Old 11th June 2009, 16:45   #361
svsantosh's Avatar
Thanked: 1,252 Times
Hi Tanveer, Greenhorn, Rajesh K(pune), Rajesh (Allepy)...& all,
I got the car back from its 30K service routine (@26K Kms).
The issue has been solved. I was told the alternator assy was sent to Lucas and Repaired and refixed. Driven about 30Kms to work and no issues so far. I will keep you guys posted if it resurfaces.
-----------EDIT---------------
Tanveer, I was cribbing that I was still getting a 14.3 - 14.4 reading after the so-called lucas service. Now I understand that its normal to go MAX @ 14.4. Thanks for the input...
OT - the car rocks & feels as if it is buttered after the oil change. Total bill 2699Rs, Includes Oil, oil filter, diesel filter, 5wheel balancing/alignment. + 500Rs Bardhal oil additive.
svsantosh is offline   Reply With Quote
Old 11th June 2009, 17:31   #362
trrk's Avatar
Originally Posted by bonnetsup View Post
What is the cost invovled in a thorough pump job?
Take a look at the following message:
Yahoo! Groups
I hope this gives you a fairly accurate picture of what all was involved.
The pricing given by tsk1979 is pretty accurate.
trrk is offline   Reply With Quote
Old 12th June 2009, 16:39   #363
Thanks doc,tsk n trrk.
Is it common to get a fuel pump overhaul done as early as 20k on the odo?Is there any chance that there's some other culprit?Just wanna make sure before getting the fuel pump redone.
bonnetsup is offline   Reply With Quote
Old 12th June 2009, 17:27   #364
greenhorn's Avatar
Thanked: 1,024 Times
FIP overhauls arent done a lot. its kinda like an engine overhaul - usually done only once or twice during the lifetime of the FIP
greenhorn is online now   Reply With Quote
Old 12th June 2009, 17:34   #365
deepclutch's Avatar
Thanked: 108 Times
My Indica is still in the workshop.a great amount of works going on.Engine returned(Engine rebuilt by Engine "Specialists" near to my place) after overhaul- cost 15K.Now ,the delay is due to repair the underside shell which has rusted beyond imagination :( .Indeed ,the guys there(not a TASC) are doing a good job.
deepclutch is offline   Reply With Quote
Old 12th June 2009, 18:02   #366
trrk's Avatar
Got it checked in my Indica at 53175kms and I have paid Rs 1365 at that time (approx 10/03/2004). i have marked it as calibration and repair, but don't have much of details. No pump work in my Sumo (55000kms) or Safari (76000kms).
There are some jerks felt at certain RPMs in the Marina. I ma not yet sure whether it is worthwhile to have the pump shown right now.
Old 15th June 2009, 10:05   #367
joecherian's Avatar
Thanked: 78 Times
My friend's indica was recently been to the service station and there, the mechanics told,a very small sound is coming from the wheel and that bearings has to be replaced.. Now, since the sound is very low, my friend has deferred the decision to replace the bearing, but, when he told me the same, was not sure how critical this is and hence thought will ask the experts. How critical is this bearing noise (can the replacement be deferred till the sound starts bothering you ) and what are the spares cost ?
joecherian is offline   Reply With Quote
Old 15th June 2009, 12:33   #368
tsk1979's Avatar
Thanked: 15,359 Times
your friend can wait till the sound increases. Infact I suggest wait till end of monsoon. After monsoon the noise will increase quite a bit, as water wading takes it toll. In BLR my route meant water wading almost every day, and after every monsoon season I needed new bearings!
Old 16th June 2009, 14:51   #369
Thanked: 15 Times
Default Weird problem
Have been facing a weird problem in my Indica lately.
She has suddenly become a powerful beast, yeah I know, this is all contrary to my earlier posts. may be its the effoect of my earlier posts.
The car suddenly seems churn up significantly more power 3rd gear upward, any gusses?
There is one probem though, there is suddenly some starting trouble. the car starts easily (has a new battery) but then dies down, as if the diesel supply has been shut down.
Then there is a lot of RPM oscillations once the car has started, the RPM stabilizes only after the car runs for @2-3 KM.
Please help me with the probable causes and solutions?
Last edited by Jaggu : 16th June 2009 at 14:59. Reason: Please avoid... typing... like this... Thanks
Ferrari1976 is offline   Reply With Quote
Old 25th June 2009, 12:31   #370
joecherian's Avatar
Thanked: 78 Times
Thanks tsk. Meanwhile, my friend has decided to go ahead and replace the bearings. he has decided to get it done out of TASC and when he enquired with SKF bearing dealer, for front and rear wheel bearing, the dealer , it seems, has asked whether for rear bearing, he needs single or double. My friend responded that it is for left rear wheel, still he was asked, for the rear left itself,do you need single or double bearing.
Now, is there some thing like, rear wheels have 2 bearings ? What exactly does the dealer mean here ? I was under the assumption that each wheel has one bearing and only it has to be replaced. Can anyone throw some light in to this ?
Old 25th June 2009, 12:38   #371
tsk1979's Avatar
Actually its inner bearing and outer bearing.
The mechanic has to open up the bearings and see if the inner bearings are gone, or outer bearings.Normally inner bearings last longer than outer ones(personal experience)
Old 25th June 2009, 12:50   #372
joecherian's Avatar
Thanked: 78 Times
that is something new to me.Thanks for the info. So, is this inner and outer bearing present only in rear wheels and not in front wheels?
Old 25th June 2009, 13:05   #373
Thanked: 48 Times
my indica (non-turbo) also feels kinda powerful lately - I would say the last 5-8k kms or so. Not sure of the reason, though - have been getting only the regular service done.
the cold start in the mornings tends to lower the rpm slightly. this happens the moment i crank the engine - it hits the 1k mark, drops to 800 when I suddenly get a feeling that the engine might die down any moment, but then it comes back to life! i have observed this only over the last couple of months, when i had not used the car much for close to 4 months due to travel. but after 2-3 minutes of idling, i usually start driving and face no issues of this sort
royalcruiser is offline   Reply With Quote
Old 25th June 2009, 13:14   #374
tsk1979's Avatar
IIRC, for front also there are inner and outer bearings
This is normal. Indica idle is pretty erratic when its very cold.
However if its too much it means one of the 4 glowplugs are gone. When all more than 2 glow plugs go bad, you car will give starting trouble at cold start.
Old 25th June 2009, 13:50   #375
Thanked: 15 Times
Found the problem in my car and got it resolved. There was a leakage in the diesel pipe, small enough to ensure that not too much diesel was lost, but big enough to introduce air at the start. This was causing the RPM oscillations and the sudden power effect.
My car is now back to normal, hopefully for a long time now.
Indica Vista - list of Known problems greenhorn Technical Stuff 1418 20th June 2017 17:13
Tata Manza - List Of Problems jkdas Technical Stuff 188 4th January 2017 14:01
Tata Indica Vista- Technical Specifications & Feature List Stratos Technical Stuff 2 24th June 2011 19:47
Tata Indica V2 DLS customized vs Tata Indica V2 DLX karikrishni Hatchbacks 20 12th November 2009 10:59
