| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #3 (permalink) |
| Senior - BHPian | I would always prefer a CARB engine. But since all cars are MPFI now, we dont have a choice. Even in a MPFI car, I have understood that open loop or CARB type LPG installation is best.
__________________ *2006 Maruti Alto LXi - Closed Loop LPG kit - Disconnected now* *2003 HH Ambition* *1998 Yamaha RX135* |
| | #4 (permalink) |
| BHPian Join Date: Feb 2006 Location: New Delhi
| Less complications involved since Carb engines essentially don't have Sensors and ECU's, but some which do still do not Map the variations of Lamda O2 readings, Air Intake etc etc. But Def not recommended, neither Safe since the fuel supply is not electronically controlled, plus the Lack of O2 readings cannot say the mixture is Lean or Rich, Depends on Excessive Manual Tuning. However I have heard that Older Padmini and NE 118( Taxi's) running in Mumbai and Pune on Carb systems have LPG or CNG kits. MPFI engines better suited since the Sensor assist in Tuning the CNG-Air Ratio for a Lean MIX, Also in an MPFI Car the Emmulator shuts the MPFI System and Emmulates the Signal to the ECU-So Safety of only Gas or Only Petrol Modes. Closed loops are best,since they involve auto mapping the Lamda Readings and adjusting the CNG ratio based with a Stepper and Lamda ECU. Open Loop are Semi Automatic systems,which need periodic adjustments to control CNG Ratio.
__________________ " When was the last time, You did something for the first time " Last edited by wolfinstein : 14th November 2007 at 22:12. |
| | #5 (permalink) |
| Senior - BHPian Join Date: Jul 2007 Location: Out of coverage area
Infractions: 0/1 (3) | I only know from experience: m800 open loop cng (97 carb) indica xeta closed loop cng. (06 dec mpfi) m800 was a bullock cart on cng. xeta is just as peppy as normal - very little feeling that you're driving a "gas" vehicle! mpfi+lambda sensor is the way to go. |
| | #6 (permalink) |
| Newbie Join Date: Mar 2007 Location: Delhi
| Exactly phamilyman - I'm installed CNG in my newly purchased Wagon R (April 07) during September. The Kit is closed loop, and the car is behaving jus as normal as a petrol vehicle. Difficult to guess that it is running on gas....! for MPFI+Closed loop kit.
__________________ "It's darkest before the dawn..." |
| Thread Tools | |
Similar Threads | ||||
| MPFI or Carb? | raajks | Technical Stuff | 2 | 18th December 2007 19:43 |
| Carb/MPFI - Which is having longer engine life ? | mithun | Technical Stuff | 47 | 10th October 2007 01:58 |
| 99'ZEN carb to ZEN mpfi.... | Balram | Modifications & Accessories | 17 | 10th December 2006 08:04 |
| carb or mpfi? which gives more power? | iceman91 | Technical Stuff | 18 | 5th April 2005 10:48 |
| DO MPFI cars have CARB's | kakx | Technical Stuff | 9 | 25th April 2004 00:54 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459
