Old 21st January 2008, 13:04   #61
akash_m's Avatar
Thanked: 88 Times
Damn! My swift dosnt go into reverse gear eaisly. Usaually takes 4-5 tries to engage properly. REst all gears are smmoth. I guess this problem may be related to swift clutch issues discussed enourmously elsewhere.
Might be that the pressure plate is not disengageing the clutch fully making the gear shifts harder!
akash_m is offline   Reply With Quote
Old 21st January 2008, 13:20   #62
Thanked: 7 Times
Reverse gear issue is a known thing with cars from Maruti stable. So nothing to worry about, Just reclutch until it falls in the slot. !!
Btw is BUSA's Swift a petrol or diesel one ?
emkay456 is offline   Reply With Quote
Old 21st January 2008, 13:36   #63
Eddy's Avatar
Thanked: 5,078 Times
His is a VDI with ABS with Pete's with Greens.
Eddy is offline   Reply With Quote
Old 21st January 2008, 13:40   #64
BUSA's Avatar
Originally Posted by Eddy View Post
Any updates on this BUSA ? Has it been solved ?
Not yet, the car will be going for the change in first gear synchro this week, will update once i get it back.
Soon your car will be similar, yours is a VDi ABS, hmmm cheers:
Old 21st January 2008, 13:41   #65
nitrous's Avatar
Thanked: 285 Times
Why are ur synchros being eaten up and spit out by the engine?
Heavy downshifting,kya?
Old 21st January 2008, 13:58   #66
BUSA's Avatar
Nahi, Nitrous Anna : The Boss, defective parts from Maruti, many cars manufactured in same time frame having the same problem
Old 27th January 2008, 05:11   #67
sameer_dg's Avatar
I am not facing this problem though I am facing a slight harshness in changing gears, it is smooth at some angles other times it gives a rought feel.
sameer_dg is offline   Reply With Quote
Old 27th January 2008, 13:32   #68
Eddy's Avatar
Is this confirmed news ? And what time period ?
Old 27th January 2008, 13:48   #69
BUSA's Avatar
Yup, confirmed by the dealer. Cars from the May batch are facing the issues.
Old 28th January 2008, 16:36   #70
[quote=emkay456;695598]Reverse gear issue is a known thing with cars from Maruti stable. So nothing to worry about, Just reclutch until it falls in the slot. !!
quote]
My Swift VDI also gives issues while putting reverse gear. Have to release the clutch and then put again. But what you say is a news for me! The mechanic told me the same during first service but i dismissed him thinking he is just avoiding the problem. But this is weird that such a problem can come up in a new car, and the fact that we have to live with it...even weirder!!!
Is it for sure nothing can be done about this, or someone has found a solution?
maverickzCar is offline   Reply With Quote
Old 28th January 2008, 20:51   #71
horsepower's Avatar
I have noticed that early morning when car is driven cold, gears are hard especially reverse and first.
horsepower is offline   Reply With Quote
Old 29th January 2008, 02:49   #72
iraghava's Avatar
Thanked: 156 Times
That's because in our relatively cold temperature these days the gearbox oil temperature drops & the oil thickens which makes changing gears a little difficult. Once the oil is warmed up the problems should disappear though.
Old 4th February 2008, 21:29   #73
BUSA's Avatar
Exclamation
The car is in the workshop since ~ 5 days, the work is in progress. The engine is out, front bumper out. Work going on. Another Swift was there getting 3rd gear synchros replaced Now if i get a third gear problem, then the time it will be to book the Getz CRDi
Some pics of the WIP
Old 4th February 2008, 21:40   #74
jaibir's Avatar
Thanked: 48 Times
Sorry to see this BUSA. Hope they can fix it properly this time.
jaibir is offline   Reply With Quote
Old 4th February 2008, 21:42   #75
Thanked: 40 Times
BUSA > Are you looking for some excuse to book the Getz-D , brother?
rrnsss is offline   Reply With Quote
2nd Hand Skoda RS Edit: Now bought. rchimni Sedans 33 12th April 2016 18:47
Mercedes SLK 55 AMG launch on 2nd December, 2013 Edit: Now Launched sarathlal Super-Cars & Imports in India 11 3rd December 2013 04:34
SWIFT - Shifting to 2nd gear problem eflanker Technical Stuff 45 31st January 2009 16:49
