Thread Tools
Old 18th November 2007, 13:11   #1 (permalink)
Default Santro Engine Missing Problem
my santro is december 2004, with around 36000 Kms on the ODO. the car has CNG fitted in it.
my problem is that the engine is giving missing problem on both CNG and PETROL from some time. especially when the car is idling the car vibrates like anything because of the missing. but once i start driving it drives without any problem. its also giving me less fe compared to when there was no missing problem.
can anyone suggest how to diagnose and rectify the problem.
coolmob is offline   Reply With Quote
Old 18th November 2007, 14:55   #2 (permalink)
1self's Avatar
Get your sparks, fuel filter, spark plug wires checked. See if you need a de-carb (depending on the quality of fuel). Better if an authorised Hyundai A.S.S. guy saw it.
__________________
I'm not into exotica & badges, just horsepower & handling!
1self is offline   Reply With Quote
Old 18th November 2007, 16:50   #3 (permalink)
Sam Kapasi's Avatar
Oh so your engine is still inside your car?? I thought someone stole the engine block or something.
Sheesh you car guys.
__________________
Live the YetiLife®
MA-DONNA! MA-DONNA! MA-DONNA!
Old 18th November 2007, 17:05   #4 (permalink)
wolfinstein's Avatar
In the Order
1) Check the Plugs(When was the last time you changed it, cleaned it)
2) Ignition Coil ( Things can fail,cause missing issues)
3) Check/Clean/Replace Air Filter Element
4) Throttle Cleaning
If the above don't solve the problem , then :
5) Visit The Hyundai Service Station get the Timing checked up and Ignition Coil Voltage using the ECU Scanner, This will help isolate Ignition Coil issues and Timing.
6) Visit the CNG Installer and check the Condition of the Diaphragm & Plunger(Inside the Reducer Unit-Its not a DIY and neither everybody's expertise go to the CNG Installer or a good CNG Technician), After a certain time these things get dirty and need servicing.
But since the problem is on Both Petrol and CNG, Its most likely Dirty or Damaged Plugs + Air Filter, Throttle.
Try solving using the solution, the last option is Preventive and good after a certain time of Usage.
__________________
" When was the last time, You did something for the first time "
wolfinstein is offline   Reply With Quote
Old 18th November 2007, 17:56   #5 (permalink)
1self's Avatar
Well written! How is the throttle responsible for this?
Originally Posted by wolfinstein View Post
In the Order
__________________
Old 19th November 2007, 07:09   #6 (permalink)
The throttle, after a certain period of time accumalates dust and gum deposits, since it takes in the Air coming from the Air filter Element,which still passes dust that sticks on to the Throttle body and Manifold- This causes variation in the throttle Positioning sensor and Idle Speed sensor module which gives inaccurate reading,vibrations and low pickup.
Depends on the conditions the car is being driven, for CNG Vehicles the CNG:AIR ratio needs to be lean and since it passes through the throttle,advisory range for cleaning is every 10,000 Km but sooner if such problems are faced.
__________________
Old 19th November 2007, 08:04   #7 (permalink)
DieselFan's Avatar
It might also be an ECU problem. take it to the nearest A.S.S. and get the issue diagnosed. Please do not suggest any solution to them but get the problem first identified and then they will fix it.
__________________
If you have not failed you have not tried enough.
Swift Diesel VDI - Feb '07 onwards
Santro LS- Mar '01-Feb '07(59000 KM) Sold.
DieselFan is offline   Reply With Quote
Thread Tools
Santro A/c problem kalaks2000 Technical Stuff 18 15th December 2007 11:18
Santro Problem nd81 Technical Stuff 13 24th September 2007 09:09
Engine Missing Problem in Santro - Please Help rareone Technical Stuff 29 15th July 2007 11:24
Indica V2 DLS missing problem tsk1979 Technical Stuff 7 4th January 2007 23:05
'MISSING' problem in LPG M-1000 slipstream Technical Stuff 2 7th September 2006 18:31
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446
