. It was jacked up with the front tyres removed and the front bumper out. Also the engine was out of the car. Engine is quite compact though.
He told me yesterday that they changed the gearbox(but the problem isint with it) then the clutch, they will put the engine back and try to deliver the car tomorrow(saturday)
I went today at around 7 or so in the evening and the guys were testing the car, the engine was in butttttt out of 10 times once-twice it still used to miss going into second. He showed me the new clutch and flywheel which he has put in the car. However since its still not completely solved he said he has called the MUL engineer on monday and they will change the 2nd and 3rd gear synchros. That means again removing the engine and all. Hopefully i should get the delivery by tuesday with the issues resovled.
Till then i have the Orange Swift Petrol to drive around in so no complains, but that car rattles like absolute crazy
Dr can you please say when did MUL change it, mine is a May 2007 model.
Old 17th November 2007, 23:26   #23
kpzen's Avatar
Did they check the gear shift lever ?
Old 17th November 2007, 23:32   #24
BUSA's Avatar
I dont think so, but i guess they are going to do a through check on Monday.
Old 17th November 2007, 23:49   #25
ported_head's Avatar
Your new flywheel and clutch assembly, will probably not be the same quality as OEM stuff. Even though they will be MGP stuff. SGP quality is much better though. Make sure you have an idea about what's going in.
ported_head is offline   Reply With Quote
Old 17th November 2007, 23:55   #26
BUSA's Avatar
@ Ported - The New Flywheel and Clutch assembly is SGP.
I am in talks with DWM WM regularly and go to the dealership and check the car in directly where customers are not allowed though i get permission.
Old 18th November 2007, 13:13   #27
Originally Posted by Ford Rocam View Post
Interesting...
I am hearing it for the first time that a service centre is giving replacement vehicle till they fix the gear problem. which service centre is this?
All MASS give a replacement vehicle. and free drop and pick up for female customers. Plz request MASS and they will give you more information.
Peace
bmdesai1987 is offline   Reply With Quote
Old 20th November 2007, 15:24   #28
BUSA's Avatar
Problem has been solved. The 2nd gear synchornizer slot had worn and got cut.
Costs 30,000/-
Old 20th November 2007, 15:26   #29
Eddy's Avatar
Thanked: 5,067 Times
Costs 30,000/-
Covered by warranty ?
Eddy is online now   Reply With Quote
Old 20th November 2007, 15:41   #30
BUSA's Avatar
Yes, covered in warranty.
2nd Hand Skoda RS Edit: Now bought. rchimni Sedans 33 12th April 2016 18:47
Mercedes SLK 55 AMG launch on 2nd December, 2013 Edit: Now Launched sarathlal Super-Cars & Imports in India 11 3rd December 2013 04:34
SWIFT - Shifting to 2nd gear problem eflanker Technical Stuff 45 31st January 2009 16:49
