Thread Tools
Old 19th November 2007, 11:58   #1 (permalink)
BunnyPunia's Avatar
Default Speed calculator from ratios etc
I came across this - Wallace Racing - Calculate Speed for given RPM, Rear Gear Ratio and Trans Gear Ratio
Now, RPM : no issues
Tire diameter : Tyre + rim or only Rim? for eg, if a bus has a 295/80 R22.5 tyre, then total dia will be 63.5 inches right ( .80 x 295 + .80 x 295 ) mm - convert to inches + 22.5 in + 22.5
Gear ratio : If a bus' 6th ratio is 0.83, i will input .83 for this ?
Trans gear ratio : the specs of bus say the rear axle ratio is 4.1 : 1 (shall i write this?)
HELP..
I m talkin abt this bus - http://www.ceritamotors.com/ceritamo...d_brochure.pdf
BunnyPunia is offline   Reply With Quote
Old 19th November 2007, 12:09   #2 (permalink)
SRShrikanth's Avatar
Thumbs up
Thats one hellava find Bunny.
Am just getting used to auto calculations ( they are a lot doff from the P/E ratios used in Audit firms, I guess !!! )
How did you arrive at the 4.1 : 1 final calculation. Am working it our for an Indica Turbo DLG model, incase that helps my case.
Also, am assuming that this table can be used to caliberate the ideal running speads for the rpms.
If so..under what conditions and does engine power bear no influence here..??
Any clues, please.
__________________
Njoy the journey..... :-)
Destinations keep passing by.!!!!
SRShrikanth is offline   Reply With Quote
Old 19th November 2007, 13:34   #3 (permalink)
Shan2nu's Avatar
295 x .8 = 236mm = 9.291 inches
(9.29 x 2) + 22.5 = 41.08 inches (overall diameter).
Yes
Yes
Shan2nu
__________________
VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE
Shan2nu is online now   Reply With Quote
Old 19th November 2007, 13:36   #4 (permalink)
sbasak's Avatar
295/80 R22.5 => 2*295*0.8+25.4*22.5 = 1043.5 mm dia of wheel
If engine RPM 1000, then wheel RPM in 6th gear
1000*(1/4.1)*0.83 = 202
__________________
Life is a math which you need to solve without knowing the answer!
sbasak is offline   Reply With Quote
Old 19th November 2007, 13:44   #5 (permalink)
Shan2nu's Avatar
Is it 202 or 293.85rpm (18.39kmph)?
Shan2nu
__________________
Thread Tools
About Gear Ratios & their Relation to Tyre OD, Torque, Speed etc speedsatya Technical Stuff 90 8th April 2008 11:50
Tax Calculator (excel) required protege Shifting gears 4 30th July 2006 22:40
help reg gear ratios freakr Technical Stuff 18 19th April 2005 03:10
What are gear ratios? sridhar24 Technical Stuff 8 1st March 2005 19:38
Powered by vBulletin
