Old 18th November 2007, 11:52   #16
theMAG's Avatar
Thanked: 1,572 Times
Cutting off OE springs is part of a wider phenomenon of lack of awareness by people of changing the dynamics of a finely engineered system such as a car. Doing a bandaid job on any part will most likely not have desired results, albeit undesirable ones.
I would also feel going in for aftermarket well designed springs is the better option over chopping off OE springs.
Old 18th November 2007, 11:57   #17
2fast4u's Avatar
i have seen the low riders on Discovery - cant remember the name.
a low rider was being made and the new springs were cut to get the ride low. So if the person with tech knows about suspension then its easier to get it cut, grinding done and good job.
Its not DIY stuff
2fast4u is offline   Reply With Quote
Old 18th November 2007, 12:07   #18
kpzen's Avatar
Thanked: 1,655 Times
razor
U have mentioned that the spring(orange) in pic are Peddar spring.
What about the shocks inside it?? Are those OEM or peddars??
Old 18th November 2007, 12:54   #19
DirtyDan's Avatar
Thanked: 776 Times
Default Tyres?
How about low profile tyres as an alternative? Right away you get stiffer tyre sidewalls because there is not so much room to flex. Hence, less roll.
I am not sure any of this lowering is really a good idea in India with its strange roads. You might be doing a public service as a cow pie removal vehicle but I think this is a limited venue.
Old 18th November 2007, 13:15   #20
razor4077's Avatar
Thanked: 258 Times
razor
Those are Pedders Comfort Gas shocks, with VRD.
More details here:
Pedders Comfort Gas - The Unique Velocity Responsive Damping System - Pedders Suspension
razor4077 is offline   Reply With Quote
Old 18th November 2007, 14:06   #21
nitrous's Avatar
Thanked: 285 Times
Razor, Do give a detailed report on those peddars suspension U've got,if possible.
It'll help guys like karthik247 in choosing aftermarket suspension components.
Old 18th November 2007, 17:23   #22
razor4077's Avatar
Thanked: 258 Times
@nitrous: will do buddy.
phoenix is stuck in the garage at the moment. still a few teething problems. once she's up and running, i'll post a detailed report on everything, including the Pedders.
Here's my initial review, posted on another thread:
Originally Posted by razor4077 View Post
I've been driving Phoenix around for close to a week after getting the Pedders fitted. Here's my initial feedback on the Pedders mated to the PP2 tyres...
- They handle bad roads pretty well. Cal roads are in PATHETIC shape now, and I was expecting a very stiff ride with the Pedders and low profile tyres. But surprisingly, the ride's been pretty decent. Definitely a touch harsher than stock, but nothing too drastic.
- Had a chance to push the car around a near 360 deg bend today (the road is an exit from NH 6, going towards Cal). Maintained 100+ throughout without making any corrections to the wheel or stepping off the gas. Car stuck like glue to the tarmac. Could have pushed her more, but took it easy this first time... need more time to learn the limits of the car.
I have taken this exit in an Octy and an NHC Vtec previously, but was never able to maintain this high a speed throughout, and feel so comfortable about it. Kinda makes the investment of time, money and effort worth it
Old 18th November 2007, 23:30   #23
BlackPearl's Avatar
Thanked: 5,144 Times
Originally Posted by PatienceWins View Post
The worst Ground clearance I have experienced is on Lancer.
you should drive a Baleno once and I am sure you would love to take back your statement
BlackPearl is offline   Reply With Quote
Old 18th November 2007, 23:57   #24
Thanked: 17 Times
What would happen to Mr. Civic then? :
Old 19th November 2007, 00:04   #25
BlackPearl's Avatar
honestly did not know that civic's condition is that bad. in my car I have to literally ask people to get down if I confront a big hump . these things become so annoying when you are not travelling on the GQ. but the performance one the GQ lets you forget eerything else . hope its the same with the civic.
Old 19th November 2007, 00:11   #26
shuvc's Avatar
Thanked: 287 Times
But @BP, your car might have a slightly lower GC than stock balenos due to the FFE. The pipe seemed a bit low to me.
Old 19th November 2007, 00:13   #27
BlackPearl's Avatar
but the case was no different even before the FFE. yours might be better due to the 14 inchers.
Old 19th November 2007, 00:18   #28
razor4077's Avatar
Thanked: 258 Times
Doubt it... tyre height is roughly the same in both your cars. But yea, I have driven behind both the Blackpearl and the Silver Bullet... the pipe does seem a little lower in your ride. Dunno, maybe it's an illusion!
Old 19th November 2007, 11:26   #29
BlackPearl's Avatar
ok, tried to defend my FFE enough. now its time to get down and fix it since all of you are pointing fingers at it
Old 19th November 2007, 14:39   #30
nitrous's Avatar
Thanked: 285 Times
BP, drive over speedbumps at an angle of 45 degrees.
It'll help a lot. Try it!
Car buyers can expect lower prices DriverR The Indian Car Scene 9 25th April 2014 12:29
Want to lower your car insurance premium? Get Married! powertrain Indian Car Loans & Insurance 12 16th January 2013 14:57
Please suggest a new B+ car for me which gives max Lower Back seat support sameer551 Hatchbacks 20 28th November 2007 00:27
Car shudders in lower gear ajayclicks Technical Stuff 21 2nd April 2007 15:15
