Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
Thread Tools
Old 20th November 2007, 20:52   #16 (permalink)
This is a bit anti-climax. I was looking for yet another "Indica - more complaint per complaint" thread. :-(
__________________
ɹǝʌıɹpʇɐǝsʞɔɐq
Old 21st November 2007, 10:44   #17 (permalink)
wolfinstein's Avatar
Same here I just love Mini Bread Box Threads too !!!
__________________
" When was the last time, You did something for the first time "
wolfinstein is offline   Reply With Quote
Old 24th November 2007, 12:28   #18 (permalink)
panky12345's Avatar
Default Cold Start Problem with my Indica - Pls Help!
lately my Indica has started giving me starting troubles in the cold mornings. my findings have been:
  • When I crank the engine (without pressing the accelator); it starts and then stops, whereas it wasn't the case in the summers.
  • The glow (heater) light have started taking considerably long to get off.
  • As soon as the car starts (with accelator), there's a sheer belt noise.
Any suggestions?
__________________
No signatures..
panky12345 is online now   Reply With Quote
Old 24th November 2007, 13:32   #19 (permalink)
gd1418's Avatar
One of the glow plugs is malfunctioning. Get the belsts tightened. Check first if they are frayed etc..
What's the battery condition. Normally if the battery is nearing its end, it starts giving a lot of problem in winters; weak current etc..
Originally Posted by panky12345 View Post
Any suggestions?
__________________
Royal Enfield Bullet 1962
All Black 1998 Safari 4x4
All Black 2004 Scorpio GLx
Old 26th November 2007, 11:46   #20 (permalink)
panky12345's Avatar
Thanks GD bhai, any inputs as to whether replacing glowplugs is a time-consuming process involving visit to mechanic or DIY?
__________________
No signatures..
Old 26th November 2007, 12:03   #21 (permalink)
kkr2k2's Avatar
it happened to us this season,
all the 4 heater plugs went kaput. We have a 2003 Indica V2 Dls.
Total cost 1350/-
took to a mechanic, he took 3 hours to do to them. Oh!, he didnt have them in his stock, he had to get them first and replace. I dont think its DIY. But if you are serious DIYer, may be you can do it yourself.
raj.
__________________
....HINDUISM
........JAINISM
.......BUDDHISM
......SIKHISM
........ISLAM
CHIRSTIANITY
kkr2k2 is offline   Reply With Quote
Old 26th November 2007, 14:00   #22 (permalink)
anonymous's Avatar
http://www.team-bhp.com/forum/techni...-problems.html (Tata Indica - List Of Problems)
Hope this helps.
anonymous is offline   Reply With Quote
Old 26th November 2007, 14:05   #23 (permalink)
tsk1979's Avatar
I got the glow plugs on my indica day before yesterday.
2 out of 4 had gone. Got MICO-Bosch plugs, 540 a pair.
As for belt, don't get it tightened blindly. Over tight belt means alternator bearing damage which means belt snapping and expensive alternator repair.
Slight screeching is okay. Only if you get screeching all the time you should get it tightened. If it screeches only in morning, ignore it.
If you don't get it fixed and your car refuses to start pour boiling water on injectors.
Thats what I did
on saturday morning. The car refused to start. 1.5 liters of boiling water on the injectors fixed the problem.
__________________
Reclaimed, wrung dry and recycled....!
Old 26th November 2007, 14:12   #24 (permalink)
kkr2k2's Avatar
thats low, considering i paid 1350/- for two pairs.
Thats what I did
DIY????
good idea, i thought cool water helps cooling down the hot engine.
Now, hot water to wake up the cold engine. Will keep this in mind.
raj.
__________________
....HINDUISM
........JAINISM
.......BUDDHISM
......SIKHISM
........ISLAM
CHIRSTIANITY
Old 26th November 2007, 14:21   #25 (permalink)
tsk1979's Avatar
thats because you went to Tata. The glow plugs you got were not Bosch, they were Behru or something like that(Tata OEM) and are cheaper than Bosch(I think 400 a pair)
DIY????
raj.
Never put cold water on an overheated engine. Quenching a red hot block can lead to cracks and subsequent engine failure.
__________________
Old 26th November 2007, 14:23   #26 (permalink)
kph
kph's Avatar
Do it yourself if you have a good T spanner.
PS: Buy only branded plugs. Other ones will not give proper heating and may get kaput soon and most importantly when you have to change it next time the neck will break and you will end up removing the engine head and will have to remove it at some lathe.
__________________
ridelogs.blogspot.com
kph is offline   Reply With Quote
Old 26th November 2007, 14:23   #27 (permalink)
Please don't ever pour cold water on a hot engine. You might be looking at a very expensive repair bill!
anupmathur is online now   Reply With Quote
Old 26th November 2007, 14:29   #28 (permalink)
tsk1979's Avatar
Any roadside guy should be able to do it. Takes 10 minutes.
first you take out all the glow plugs.
Connect directly to battery and see whether there is a wisp of smoke from the diesel soaked end(Do not touch, very hot).
After identifying which went kaput, you get the appropriate number.
If you have never done the DIY, don't. Give 50rs to a roadside guy. He will tell you which plugs have gone. Since your car starts eventually, I presume either 1 or 2 are gone.
__________________
Old 26th November 2007, 14:38   #29 (permalink)
kkr2k2's Avatar
nope, went to a regular mechanic.
No way, it was just a joke. I am not going to try pouring hot water as well.
I would rather push start the engine.
raj.
__________________
....HINDUISM
........JAINISM
.......BUDDHISM
......SIKHISM
........ISLAM
CHIRSTIANITY
Old 26th November 2007, 14:42   #30 (permalink)
tsk1979's Avatar
raj.
Push start works when your battery is too weak to start the engine or your starter motor goes kaput. when your engine is cold and your glow plugs are not working, push start will not help. Infact repeatedly cranking the engine and pushstart will flood the engine with diesel and may make starting even more difficult.
Putting water at around 70 degree C(what you get out of the home geyser) is not going to cause any damage.
__________________
Thread Tools
Indica Vista - list of Known problems greenhorn Technical Stuff 324 13th November 2009 15:06
Tata Indica V2 DLS customized vs Tata Indica V2 DLX karikrishni Hatchbacks 20 12th November 2009 10:59
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
