Closed Thread
Old 9th November 2007, 22:51   #46
1100D's Avatar
Thanked: 2,503 Times
Originally Posted by Mayavi View Post
I wrote: Most production RWD sedans are tuned to understeer.
Here is why
....even rear-drive cars sold to average consumers...
I did notice that my coupe understeer's and I have to either slow down or turn the ESP off and accelerate to take the corners. This has been the experience of other C class owners too who drive on stock set-up.
The Keyword here would be cars for the average driver. Thats also what I meant on the quote below.
Originally Posted by 1100D View Post
Now in US most drivers do not speed on a turn, they speed on a straight, in this case makes no difference. Moreover most US RWD's pre-charger/300c era were softly sprung, devoid of grip.
My experience may be different from yours on account of my car having the sports suspension setup and no ESP (ESP does a lot of unecessary tricks on you). But have driven a couple of E36's and E34's they too are on the pointy side (although E36 rolls a bit).
where the rear wheels are heading for the weeds, you have to both slow down and counterintuitively turn the wheel in the opposite .
I dont quite agree totally on the slowing down part. One has to modulate the throttle based on the situation.
1100D is offline
Old 10th November 2007, 00:01   #47
BlackPearl's Avatar
Thanked: 5,144 Times
then there is left foot braking in fwd which can help to drift a lot and at much higher speeds than that possible with hand brakes.
BlackPearl is online now
Old 10th November 2007, 01:26   #48
1100D's Avatar
Since this has eventually come up, before anybody attempts a LFB turn. One needs to make sure, he/she has had adequate exposure to how the brake pedal feels while being operated by the left foot.
Generally the left leg needs practice to come to terms with the pressure requirements. It is recommended to do straight line braking with the Left foot, for familiarization.
1100D is offline
Old 10th November 2007, 01:41   #49
rocksterraghu's Avatar
Thanked: 97 Times
Even a M800 can drift on the handbrake, if the brakes are proper. And in my opinion it actually displays a huge control while doing so. Infact handling wise, I dont think any FWD car in India ever comes close to a "proper" Maruti 800.
True. One just has to remember that Maruti 800 is not a very safe car to try adventurous things, that is all.
rocksterraghu is offline
Old 10th November 2007, 02:04   #50
vivekiny2k's Avatar
Thanked: 184 Times
hasn't the situation already been mentioned. rear whels lost traction, car oversteered, driver trying to regain control.
IMHO, the whole reason behind fishtailing is not being able to control the car and steering alternately on either side until balance is regained (or not).
I can see the point that FWD will not fishtail on either side in case of a loss of traction on front wheels.
vivekiny2k is offline
Old 10th November 2007, 02:40   #51
ananthkamath's Avatar
Thanked: 63 Times
Originally Posted by SuperSyn View Post
True enough, though I am sure people appreciate the handling of their cars more when driving rather than standing still there seem to be some compromises in road car suspension engineering which makes a more rearward bias desirable.
You misunderstood. I meant that, rearward weight bias can be achieved through control of weight transfer rather than static weight bias, which is what we were alluding to earlier.
ananthkamath is offline
Old 10th November 2007, 02:42   #52
Thanked: 63 Times
I disagree. A FWD can be made to fishtail through incorrect application of throttle and steering inputs, which is most likely what an inexperienced driver will do. Hence FWD can be equally dangerous when pushed hard.
Example: My own Jetta. If I start accelerating out a corner hard, the car starts understeering. Alarmed by this, if I let off the throttle, all the weight transfers to the front, and the rear end becomes light. Result: Snap Oversteer. I get even more alarmed by this, and I give opposite lock. The car has, however, stabilized itself, and starts coming back to line. But the opposite lock overcompensates and the back starts swinging in the other direction. Result: Fishtailing. See what I mean?
Which is why weight transfer is much, much more important in the overall balance of the car rather than which wheels are driven.
Old 10th November 2007, 03:00   #53
vivekiny2k's Avatar
Thanked: 184 Times
may be i am wrong, but my brain still thinks FWD has to be pushed HARDER to be equally dangerous.
well, actually mayavi was favoring understeer, regardless of which set of wheels is driven. I should have noted.
Old 10th November 2007, 07:21   #54
DirtyDan's Avatar
Thanked: 776 Times
Default Definitions
Understear: car hits tree with front end
Overstear: car hits tree with back end
high Horsepower: car hits tree very, very hard
alcohol: tree hits car very, very hard
DirtyDan is offline
Old 10th November 2007, 14:24   #55
2fast4u's Avatar
in addition be in the right gear.
2fast4u is offline
Old 11th November 2007, 03:13   #56
oversteer's Avatar
Default Say What?
Very interesting... Could someone throw more light on this (or point me to the right post) please?
I mean... I'm going, I turn, touch the brake pedal with my left foot, and I'm assuming counter-balance the throttle with my right foot... but in order to achieve what, exactly? I mean, how do I get the car to "drift" and brakes not to "burn"? (Disclaimer: I'm not being sarcy here, just curious!)
I second that. You get fantastic feedback from the car, unpolluted by "electronic noise" (from the EPS etc)
oversteer is offline
Old 11th November 2007, 12:17   #57
hyper123's Avatar
check this out.
Autocar UK:
hyper123 is offline
Old 11th November 2007, 21:11   #58
oversteer's Avatar
Thanks, hyper123. Makes sense now!
This raises another interesting point, though: differentials. Are the differentials in RWDs and FWDs typically different, in a way that would allow the driver to distinguish one from the other?
Old 11th November 2007, 22:55   #59
Thanked: 253 Times
No. They cannot be. Laws of physics dictate that part.
anupmathur is offline
Old 11th November 2007, 23:00   #60
v1p3r's Avatar
Thanked: 27 Times
The connection between the diff and the wheels differs from FWDs to RWDs though.
v1p3r is offline
Closed Thread
FWD climbed a hill but RWD failed. Reason ? mithun Technical Stuff 29 13th April 2015 20:09
RWD, FWD, AWD-what would you choose? nitroxx Shifting gears 38 30th April 2010 13:41
converting a FWD to a RWD....POSSIBLE? twister Technical Stuff 21 27th April 2006 03:05
