Closed Thread
Old 8th November 2007, 14:05   #16
2fast4u's Avatar
Originally Posted by ananthkamath View Post
Its not just about which wheels are driven. Its also about the overall balance of the car and the weight distribution. You cannot even get close to the ideal 50/50 balance that a typical RWD car offers in a FWD. That is what changes the equation.
I also feel that if its RWD it should be Manual transmission as this helps taking corners without lowering speed. the auto tranny is scarry.
2fast4u is offline
Old 8th November 2007, 14:36   #17
vnabhi's Avatar
Thanked: 1,317 Times
I guess FWD cars are better---I recall an ad around a decade ago with a guy pulling a partly opened matchbox on a table with his finger (FWD), and pushing it from the back (RWD). He concluded that FWD was better.
vnabhi is offline
Old 8th November 2007, 16:20   #18
Thanked: 253 Times
Originally Posted by sbasak View Post
I often notice there is so much enthusiasm about RWD cars because of their superior handling characteristics.
I read about torque steering and over steering but does it affect if you are driving sensibly on public roads?
And how often that is "feelable" in normal day to day driving??
Your observation has been proved again - enthusiasm about RWD cars etc..!
To answer your very simple question: the difference is not "feelable" if you are driving sensibly on public roads, or in normal day to day driving. The rest is all been here done that, as you have seen already!
anupmathur is offline
Old 8th November 2007, 17:16   #19
Awaiting Email Confirmation
50/50 weight balance is "ideal" only in BMW marketing literature. Real world experience differs, slightly more mass on rear would usually be better in real world conditions (both braking and acceleration). Then there's the other extreme of certain Porsches, and the cars' entire design seems to be motivated by fighting this inherently flawed weight distribution.
But of course, both 50-50 or a biased 48-52 are far more preferable to front weight bias, as long as the car is designed to fully exploit this character.
The role of suspension and chassis specifications etc cannot be underestimated in final handling behavior.
SuperSyn is offline
Old 8th November 2007, 17:20   #20
True enough.
At 7/10 or 8/10, the typical FWD cars like Accord are just as good as anything a driver might require, and will certainly be better than certain RWD cars in snow/wet conditions. (Electronic nannies to the rescue).
SuperSyn is offline
Old 8th November 2007, 19:14   #21
Thanked: 103,674 Times
In flat out acceleration, the torque-steer from a FWD is annoying and all too evident. In spirited driving around the curves, its just too easy to differentiate the behaviour between a FWD and a RWD.
Of the two, I'd pick a RWD anyday anytime.
GTO is offline
Old 8th November 2007, 21:21   #22
ananthkamath's Avatar
Thanked: 63 Times
When a car is sitting still the most ideal balance to have is 50/50. Period. When it is moving though, weight transfer comes into play and as we all know: suspension tuning IS controlling weight transfer.
ananthkamath is offline
Old 8th November 2007, 22:09   #23
1100D's Avatar
Thanked: 2,503 Times
I do remember that. It was quite baseless. Why, The matchbox in this case was more of a trailer than a locomotive, as it was being moved on external force. Secondly a matchbox does not have direction guiding capabilities a car has (namely the steering system).
This was articulated beautifully by someone very close by using a shopping cart example. The carts turn because the external force is making it turn. Very unrelated to the working principles of a self propelled automobile.
1100D is offline
Old 8th November 2007, 22:14   #24
vivekiny2k's Avatar
Thanked: 184 Times
another thing you may notice is when you NEED traction, say a rainy day and starting form a signal uphill (or even flat), RWD will give you better traction unlike FWD which starts wheel-spinning.
on corners, I have seen a lot of the RWD fishtailing in rain. mostly because power to weight ratio is much more in US cars/trucks.
vivekiny2k is offline
Old 8th November 2007, 22:20   #25
Nitin's Avatar
So true. There have been times when my car's swerved all over the road,when I'd start moving on an incline. Corners feel tight and secure,there's no beating that.
Nitin is offline
Old 8th November 2007, 23:05   #26
But it is true that FWD is much safer than RWD in most driving conditions... the reason why most car manufacturers moved to FWD from RWD.
Regarding oversteer in RWD cars, no production RWD sedan or coupe oversteers. The suspension in all the RWD cars are factory tuned to understeer. In sports cars though, it is different.
Mayavi is offline
Old 8th November 2007, 23:06   #27
chetanhanda's Avatar
Thanked: 44 Times
During normal driving no diff, when u actually floor the throttle u get to see the diff.
RWD is more enjoyable when u floor it, wish my car was RWD ...
chetanhanda is offline
Old 9th November 2007, 00:55   #28
1100D's Avatar
Originally Posted by Mayavi View Post
But it is true that FWD is much safer than RWD in most driving conditions... the reason why most car manufacturers moved to FWD from RWD. .
Agreed. Safer, yes (for the average driving population). Faster exit speed thru a corner, no.
Now in US most drivers do not speed on a turn, they speed on a straight, in this case makes no difference. Moreover most US RWD's pre-charger/300c era were softly sprung. So they do not represent the sporty nature of RWD. Some people actually enjoy driving on ramps more than driving on the interstates meant for boats. Most german RWD's are sporty, even under very non sporty clothes.
In my first post I had actually compared the E320 with the Acura TL 3.5. Both cars of similar power output. TL is Sport tuned FWD and my E320 had the sports suspension package optioned by the first owner. I guess that was a true comparison of FWD vs RWD OF adequate power.
I beg your pardon?!
1100D is offline
Old 9th November 2007, 00:55   #29
iraghava's Avatar
Thanked: 156 Times
Yes, FWD is much more tolerant to ham-fisted drivers, whose abrupt inputs can be lethal in RWD. But, that's not the only reason, FWD is also cheaper to manufacture than RWD so that also plays a part.
iraghava is offline
Old 9th November 2007, 01:02   #30
1100D's Avatar
Modern RWD with traction control, it does not pose as challenging to the drivers you mention.
The only point is mainly the flexibility of platform sharing and packaging (small external sizing) that the FWD offers and overall lower cost of production. The real benefit of FWD, contrary to what the manufacturers will like you to beleive, goes to the manufacturers pockets.
1100D is offline
Closed Thread
FWD climbed a hill but RWD failed. Reason ? mithun Technical Stuff 29 13th April 2015 20:09
RWD, FWD, AWD-what would you choose? nitroxx Shifting gears 38 30th April 2010 13:41
converting a FWD to a RWD....POSSIBLE? twister Technical Stuff 21 27th April 2006 03:05
