Old 10th August 2009, 16:18   #436
joecherian's Avatar
Thanked: 78 Times
Now that the brake issue has been resolved,another brake issue seems to be creeping in. When trying to brake, I hear a small whistling/rubbing sound from the rear wheel (probably from the left rear wheel). The brake cylinders for the left rear was replaced last month and right rear was replaced last week.
Any idea what might be the culprit ? For resolving my earlier brake issue, Manipal mechanics has checked all the four wheels (brake linings, discs, calipers etc) and has found no fault with them.
joecherian is offline   Reply With Quote
Old 22nd August 2009, 15:42   #437
IndrojitSircar's Avatar
Thanked: 113 Times
Default Tata Indica Xeta starting problem
Hi everyone
My friend has a Tata Indica Xeta which has done 21,500 kms.This car has a CNG kit in it.This car gives trouble while starting every day in the morning.The car is started on petrol and then changed over to CNG.It take a good 15-20mins starting and then after that you shut off and start again no prblem at all.The car works alright after that.This problem has been there for a long time.He has taken it to the TATA service stations where they conected a comnputer to the ECU board of the car and they removed errors as they say.After that it was ok for 15 days and then it starts again.Was wondering if anyone is facing the same problem with their car.I think there is something wrong with the ECU board of this car.
Mods- please move this thread to the appropriate section.Didn't find the technical part.
Old 2nd September 2009, 00:14   #438
kcj3b's Avatar
Thanked: 55 Times
hi,
small issue which is bugging me n eating my tyre.
My whell alignment/balancing in perfect for a V2 DLS clocked 42k but the left rear tyre is being eaten from inner side.
What can be the issue?
kcj3b is offline   Reply With Quote
Old 2nd September 2009, 11:45   #439
rkavthekar's Avatar
Thanked: 7 Times
Originally Posted by junniaga View Post
hi,
Check the hub bearing.
takecare and drive safely
rkavthekar is offline   Reply With Quote
Old 2nd September 2009, 12:23   #440
jav
hi,
Can also be a weak shock absorber.
jav is offline   Reply With Quote
Old 2nd September 2009, 13:17   #441
SRShrikanth's Avatar
Thumbs up
On my V2 DLG, for the last two days am hearing a 'krrrr' sound on turning my steering full.
Have never heard this before and hence am a bit confused.
The V2 DLG has done 43K kms now and hence a query here.
Inputs welcome.
SRShrikanth is offline   Reply With Quote
Old 6th September 2009, 23:40   #442
kcj3b's Avatar
Thanked: 55 Times
I hav to meet my mech on Tuesday fulltime for all the issues, needless to say srinagar has the worst Dealership workshop so need to rely on local mechs, although mine does a grt job.
ON 42k i plan to :
Oil/filter, Diesel filter change
4 wheel Bearing Check
4 Wheel Brake lining chnge
Will check Transaxle oil too same goes for the PS oil
Glow plug check (Winter special)
I am still looking for the Noise dampner cover for the engine though
Also anyone has any ides if i can install the rear wind screen defogger as chilly winters are comming on quick
Old 7th September 2009, 00:06   #443
greenhorn's Avatar
Thanked: 1,436 Times
do check the brake fluid too.
the rear defogger should be possible, but apart from the glass and the wiring , you'll have some plastic bits to add where the contact is made, along with the rear parcel tray
greenhorn is online now   Reply With Quote
Old 7th September 2009, 11:27   #444
SS-Traveller's Avatar
Thanked: 10,967 Times
Problem with the power steering pump - bearing damage or chipped pump vanes. Check if the power steering fluid is topped up or not. If yes, then till the pump is opened and checked, try not to take the steering to full lock on either side and cause that sound to come.
Old 8th September 2009, 22:55   #445
kcj3b's Avatar
Thanked: 55 Times
ON 42k i plan to :
ok Today was th day at the Garage, heres what was done there:
Oil Change with filter
4 wheel check took us to changing a complete bad rear outer (small) Bearing which was the Tyre eater culprit!
Rear Brake pads were as good as new.
Front bearings were all fine although Disc pads were changed which looked worn out.
Gear Oil was just fine so was PS oil .
Although there is no Engine oil leak we are tracking a small leak which seems to be either PS oil or Gear oil.
The car is breathing a new life at 43539 now, i enjoyed the drive yet again.
Old 9th September 2009, 14:13   #446
Spot-on SS.
The culprit was the presence of very little steering fluid that I topped up immediately.
All's well and smooth now. Back to the grind.
Appreciate the immediate response as well.
Cheers.
Old 9th September 2009, 16:04   #447
adityamunshi's Avatar
Normally PS fluid doesnt need to be topped up. You need to keep checking it regularly and look for possible leaks in and around the reservoir, pipes and the rack oil seals.
Spot-on SS.
Cheers.
adityamunshi is offline   Reply With Quote
Old 9th September 2009, 16:33   #448
I agree Aditya.
My old war-horse ( NA Indica DLX ) at 103K kms had a leaking joint issue for the PS at 88K kms. But then, I did not get any irritating sounds that trigerred my query, only a gradual drop of oil from the pipe joint that got noticed.
Here in my V2 now, am positively going to keep a check on any leaks for this issue.
Old 9th September 2009, 17:59   #449
greenhorn's Avatar
power steering is an achilles heel. its placed at a vulnerable place, and the seals etc can be damaged by rocks etc or other impact on the underbody
Old 9th September 2009, 18:10   #450
My DLS 2004 (82K) had a leak from the oil seal and i was stupid enough to get it done by a local mechanic. The leaking stopped but the steering is very hard to turn now. Been trying to get this fixed for the last six months but no avail.
Indica Vista - list of Known problems greenhorn Technical Stuff 1427 8th January 2018 02:11
Tata Manza - List Of Problems jkdas Technical Stuff 200 13th December 2017 22:41
Tata Indica Vista- Technical Specifications & Feature List Stratos Technical Stuff 2 24th June 2011 19:47
Tata Indica V2 DLS customized vs Tata Indica V2 DLX karikrishni Hatchbacks 20 12th November 2009 10:59
