Old 7th November 2007, 17:48   #1
BUSA's Avatar
Exclamation Swift 2nd Gear Problem EDIT: Now first gear problem
My Swift Diesel is not going into 2nd gear while downshifting, it goes to 2nd only while upshifting i.e its not downshifting into second.
Showed the car to the service guys and they said this is one of a kind of problem, have told me to leave the car on monday and if the work is more then one day they will give me a replacement vehicle.
The problem could be gear linkage or the whole gearbox altogether, which would be replaced compleltely under warranty.
The thing is Maruti should use quality, maybe this problem is a one off, but the whole ECU problem and then wiring harness problem shows there isint a good QC in MSIL.
I didnot remove the petes box this time and the service guy saw it, he said its not a problem wrt warranty as he would handle it
Old 7th November 2007, 17:57   #2
crazydiablo's Avatar
Thanked: 21 Times
Hope the petes box comes back with the car.
crazydiablo is offline   Reply With Quote
Old 7th November 2007, 17:58   #3
BUSA's Avatar
I will be removing it before giving the car on monday. Today i just had to show the car and take a appointment, so didnot make sense to remove the box,
Old 7th November 2007, 18:51   #4
Ford Rocam's Avatar
Thanked: 16 Times
Interesting...
I am hearing it for the first time that a service centre is giving replacement vehicle till they fix the gear problem. which service centre is this?
Ford Rocam is offline   Reply With Quote
Old 7th November 2007, 18:59   #5
moralfibre's Avatar
Thanked: 6,533 Times
Busa, not about 1st to 2nd but I find the Swift Diesel gearbox too bad when you consider shifting from 5th to 4th.
Originally Posted by Ford Rocam View Post
Interesting...
Our own Shrivz gets a service car from Wonder Cars each time he puts his Baleno or Baleno Altura for service. Quite commendable that. I don't if its his size that they fear about.
Old 7th November 2007, 19:00   #6
BUSA's Avatar
FR, it is Automotive, Manf, Maruti Service Center. I had got a replacement vehicle before also for gear oil leak in my Swift D.
Actually if you know the service center well then it helps.
I am sure they are going to give me a 35000kms done Swift Petrol on stock worn out slick JK's, which is their demo cars and rattles like crazy. But however the replacement vehicle is the initiative is good.
Old 7th November 2007, 19:00   #7
Thanked: 9 Times
Bangalore, Mandovi Motors in Vijayanagar also gives a loaner car when people leave their car for service !.
iridium is offline   Reply With Quote
Old 7th November 2007, 19:27   #8
toiingg's Avatar
Thanked: 85 Times
Best time to practice some 180's
toiingg is offline   Reply With Quote
Old 7th November 2007, 19:41   #9
kpzen's Avatar
Thanked: 1,655 Times
Do u know Mr. Jagdish Khattar or what??
Old 7th November 2007, 19:55   #10
sbasak's Avatar
Might be a problem with synchromesh. In that case replacing the 2nd gear synchro should fix it.
sbasak is offline   Reply With Quote
Old 8th November 2007, 00:22   #11
BUSA's Avatar
Haha, its way too risky on those tyres, on slight turn the tyres screech.
No, but i know the service advisor since quite a few years, since i had a esteem in 2000, serviced at the same service center.
That could be another possibility according to the service advisor.
Old 8th November 2007, 00:52   #12
D1ISTHE1's Avatar
MSIL, has a very poor quality control, especially in the Swift the quality of materials is disgusting.
D1ISTHE1 is offline   Reply With Quote
Old 8th November 2007, 01:05   #13
kartikkumar's Avatar
It sure is a one of a kind problem. I find the gearbox on my DDiS a dream and perfectly slotted. I particularly love the way it clicks into place with no play at all. Hope the problem gets fixed quickly dude.
Cheers!
kartikkumar is offline   Reply With Quote
Old 15th November 2007, 18:58   #14
BUSA's Avatar
Edit - They have removed the engine, gearbox, bumper, radiator and are working on the car, the gearbox is fine. Its said its a clutch pressure plate issue. All that at 11k kms. Should be getting the car tomorrow.
Old 15th November 2007, 22:49   #15
kpzen's Avatar
Were u facing the same problem with 3rd gear also??
Clutch plate issue Normally clutch plates issue is when there's a problem with 1st gear or reverse.
2nd Hand Skoda RS Edit: Now bought. rchimni Sedans 33 12th April 2016 18:47
Mercedes SLK 55 AMG launch on 2nd December, 2013 Edit: Now Launched sarathlal Super-Cars & Imports in India 11 3rd December 2013 04:34
SWIFT - Shifting to 2nd gear problem eflanker Technical Stuff 45 31st January 2009 16:49
