Old 28th December 2007, 14:33   #46
BUSA's Avatar
Now the car refuses to slot into first gear. Same problem as before but with 1st gear. The dealer checked and has told me its a problem with 1st gear synchro, apparently others are also facing similar issues. The batch to which my Swift belongs has defective gear synchros.
He has ordered the part and it will take 2 days for it to come. Damn MSIL and their cost cutting.
Old 28th December 2007, 14:37   #47
Thanked: 63 Times
Busa
Can you tell me the lot of cars which is facing this issue ? I got mine in Aug 2007 and sometimes I face issues with second gear, not observed frequently
lambuhere1 is offline   Reply With Quote
Old 28th December 2007, 14:47   #48
Jaggu's Avatar
Thanked: 8,670 Times
@Busa: why dont you push the dealer for gear box replacement instead, since you have a good rapport with them.
Old 28th December 2007, 16:22   #49
kpzen's Avatar
Thanked: 1,655 Times
BuSa: Since u get most of things replaced under warranty why don't u get the whole gearbox replaced too
Old 28th December 2007, 17:16   #50
BUSA's Avatar
@lambhuere - My car is May batch. I dont think your batch of cars have this problem.
@KP & Jaggu - They have identified problems with just 1st and 2nd gear, and its not with just my car, many cars are facing it. Getting a gearbox replacement will be time consuming and also not that easy. Anyways lets see what can be done.
Old 29th December 2007, 22:28   #51
BUSA's Avatar
Spoke to the dealer, he said that since the gearbox is integrated in the engine, it is not a easy task to replace the whole gearbox.
Old 29th December 2007, 22:32   #52
Vid6639's Avatar
Thanked: 20,984 Times
huh??? who? what? where when? why? how?
Old 29th December 2007, 22:33   #53
CrAzY dRiVeR's Avatar
Thanked: 19,776 Times
Integrated in the engine?
The clutch comes in between these two, right? I think he meant that the engine may have to be taken out to dissassemble the gearbox.
Old 29th December 2007, 22:55   #54
BUSA's Avatar
D Company asking so many questions in a single post.
I think crazy is right, he meant something like that, but they do remove the engine to change the synchros, then why the fuss?
Old 29th December 2007, 23:07   #55
Vid6639's Avatar
I asked cause I thought that you can remove it by removing the sub frame below. That's how I think it's in the petrol swift and in the lancer. Correct me if I am wrong.
Old 29th December 2007, 23:20   #56
Awaiting Email Confirmation
Thanked: 319 Times
Default Cost cutting was involved
I know for sure cost cutting was involved but I thought that it was restricted to cars sold only in the northern part of Kerala. Majority of the swifts sold there tried an Indian made component from another manufacturer/vendor. I heard it was clutch plate now it looks like the syncros are involved in this too. Best of luck. Bye and wear your seat belts.
drpullockaran is offline   Reply With Quote
Old 29th December 2007, 23:55   #57
BUSA's Avatar
@ Vid - I have seen the MSIL guys remove the engine to remove the gearbox, last time when there was a second gear issue, maybe the engine bay is too cramped to work on with the engine intact.
Old 30th December 2007, 11:08   #58
kpzen's Avatar
Vid
U are right about the Swift P and lancer but in case of Swift D the engine has pulled out for removing the gear box.
The reason is the limited space in the engine bay to put in the tools.
BUSA- U are dragging with Verna's without 1st gear??
Old 30th December 2007, 11:43   #59
BUSA's Avatar
First engages with difficulty, when the car is in motion and i want to slot first then it just doesnot go, while the car is standing still it engages perfectly.
Old 21st January 2008, 12:48   #60
Eddy's Avatar
Thanked: 5,065 Times
BUMP:
Any updates on this BUSA ? Has it been solved ?
Eddy is offline   Reply With Quote
2nd Hand Skoda RS Edit: Now bought. rchimni Sedans 33 12th April 2016 18:47
Mercedes SLK 55 AMG launch on 2nd December, 2013 Edit: Now Launched sarathlal Super-Cars & Imports in India 11 3rd December 2013 04:34
SWIFT - Shifting to 2nd gear problem eflanker Technical Stuff 45 31st January 2009 16:49
