| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | guys am new to the honda family so dont know whether this problem is normal or its only with my vtec i have fitted a short shifter in my car but after a long drive the gear stick heat up a lot no the gear nob though the stick and also the glove compartment below my music system and ash tray and in front of the gear stick is also very heated up now is this normal with a vtec or is it a problem pls help!!! ![]() |
| | #5 (permalink) |
| Senior - BHPian | Though i dont own a vtec, i've never even heard of such a problem. Did you face this before u installed the short shifter? Could this be due to lack of oil in the gearbox?
__________________ A lil more work and she'll fly like a streamlined butterfly! :) |
| | #7 (permalink) |
| Newbie Join Date: Mar 2007 Location: Mumbai
| Hi Malcolm, I think you need to check whether your Catalytic converter (in silencer) is getting overheated. Usually if there unburned fuel coming out of the exhaust, due to misfiring or a rich mixture. The unburned fuel kind of afterburns inside the catalytic converter. This causes the silencer tunnel below your gearshift to heat up, and ineffect your grearshift is becoming hot. You can confirm this by looking below your car when the gearshift becomes hot, the silencer below that area sometimes becomes red hot. IMHO this is not a normal vtec problem. Also I dont think the gearbox is getting overheated. You can confirm the gearbox temp by opening the bonnet and measuring the temp on gearbox casing. |
| | #8 (permalink) |
| BHPian | this sounds abnormal to me too. i have this VTEC (all stock) since 18 months now and it is 7 years old. never have i felt it to be hot even if i touch the metal rod by pushing the leather sleeve down. i would say the max i have seen even in a hot summer is - warm.
__________________ ...looking forward to sit a few feet above mean road level and away from potholes... |
| | #10 (permalink) |
| BHPian Join Date: Jul 2007 Location: Dharamsala
| I would bet 2 rupees this is an exhaust problem. Maybe you are missing a heat shield or two. Maybe you have some damage underneath and the exhaust pipe has been pushed too close to a few things. Have somebody look at the exhaust and soon, you do not want to fool around and risk carbon monoxide poisoning in case it is also leaking. Might be the cat as Sss sugested above.
__________________ The only tyrant I accept in this world is the still voice within. -Gandhi |
| | #11 (permalink) |
| BHPian | Does the city use cables or linkages to connect the shifter with the Gearbox! If it uses cables, then there is no chance the heating of the stick is due to heating of the G'box! I think Sss is right!
__________________ Motorsport is the only 'REAL' sport.... all others are just Games! Aalap Patel '97 Zen '88 RD350 |
| | #12 (permalink) | ||
| BHPian Join Date: Mar 2006 Location: Phoenix, US
| Quote:
| Thread Tools | |
Similar Threads | ||||
| Wagon R Gear box problems | prashantk007 | Technical Stuff | 25 | 10th May 2008 08:32 |
| HELP...!!! Close-Ratio Gear BOX for RX 135 5spee | malvechaitanya | Motorbikes | 0 | 1st August 2007 11:15 |
| Gear lever play in OHC VTEC. | vishnuvijay | Technical Stuff | 9 | 21st July 2007 19:18 |
| Your choice of Gear Box: Tall or Short? | turbo_c | Technical Stuff | 37 | 23rd June 2007 03:06 |
| NHC-Vtec or OHC Vtec..which is a better buy? | sunith | Sedans | 4 | 2nd May 2006 21:25 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
