| Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al). |
| | Thread Tools |
| | #46 (permalink) |
| BHPian Join Date: May 2007 Location: Baroda
| This isnt exactly a problem with the Indica but i'll post it in this thread anyway. Im 6' 2" tall and I find the drivers seat a bit too cramped, even with the seat pushed all the way back. It is quite difficult to move my left foot off the clutch and i have to keep my foot flexed in order to avoid riding the clutch. This works for short trips but I get severe pain after long drives. Is there a way to increase the travel so that i can push the seat further back ?
__________________ Sometimes, to do it right, you have to do it yourself |
| | #47 (permalink) | |
| Senior - BHPian | Quote:
![]() Jokes apart, there is nothing much you can do. Alternatives are you choose a more spacious car, wear slightly less chunkier boots ( this does make a good difference for comfortable clutch operation, speaking from exp as i am 6ft 1in tall myself)
__________________ I have terrible reflexes- I was once run over by a car being pushed by two guys !!!!!!! | |
| | #48 (permalink) |
| The 'check engine' light comes on at RPMs above 2000 in my DLG (1700 K on the odo). Occasionally there's also a grinding noise at high RPMs. Any ideas guys ?
| | #49 (permalink) |
| BHPian Join Date: Mar 2006 Location: goa
| hey u need a to over haul the starter motor and use a bigger bat, it common on idicas ,that the starter won't take the load of a warm engine. thing is even if change the bat , it'll work for few month but later the same problem comes around, bosch bats work fine and fit in the existing fitting. As for the black smoke it's again common with engines with 75000 km, on them. Get the engine decarbonised , your both the second and third, problems will be reduced if not eliminated. these things are common with indicas, dude do not worry, there is solution to all the problem now and in the future. |
| | #51 (permalink) |
| Newbie Join Date: Dec 2007 Location: Bathinda
| Hi All, My indica DLG Nov.2005 has done 89000Kms. Never had any trouble.Recently I encountered the Hot Start problem. on even cold mornings the car started at first go, however after a drive of 10 mins or more it refused to churn the self or it did with difficulty. A few time heater sometimes did the trick. the battery dealer asked it needed a new battery. a couple of electricians did ask for self repair or replacement. Went to Tata Dealer and they charged Rs150 for self service and its almost a week and the car has cranked in one go in cold and hot engine state.
__________________ Life is short, Make it Sweet, Keep not all the flowers for the grave. |
| | #52 (permalink) |
| Senior - BHPian Join Date: Mar 2006 Location: New Delhi
| Ok.... update time. I recently got one of the glow plugs changed, (of the four one was faulty). It was Behr (i think) costed me around 280/- but the problem doesn't seem to go completely. I started the car after 2 days and it didn't. Then I did the ignition trick, i.e. let the heater sign go off, switched off the ignition and repeated. The car started, but I suspect the problem is somewhere else. Anything??
__________________ No signatures.. |
| | #53 (permalink) | |
| Team-BHP Support ![]() Join Date: Oct 2005 Location: Hyderabad
| Quote:
Why I said this? For two reasons... * A failed sensor cause those grinding noises from the engine at high RPMs? Sounds kiddish to me! * There have been similar cases in the past and one of the guys once told me about a case where his friend got suspcious of the whole idea of failed sensor and took some cross-opinions from other TASCs in the city. Everyone had a different opinion! Ultimately he approached the regional Tata guys I guess and there engineers intervened to get the problem correctly sorted out. EDIT: panky, you sure that only one glowplug had gone kaput? it is very much possible that another one has gone phutt. also check that the battery has enough juices left to make a cold start.
__________________ Announcements are important. Last edited by Zappo : 4th January 2008 at 18:50. | |
| | #54 (permalink) |
| thanks zappo.... i opened the bonnet yesterday to check the battery, realized that there are bubbles coming out of the cell - top (plastic wala dhakkan) where we pour the battery water. When i tried to open one of those, it was with some pressure that the water starting coming out. I went to a battery wala, he checked and said that the cells were OK but weak and its high time to get the battery changed. I switched on to amaron and all's well.
| | #55 (permalink) | |
| What should I do now? The problem has disappeared after the service.Quote:
__________________ Sometimes, to do it right, you have to do it yourself | |
| | #56 (permalink) |
| My indica 2004 DLS 68K on the odo occasionally has trouble starting. Usually the problem occurs when the car is warm. It never happens in the mornings. I had the TASC guys check my battery and glow plugs but no problem was found. The starter was overhauled a few months ago for the same problem but it returned sometime later. Any ideas guys ?
| | #57 (permalink) |
| BHPian | My sister's car had been sitting idle for the past 15-20 days due to unavailability of a driver. So one day I went to start the car and saw that the check engine light had stayed on after starting the car. sometimes it was blinking like some loose connection. took it to the service centre where the mechanic tightened a few things and the light had gone off. this guy had no clue as to what might have happened and said that these things are quite common and one should not worry about it . the best part was that the educated service advisor also told the same thing. but I insisted a lot and tried to get an answer from them. So they asked me to keep the car for the entire day and they would get back with some results. so in the evening while taking delivery of the car they told me that it was due to loose oxygen sensor. but the problem cropped up again while returning from the service centre. the light is blinking sometimes and sometimes going off. I am totally confused and hope to give these guys a good thrashing the next time I take the car there.
__________________ Don't take life too seriously, no matter what you do you won't come out of it alive |
| | #58 (permalink) |
| BHPian Join Date: Feb 2006 Location: New Delhi
| Before you start thrashing...! I suggest ask them to hook up the Laptop to diagnose what the check engine error is, At times the check engine stays on or starts blinking and might even go away in a fugitive state-which can be attributed to either loose coupler or faulty connection somewhere----If it stays on,it has to be a fault.
__________________ " When was the last time, You did something for the first time " |
| | #59 (permalink) | |
| tsk? anyone else ? I need info urgently because im reluctant to go to TASC now. Should i go there again or to a roadside mechanic ? Quote:
__________________ Sometimes, to do it right, you have to do it yourself Last edited by adityamunshi : 13th February 2008 at 16:54. | |
| Thread Tools | |
Similar Threads | ||||
| Indica Vista - list of Known problems | greenhorn | Technical Stuff | 324 | 13th November 2009 15:06 |
| Tata Indica V2 DLS customized vs Tata Indica V2 DLX | karikrishni | Hatchbacks | 20 | 12th November 2009 10:59 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
