Old 19th November 2007, 22:20   #16
ported_head's Avatar
Fight with them, it's under 5k kms, so you can still fight for defective clutch. Even though you ride your clutch.
Also, only clutch plate is not covered under warranty. All other components such as pressure plate, cable, thrust bearings are covered under warranty.
ported_head is offline   Reply With Quote
Old 20th November 2007, 01:06   #17
blue2ki's Avatar
my esteem clutch plate got fried too but @ 60k kms, got new 1's couple of days back...
heres a pic of the old 1..
you need to fight fight with them maruti guys. i dint know that the clutch plate is not covered under warranty.. u should sue them too.. get some heavy punitive damages from them.
blue2ki is offline   Reply With Quote
Old 26th November 2007, 18:04   #18
ad75's Avatar
Thanked: 20 Times
Default Update
Gave the car to Bimal today. 2nd service + clutch issue.
Just got a call from them.they will be replacing the whole clutch assembly, under warranty .they said there was some fault.
will get the details tommorow when i go to pick the car.
ad75 is offline   Reply With Quote
Old 26th November 2007, 19:19   #19
Thad E Ginathom's Avatar
Thanked: 8,378 Times
Congratulations!
If it was a new, badly-taught driver, it just might be possible it is their fault--- but you have the experience of making a clutch last a long time. It is jsut so unlikely to have been your driving causing the problem.
Old 28th November 2007, 12:07   #20
ad75's Avatar
Thanked: 20 Times
Smile
got the car yesterday evening.clutch feels good.
they have changed the clutch assembly & the cable.
Originally Posted by ad75 View Post
the gearbox oil was also filled 200ml.
there was a leak from the left drive shaft.the seal had broken.they have replaced it under warranty.
Did not press the clutch while down shifting :( Adithya BG Technical Stuff 29 14th March 2018 14:23
can a battery short circuit in Gypsy fry the Clutch ? abheekg 4x4 Technical 8 31st March 2010 19:07
Beijing menu: scorpion fry, seahorse kebab mjothi Shifting gears 59 21st August 2008 13:25
My Esteem did not start today bhogalrajnish Technical Stuff 9 26th October 2006 23:51
wet clutch vs dry clutch and slippers clutches devsus Motorbikes 7 16th May 2006 10:08
