Old 12th November 2007, 11:46   #1
Default Dent on the body - Will the paint peel off if I repair it?
I was in Jog Falls last weekend, after an enjoyable ride in my Palio Stile.
After returning from Jog, I noticed a small dent on the left side of the bonnet. It was not there before. Probably something should have hit the car while it was parked. But there is no mark of any sharp object having touched it as the paint is intact and there is not even a scratch on it. It appears as if somebody has hit it with a rubber hammer. The dent is visible from the side when light gets reflected from it.
Now the question is , should I ask the service centre to tinker it and bring it back to original shape? Will the paint come off if the part is tinkered? Will it make it necessary to repaint that part or should I simply accept and leave the dent as a memento from Jog?
ankura12 is offline   Reply With Quote
Old 12th November 2007, 13:05   #2
Thanked: 244 Times
A picture of the dent would have definitely helped here.
Depends upon the intensity and depth of the dent. If its small, leave it, dont fiddle.
If its slightly bigger, check if the paint has develped any small superficial cracks, if yes, paint will chip off upon removal, if not, it might not, but depends on the depth of the dent, sometimes it chips off while removal, so you have to mentally prepared for it.
Old 12th November 2007, 13:20   #3
bottle's Avatar
Thanked: 133 Times
could it be from someone pressing the bonnet closed ? cause my car has a dent on the bonnet as well and i feel thats why it happened
bottle is offline   Reply With Quote
Old 12th November 2007, 13:29   #4
kpzen's Avatar
Thanked: 1,599 Times
Please post a pic of it..
From what u are saying i feel it should be left as it is. The best u can do is get the dent removed by the dry denting process in which your original paint will remain intact.
Its a F I A T
kpzen is online now   Reply With Quote
Old 12th November 2007, 15:11   #5
snaronikar's Avatar
Thanked: 23 Times
I feel some fruit/branch might have fallen on your car. The same thng happened to my Ikon. I had stopped the car under a coconut tree and a coconut had fallen on the car roof and there is a dent now-no scratches on the dented portion and the paint is intact. I have left it alone, if I try to do some thing, I may end up messing the whole thing. Well this is my experience.
snaronikar is offline   Reply With Quote
Old 12th November 2007, 15:36   #6
ramki067's Avatar
Thanked: 25 Times
sorry to hijack this thread ankura12. As this topic is almost same to mine i choose to do so.
Firstly as i'm still a novice to driving, today as i took my baby to rounds, as i was leaving the petrol bunk and taking a left to join the road,i was seeing right hand side for traffic and as i took the left turn their was an electric pole to the left of the car which just touched my baby and caused a skreeeeeeek!!!! God, i stopped the car and went to look and their were three scratches on the left front and rear doors, the scratches were felt when i touched them. Is their any solution.
RAmki.
ramki067 is offline   Reply With Quote
Old 12th November 2007, 15:49   #7
kousik's Avatar
Thanked: 36 Times
Originally Posted by ramki067 View Post
... and their were three scratches on the left front and rear doors, the scratches were felt when i touched them. Is their any solution.
For scratch removal, see http://www.team-bhp.com/forum/modifi...s-removal.html (Scratch(writings) removal?)
kousik is offline   Reply With Quote
Old 12th November 2007, 16:23   #8
DirtyDan's Avatar
Thanked: 745 Times
Default Save them up
"All phenomena are appearances only." -Samkara, Hindu sadhu
"All phenomena are ephemeral and totally dependent on each other"
-Nagarjuna, Buddhist sadhu
"Set thee not up wordly treasures." -Jesus, Christian sadhu
"Dents? You have to mentally prepared for it." -Dadu, Bhp sadhu
What I do is try to save up my scratches, dents and dings and then periodically take the vehicle to a shop and get them all fixed at one time.
-DirtyDan Bhp twit
Old 12th November 2007, 16:29   #9
androdev's Avatar
Thanked: 1,728 Times
What I do is try to save up my scratches, dents and dings and then rationalize myself into thinking "why sweat for this piece of s***" and it works nicely.
androdev is online now   Reply With Quote
Old 15th January 2008, 10:01   #10
arunkumar_rec's Avatar
It is tough mentally for some time. Seeing the dent/scratch for some more time will make you get used to it.....
arunkumar_rec is offline   Reply With Quote
Old 15th January 2008, 10:16   #11
deep_bang's Avatar
Thanked: 291 Times
I had a similar problem. There were 2 small scratches within 2 months of buying my car. Not deep, but visible from a short distance.
I had once parked my car (still remember it was my son's naming ceremony) somewhere, and i come back and see a garbage trolley resting against my car :(. I was shocked. A small dent and a few scratches. I no longer worried about the first 2 small scratches. I had a bigger problem here.
Then there was another bigger dent (5cms dia). I am no longer worried about all of them now.
deep_bang is offline   Reply With Quote
Old 16th January 2008, 11:15   #12
rider60's Avatar
Thanked: 47 Times
well it does pain to see all the dents and the scratches, so every year in December i make it a point to get the dents removed and the scratches painted or the touch up work done!
just save up all the dents for the year's end and just get them fixed or just ignore them!, not a big deal, and we just cant help the impatient two and three wheelers and incidents mentioned above!
rider60 is offline   Reply With Quote
Old 16th January 2008, 11:55   #13
snaronikar's Avatar
Thanked: 23 Times
@ rider: Same here. I follow the same thing. Look, how our ideas meet within the team-BHP.
Old 16th January 2008, 12:21   #14
sfilinto's Avatar
there was a thread on using dry ice to remove dents. not sure if this actually works but do go throught it.
http://www.team-bhp.com/forum/techni...-you-know.html (Fixing small dents - a secret that garage owners would not like you to know)
sfilinto is offline   Reply With Quote
Old 16th January 2008, 12:59   #15
yes the dent can be removed to some extent without damaging the paint . they have special tools for repairing these dents. i got a dent removed on my car without damaging the paint. but one thing that the denter told me that it can be only possible if the paint is stock otherwise if car has been repainted than paint will peel off.
harry2223 is offline   Reply With Quote
Body Repair & Painting, Glass Repair, Detailing etc. - Trend Automobiles (Bangalore) decode Bangalore 278 9th November 2017 00:44
Exterior work: Paint, Dent, Polish - Mazda Motors (Tardeo, Mumbai) Sahil Mumbai 13 7th July 2017 17:35
A Fiat 500 Abarth made from human body & body paint dharmeshmahajan The International Automotive Scene 5 25th October 2013 14:47
The Peel Car. And Jeremy in it! GTO The International Automotive Scene 22 22nd November 2007 19:52
