Old 23rd September 2008, 23:37   #136
shiva_cool87's Avatar
I dunno if this the right place,but still I'll go ahead with my questions !
Its been Exactly ONE year since I serviced my Indica petrol.Now that I have driven just 5k kms in a year,I may give it for a service this month.
I have to change the Engine oil , Last time the guy used Veedol Engine Oil and he told its the best and I'm sure that its not the best.Which OIL do u guys recommend ?(of course not Synthetic,coz I'm planning to go Synthetic after 25k).
Last time I changed the Gear box oil completely,shud I do it again?
Same with the Coolant,shud I change it completely ?
Brake Fluid ? PS oil ???
I see that my car emits Smoke now ! What shud I do ? Clean the Air Filter or change it ?
And what else shud I do ? Wheel Allignment ? What else ? Pls throw some light!
Off late I see a drop in mileage...
PS - I won't be doin it from Tata Service Center.
shiva_cool87 is offline   Reply With Quote
Old 23rd September 2008, 23:48   #137
iraghava's Avatar
Thanked: 154 Times
Your Petrol Indica emits smoke? What colour & under what conditions?
Old 24th September 2008, 00:13   #138
somewhat light Grey in color....only for a few minutes though !
Old 27th September 2008, 22:09   #139
sid_meyer's Avatar
Angry
I have a problem starting my Indica when the Engine is cold. When i start the car, it starts for while (a couple of seconds) the the engine dies. Then the engine starts only when the accelerator is pressed. Would appreciate if someone could help me out.
sid_meyer is offline   Reply With Quote
Old 27th September 2008, 22:51   #140
tsk1979's Avatar
Thanked: 15,683 Times
One or two glow plugs are gone, get them checked.
Most probably its one of the plugs.
I think you would also see lot of black smoke early morning, right?
To confirm this, before starting put hot water (around 70 degrees straight out of the geyser) on the injector area, then start and see if you get same issue.
Old 27th September 2008, 23:28   #141
sid_meyer's Avatar
Thumbs up
ok thanks. How much would a glow plug for Indica cost?
Old 28th September 2008, 11:47   #142
tsk1979's Avatar
I think around 300rs for Mico bosch, don't remember the exact amount. Do the water test first to determine its really the glow plugs and not something else
Old 28th September 2008, 11:52   #143
trrk's Avatar
Thanked: 12 Times
Hi sid_meyer,
Oct 2007: Rs 363 each. Would not have changed much. OEM is BERU, I think.
To check if glow plug is working, see the first part of the following message:
Yahoo! Groups
A cold starting tip when the glow plugs are working:
Yahoo! Groups
trrk is offline   Reply With Quote
Old 28th September 2008, 23:24   #144
tsk1979's Avatar
Yes 363 is the correct price. But I would recommend Bosch over Beru. MICO Bosch lasts longer, from personal experience
Old 29th September 2008, 13:06   #145
anonymous's Avatar
Thanked: 15 Times
Need help guys. My car has done 85K so far and I was told by TASS that the timing belt and gear box are running end of life and need to be replaced. How can we check the funtionality of these two things?
anonymous is offline   Reply With Quote
Old 29th September 2008, 13:17   #146
greenhorn's Avatar
Thanked: 1,421 Times
85k seems about right for a timing belt change. Even if it is functional now , it is better to change it, since the consequences of timing belt failure are catastrophic
Old 29th September 2008, 13:23   #147
tsk1979's Avatar
1. Get timing belt changed. Better safe than sorry.
2. Get clutch plates change if you have issues like judder etc., else you can go on for another 20K kms
But do get gear oil changed.
For other changes refer to owners manual. It clearly tells what should be changed when!
Old 29th September 2008, 16:11   #148
I haven't got any reply yet.
I'm asking u guys because I don't want the garage boys to decide wat to do and what not !
Old 13th October 2008, 17:12   #149
Marlon's Avatar
Thanked: 78 Times
Default Need suggestions for Xeta 1.2L - 5K Kms Olg
Friends,
Need couple of suggestions for the problems faced in my Xeta
  • I have a strange issue of Head Lights. The Left is Brighter & Powerful than the Right. I changed my Head Lights from Stock to Philips & am facing this problem since then. I tried with different sets of bulbs & different mechanics but no one is able to solve my problem.
  • Second, the milegae, I get only 9KM with 100% AC in City. Need Suggestions to improve on it
Also please suggest if I need to go for Paid Service. My 10K 2nd Free Service is Due in Feb '09.
Marlon
Marlon is offline   Reply With Quote
Old 13th October 2008, 20:19   #150
Sorry, I had not looked at this thread since most of the queries were for the diesel. Hope this is not too late.
How much has your car run so far? Who is this dealer who uses VEEDOL?
On a cold morning, I can see some smoke coming from my LSi's exhaust (BS-II) but nothing radically different from other cars (all makes / petrol models).
hrag is offline   Reply With Quote
Indica Vista - list of Known problems greenhorn Technical Stuff 1427 8th January 2018 02:11
Tata Manza - List Of Problems jkdas Technical Stuff 200 13th December 2017 22:41
Tata Indica Vista- Technical Specifications & Feature List Stratos Technical Stuff 2 24th June 2011 19:47
Tata Indica V2 DLS customized vs Tata Indica V2 DLX karikrishni Hatchbacks 20 12th November 2009 10:59
