Old 14th November 2007, 13:05   #1
~ H O N D A ~'s Avatar
Thanked: 9 Times
Default Water Leakage in my OHC
Need you help again guys....
from past few days my OHC is getting water leakage ...
I donno wherez it comin from..
For first few days its was on the front passanger side.
then front and rear passanger side.
from last 3 days just drivers side is dry all the three sides are wet always...
Even if we try to remove water by cloth it keeps coming i cant locate the source.
The local garage guy tried to keep the AC ventilation open of the car open and pour a few buckets of water on the front windshield but he said its not from ac pipes nore is it coming from door.
can someone help...
~ H O N D A ~ is offline   Reply With Quote
Old 14th November 2007, 13:14   #2
Shan2nu's Avatar
Thanked: 89 Times
Check the windows, even if there's a slight gap between the glass and the rubber beading, water can seep in. Happened to my car once.
Shan2nu
Old 15th November 2007, 13:55   #3
Thanked: 9 Times
checked it...
its alrite...
its really pain in the *** yaar. whenever i open my car its like everything is covored with vapour..
Everything from steering, dashboard, glass everything it even smells bad.
Old 15th November 2007, 15:12   #4
check the windows and wind screen for leakage or even if the door rubbers are worn out it might seep in
malcolm is offline   Reply With Quote
Old 15th November 2007, 17:20   #5
mtnrajdeep's Avatar
Thanked: 101 Times
Check the AC drain pipe. Chances are it is loose and that water is dripping inside the car!
mtnrajdeep is offline   Reply With Quote
Old 15th November 2007, 18:06   #6
Thanked: 127 Times
exactly..check the ac drain pipes.
heavy_foot is offline   Reply With Quote
Old 15th November 2007, 18:23   #7
gbpscars's Avatar
Shan2nu
Shan2nu, Malcolm, your explanations will hold good only if it is raining. yeah? it has been dry for long in Mumbai.
~HONDA~,
your post is slightly vague to me.
- do you see water accumulate when your car is parked.
- if yes... then did you run the AC during the immediately previous drive?
- did you try driving long time without the AC on?
- did the mechanic check the AC drain pipe for any clogging / breakage / leakage
- by water on three locations that you have mentioned, do you mean stagnant water, wet and soaking carpet?
the only source of water that can enter the cabin is the AC drain pipe.
focus on that right from where the draining starts and till the point that it exits the cabin out of the firewall. you must be able to pinpoint the leak.
if you are getting a bad smell, then i assume this has been happening for quite long and it has been noticeable slowly and lately. yeah?
gbpscars is offline   Reply With Quote
Old 15th November 2007, 21:46   #8
Thanked: 9 Times
@gbpscars
its there from last 7-8 days
yes i use my car almost everyday with my ac on
Nope
Yes he checked it and said its ok...
(Maybe he didnt checked it properly!!!)
Completely soaked carpet, Just drivers side is still dry
Even i think it must be coming from ac pipe.
Old 15th November 2007, 21:55   #9
kpzen's Avatar
Thanked: 1,655 Times
HONDA
It has happened to me also once and the culprit was the AC drainiage pipe.
So please get it checked from another mechanic.
Old 15th November 2007, 22:49   #10
Jaggu's Avatar
Thanked: 8,686 Times
ac pipe as well as the drain hole at the evaporator box, that might be chocked with dirt and stuff.
Old 15th November 2007, 23:04   #11
Thanked: 9 Times
im off to delhi tomorrow i'll get it checked as soon as i come back.
Thanks alot for all the suggestions buddy.
Old 16th November 2007, 11:54   #12
dude to check go to a service center and tell them to was ur car with the water spray and u sit in the car ull know if the water is seeping from outside or its an internal ac leakage
Renault Duster: Water leakage on the floor carpet. EDIT, now Solved! woodcrawler Technical Stuff 176 3rd June 2015 16:40
Water leakage in Mercedes E350 (W212) sidharthg Technical Stuff 4 8th March 2015 10:56
OHC silencer leakage in Pondy! Fortuner71 Technical Stuff 5 14th August 2011 11:33
Water Leakage ~ H O N D A ~ Technical Stuff 20 4th October 2007 09:52
ohc power steering oil leakage vinodbijlani Technical Stuff 10 10th August 2006 17:22
