| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #31 (permalink) |
| Senior - BHPian Join Date: Mar 2006 Location: New Delhi
Infractions: 0/1 (4) | Thanks everyone for the replies! Tanveer: The Belt screaming is normally in the mornings or after long "rest" times only. However, I get a feeling that a tic-tic sound from the belt is persistent. I went to a local guy who greased the belt. It stays Ok for couple of hours and then the same problem. Also, there is a LOT of smoke in the morning when I start.
__________________ SINGH IS KINNNNNNNG.. |
| | #32 (permalink) |
| BHPian | hmmm. . . prior to change the heater plugs, to go to the mechanic i started the car by pushing. i did not face any problem that way.
__________________ kkr, unofficial hyd tbhp meet co-ordinator ....HINDUISM ........JAINISM .......BUDDHISM ......SIKHISM ........ISLAM CHIRSTIANITY |
| | #33 (permalink) | |
| Team-BHP Support ![]() | Quote:
As for greasing the belt, I suggest you stay away from the local guy. Greasing the belt will take care of screeching sound but will make your belt slip even more! Belt slipping will not cause a tic tic sound, unless the belt is frayed.
__________________ Reclaiming.....! | |
| | #34 (permalink) |
Infractions: 0/1 (4) | I think I'll go in for changing the belt and glow plugs. Any idea what the belt is called? Also, any good brands for belt and glow plugs?
| | #35 (permalink) | |
Normally the belt lasts around 40K kms. When was the last time the belt was changed in your case? For Glow plugs, try to source MICO-Bosch plugs. The Behru ones which TASC puts in have never lasted me beyond 25K kms.
| | #37 (permalink) |
| BHPian Join Date: May 2007 Location: Baroda
| I had the same problem with the belt screeching in the morning, got it changed and it hasnt improved by much.
__________________ And Michael Schumacher is actually in a very good position to win the race. He is in last place. - Murray Walker |
| | #38 (permalink) |
| I have a problem with the right rear window. It rattles everytime I hit a pothole. I've even had it fixed twice but the problem resurfaces after a few months and is really irritating. What would be a good place to have this fixed ? Or is it possible to do it myself ?
| | #40 (permalink) |
| Team-BHP Support ![]() Join Date: Oct 2005 Location: Hyderabad
| Behru?!! Lol... I think you guys are referring to Behr India. I do not know the make of the glow plugs but otherwise Tata sources a lot many components from them. Behr is a german multinational and is a OEM for world reknowned brands. Behr's India venture also exports to the Behr's international clientele. In India they also supply to Volvo, MAN and many other such reputed names. So Behr is certainly no pushover... At least not enough to be called Behru ![]() |
| | #43 (permalink) |
| Team-BHP Support ![]() | Bearings make a humming noise. Alternator bearing is lubricated by engine oil, so if it runs dry your engine will seize first. As for other problematic bearings, apart from the wheel ones, its the Subros compressor bearing. When that goes overhaul costs 7500rs and it works for just 20-30K kms atmost. Its better to get a new compressor which costs 9.5K in the open market As for belt noise(AC, PS, Alternator have a common belt) do not get it fully tightened. It will take care of noise completely but kill the alternator bearing.
| Thread Tools | |
Similar Threads | ||||
| Tata launches New Indica, Indigo CS, Indica V2 DICOR, Sumo Grande, Xenon. Details.... | ashutoshb | The Indian Car Scene!! | 100 | 22nd June 2008 14:56 |
| GT5 potential car list!! (Tata, Mahindra, DC, Etc!!) | Shan2nu | Shifting gears | 14 | 20th May 2008 13:49 |
| Starting problems Indica DLG | vfmanuel | Technical Stuff | 19 | 13th December 2007 23:09 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
