| Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al). |
| | Thread Tools |
| | #61 (permalink) |
| BHPian Join Date: May 2007 Location: Baroda
| The engine cranks but the car doesn't start. After trying a few times it slows and the car has to be pushed. I read your thread about indica starting problems. you said that the stereo shouldnt switch off while starting the car. I have a pio 6950 and it switches off when i start the car. Does this mean anything ?
__________________ Sometimes, to do it right, you have to do it yourself |
| | #62 (permalink) |
| Team-BHP Support ![]() | The engine is cranking at normal speed but the car is not starting. This means the starter is okay, but somehow engine is not starting when car is warm. Could you give more details. Does your car automatically switch off when warm? If no, then the only culprit could be solenoid valve. Does this happen always or sometimes?
__________________ Reclaimed, wrung dry and recycled....! |
| | #63 (permalink) | |
| The car does not switch off when warm. And the problem is occasional. Most of the times the car runs fine but once in a while (few times a week) it has to be pushed. Quote:
__________________ Sometimes, to do it right, you have to do it yourself | |
| | #66 (permalink) |
| BHPian Join Date: Feb 2006 Location: New Delhi
| I had got the Wheel Hubs Greased and Wheel Balanced around 1000 KM back, but shortly I noticed a rumbling sound coming from the rear- left passenger side. It comes on bad roads or uneven roads, Got the suspension checked, its fine- What could it be, Since the mech cannot identify the cause. As a preventive measure, I had them grease the Rear Shocker Arms, Grease and tighten the Under body bolts, But still the noise remains. What I suspect is that it may have something to do with the Drum or Bearings on this side, but since they were checked and greased at 25,000 KM-I'm unsure.
__________________ " When was the last time, You did something for the first time " |
| | #67 (permalink) |
| Team-BHP Support ![]() Join Date: Apr 2007 Location: Delhi
| It may well be the bearings. Try to listen to the noise when the car is cruising at 40kmph and then switching off the engine. If the noise persists, its the bearing in all probabilities.
__________________ Car is no longer a luxury; parking space is. Swift VDI(ABS) Sep 07 - 53K Kms Ford Ikon Flair Sep 04 - 70K Kms |
| | #68 (permalink) |
| I can hear the noise on low speeds, specially since I drive back late and roads are quite. It specifically comes from the Left rear side. Also I was pertuped by the constant squeeking and rattles every now and then from the rear, Got it checked- Turns out the parcel tray and rear tail lamps were the culprits- got them adjusted, noise gone except for this Rumble.
| | #69 (permalink) |
| Drove another 500 KM in this week, the noise is there. Will be visiting the workshop tommorow and check the rear wheel bearing. Would it be possible for a wheel bearing to wear out immediately from the time of re-greasing the Hub. Also, I have BOSCH Brake Pads installed at 25,000 KM- The Brake power is good, for the first few 100 KM's there was no squeeky noise, Offlate I have noticed that once the car is warmed up, The Brakes Squeel on slowing down, Its not the metallic grind that comes when the pads are worn, but a normal squeel. Any suggestions on what to do- I don't think cleaning the pads with sand paper has helped, since I go it done, but the sound came back.
| | #71 (permalink) |
| BHPian | After the first service of my sister's vehicle a strange problem has cropped up, the car does not start before 3 -4 crankings. can anybody please suggest what may have gone wrong?
__________________ Don't take life too seriously, no matter what you do you won't come out of it alive |
| | #72 (permalink) |
| BHPian Join Date: May 2006 Location: mumbai
| Hi Indica Xeta 2006 - 18000 kms 1.4 GLS (Petrol) I have been facing the cold start problems for over 2 weeks. Went to TASC a week back (for non cooling of the ac) and they put gas, there was some leakage and gave me bill of 3000/-, wheel alignment etc... But the main problem with the cold start never went away. The rep has recently told me that there is a switch near the driver seat which needs to be presed. But that has been to no avail.... I havent taken extended warranty and this dude gave a synopsis about why one should take it etc. etc. and that i missed it cos i did not go within 15 months..... useless dumb... I am thinking of going to a mechanic and have this sorted....but am sceptical since I have never taken my car to a road side garage |
| | #73 (permalink) |
| Sail, I suggest take the extended warranty, Whats a 4000 rupees compared to the coverage offered. Suspension, ECU,Fuel Injectors, Pump, Engine Parts etc etc. You can also opt for 24/38/48 months coverage- each at different costs- 48 months extended cover comes for Rs 4000. The later you purchase the expensive it becomes.
| | #75 (permalink) |
| I think he still can, its offered here. As far As I'm aware-Suggest that more information can be obtained from another TASC or TATA regional Center. You can not apply if you exceed the 18 months Manufacturers warranty. However since its late, He will have to shell out a premium, which in the most likely range of 4000 should buy him 38 months instead of 48. Suggest that Sail, Take it- if its still up for grabs. But coming back to the issue, The car is warrantied for another 3 months- The Cold start issue needs to be resolved, Did you check the Coil, Starter and Plugs. Also the switch being referred to is under the Driver seat, Don't know how it works, has some rubber top- I guess Msharma, one of the other XETA owners on the forum talked about how he discovered it during a After Wash Mayhem.
__________________ " When was the last time, You did something for the first time " Last edited by wolfinstein : 29th February 2008 at 01:08. |
| Thread Tools | |
Similar Threads | ||||
| Indica Vista - list of Known problems | greenhorn | Technical Stuff | 324 | 13th November 2009 15:06 |
| Tata Indica V2 DLS customized vs Tata Indica V2 DLX | karikrishni | Hatchbacks | 20 | 12th November 2009 10:59 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
