Old 12th December 2008, 11:16   #211
rkavthekar's Avatar
Thanked: 7 Times
Originally Posted by trrk View Post
Please check your alternator. The voltage regulator is gone for sure.
Please don't take it to the TASC for this. Find a local Lucas TVS center for this.
The following is what I got off from the online directory:
020-27494684 CHINCHWAD LUCAS TVS LIMITED RES OF K P ACHUTAN RL 179 G BLOCK PMP CHDINDUSTRIAL AREACHINCHWAD 411019
020-26611419 PUNE LUCAS TVS LTD HERMIS HARITAGE-II H8-10/11OFF NAGAR ROADSHASTRINAGAR 411014
Lucas-TVS Contact Us
If the above does not help, ask an auto electrician and he would be able to direct you to a Lucas TVS centre.
Hope this helps!
Rajesh,
Thanks for your help and I appreciate you of going out of the way to find out Lucas TVS locations in Pune and passing on that information. Hats off to you.
I will take my car to Lucas TVS centre and post a response on the outcome of the same.
takecare and drive safely
rkavthekar is offline   Reply With Quote
Old 12th December 2008, 11:29   #212
nithinnarayanan's Avatar
The following is what I got from the Bangalore online directory. I assume this is what you wanted, anyway a phone call will settle it.
LUCAS INDIAN SERVICES,65/2,MILLERS ROAD,560 046 - 23536138
In case, the above is wrong, take a look at the following:
Thanks mate
Will get the service done and update.
I called the number but its says "The number has been shifted"
Will go to millers road and find out.
PS: Heard from one of the friends that the TVS service centre is in JC road somewhere. He is not sure about the exact location. Does anybody has any info on this ?
Nithin
nithinnarayanan is offline   Reply With Quote
Old 13th December 2008, 19:24   #213
trrk's Avatar
Originally Posted by rkavthekar View Post
Rajesh,
The pleasure is all mine. Sitting so far away, this is the least I could do. Unfortunately all the information are only pointers which could lead to more concrete information.
If it is of help, my day is done!
@nithin:
Originally Posted by nithinnarayanan View Post
Thanks mate
I am sorry that the info was not useful.
I need to organise my fact finding procedures in a better way.
trrk is offline   Reply With Quote
Old 19th December 2008, 10:37   #214
rkavthekar's Avatar
Thanked: 7 Times
[quote=trrk;1092175]Hi,
Rajesh,
I have given my Indica to Lucas TVS today. Should get it back by late afternoon. I will submit my report after the same
Takecare and drive safely
Old 19th December 2008, 12:42   #215
Lucas TVS service centre in Bangalore: (courtesy Mahesh Kale of TIUG)
Standard Auto Service, No. 8 Lalbagh road 080-2218376 (please check the number, there's one digit missing)
Enter LalBagh road from the Corporation side. It is One way from Siddhaiah Circle towards Lal Bagh. This Standard Auto shop is between a Yamaha showroom and Urvashi theatre on the right side.
hrag is offline   Reply With Quote
Old 19th December 2008, 17:37   #216
trrk's Avatar
The number is 22218376, courtesy online Bangalore phone directory!
Old 22nd December 2008, 12:03   #217
Thanks a lot Hrishi and Rajesh for your help.
BTW Hrishi any cost estimate for alternator+voltage regulator overhaul for Indica Turbo.
Old 22nd December 2008, 12:15   #218
trrk's Avatar
I am sure you won't mind the details coming from me!
Just click on the following links:
Yahoo! Groups
Yahoo! Groups
Hope this helps.
Old 23rd December 2008, 04:05   #219
deepclutch's Avatar
Thanked: 108 Times
Yesterday I bought a 2002 3rd month Indica DLE.everything seems fine.Engine Oil changed,Coolant filled .with a/c ,I feel a lack of power .Is it normal?Should I go for nozzle service ?There is a Pioneer System(ice) in the car.but it got deck.Can I get any system to use a usb mp3 player to give output to this deck's amplifier?instead of going for new ?
thanks.
deepclutch is offline   Reply With Quote
Old 23rd December 2008, 19:16   #220
trrk's Avatar
How much has it run? Any service history available?
With AC, DLE is a little underpowered.
Old 23rd December 2008, 22:30   #221
deepclutch's Avatar
Thanked: 108 Times
Post
Yes.service history is available(as in bills).It completed 117033kms(hence reset and shows 17033kms) ,when I bought it.was owned by a doc.Engine overhauling done(only piston rings changed ,but no sleeve work).
and Yes ,with A/C Indica are underpowered.
Old 23rd December 2008, 22:45   #222
greenhorn's Avatar
Thanked: 1,024 Times
welcome to this thread deepclutch. you ought to join the TIUG too
Old 23rd December 2008, 22:55   #223
adityamunshi's Avatar
The odometer resets after 10,00,000K and not 1,00,000K. Atleast thats the way it was in my DLE 2000.
adityamunshi is offline   Reply With Quote
Old 23rd December 2008, 23:08   #224
deepclutch's Avatar
Thanked: 108 Times
I dont think so.it is 1 lakh kms(100,000) when odo gets reset.correct me.and the guy who sold me sure said the same.He dont have any need to tell a lie.
still,
If it is wrong ,then possibility is they reset the odo manually after engine work?
@greenhorn:yes ,thanks.but already was driving another DLE too though not owned by me.know almost well ,what I can expect .I selected this car only for the reason of more space.No other car can satisfy it at this budget with superb mileage.
Old 24th December 2008, 06:55   #225
Whats the year of manufacture ?
still,
Indica Vista - list of Known problems greenhorn Technical Stuff 1418 20th June 2017 17:13
Tata Manza - List Of Problems jkdas Technical Stuff 188 4th January 2017 14:01
Tata Indica Vista- Technical Specifications & Feature List Stratos Technical Stuff 2 24th June 2011 19:47
Tata Indica V2 DLS customized vs Tata Indica V2 DLX karikrishni Hatchbacks 20 12th November 2009 10:59
