Old 18th November 2011, 22:09   #886
kcj3b's Avatar
Thanked: 42 Times
Originally Posted by deep_bang
Let me go back and open my car's bonnet and see if i can find anyother reason to get stuck. Will get back by tomorrow morning (now its too dark to play around).
Dude the missing rubber is the culprit.actually the one still hanging there just had it. It cant take the load and needs either to be raise by unscrewing it or replaced as its life is over and cant keep the bonnet tightly closed .as the bonnet is not tight enough the lever will pop it and not good enough for it to be opened. In short,get the rubbers
kcj3b is online now   (1) Thanks Reply With Quote
Old 19th November 2011, 16:25   #887
AutoIndian's Avatar
Thanked: 3,726 Times
Default Re: Tata Indica - List Of Problems
Originally Posted by mercedised View Post
Yes that rubber is the reason. Those rubbers does a job of spring so that when we pull the bonnet opening lever those rubbers pushes the bonnet up and thus the bonnet gets unlocked. Get that rubber. Or alternatively, get a person to hold the bonnet lever for you and then another person open the bonnet. This is what I do regularly due to the same problem. Although I have developed my own methods to open bonnet nowadays.
Guys finally the issue is resolved, thanks for your suggestions. This morning I went to Pandit Auto & bought 2 rubber screws (each costed me Rs 14/-). Below are the pics. These are simple rubber screws with 5-6 threads. These need to be simply screwed in the hole (can be seen in the second picture). Now the bonnet gets locked excerting some pressure on these two screws. I have kept four threads outside & two inside. When the lever is pulled from inside the car to unlock the bonnet, it pops up as the screws release the pressure & I can easily lift it now by pressing the flap under the bonnet.
Tata Indica - List of problems-rubber-screw-fitted-3-turns-outside-2-inside.jpg
AutoIndian is online now   (2) Thanks Reply With Quote
Old 19th November 2011, 19:01   #888
kcj3b's Avatar
Thanked: 42 Times
Lovely Sir,great to see we all learning from each others experience.
Another thing which makes me feel proud is how a few people still take care of these machines by taking care of these details.
Lucky are those who get the required spare n expertise.
I own a 2004 Indica Dls now clocking 66k is a rare thing in this part of the world and getting such small but essential parts is a dream!!!!!!!
Old 19th November 2011, 22:12   #889
AutoIndian's Avatar
Lovely Sir,great to see we all learning from each others experience. Another thing which makes me feel proud is how a few people still take care of these machines by taking care of these details.
Very true. TBHP is such a great forum & there are so many things to learn from each one of us over here, it is just un-ending. I do take utmost care of my car & bike, there are many like minded people over here. I am of the firm belief, if you take care of her (car, bike, bike-o aka wife), she will never let you down & will return the same care multi-fold times.
Lucky are those who get the required spare n expertise. I own a 2004 Indica Dls now clocking 66k is a rare thing in this part of the world and getting such small but essential parts is a dream!!!!!!!
I can understand that. I am very fortunate to live in the same city where Indica was born & getting the spares here is a breeze. Any time any of the forum members find difficulty in procuring any Indica spare part they can drop me a private message & I can source it for them.
AutoIndian is online now   Reply With Quote
Old 19th November 2011, 22:32   #890
johnruben's Avatar
Thanked: 52 Times
@scopriobharath & @AutoIndian, i went again to Prerana motors next day to rectify this, the service guy as usual said, oil above the max mark is still normal and he has been doing this for all indica's, i gave him my piece of mind and told him NOT to give wrong information to customer if he doesnt know, finally supervisor drained some of the excess oil and i also added Bardhal engine oil Additive, now attaching the pictures of dipstick showing oil level along with full invoice.
Please do comment about the wheel bearing being changed at 36k km and also wheel cylinder replacement, i think i have been conned here, expert advise needed, b/w my tyres are upsized than usual indica's, they are 175 R14
Please also comment on the dipstick level, the backside of dipstick shows more then max while front shows below the max, is it normal ?
PS: my apologize for picture quality (in PDF) being terrible, took snapshot from my phone.
johnruben is offline   Reply With Quote
Old 19th November 2011, 22:52   #891
AutoIndian's Avatar
Originally Posted by johnruben View Post
Finally supervisor drained some of the excess oil and i also added Bardhal engine oil Additive, now attaching the pictures of dipstick showing oil level along with full invoice. Please also comment on the dipstick level, the backside of dipstick shows more then max while front shows below the max, is it normal ?
The correct way of checking oil level with a dip stick:
1. Park the car on a leveled floor.
2. The engine should be off for at least a couple of hours (& cold) so that all the oil collects in the sump (Never check the oil level when the engine is hot)
3. Take out the dip stick, wipe the oil on it with a clean cloth/ newspaper.
4. Insert the dip stick in the oil well completely, hold it for a couple of seconds & then remove it.
5. After removing hold it vertically & check if the oil level is between the two marks.
6. The oil level should be the same on either side of the dip stick
Did they show you the damaged bearing that was replaced? What is the wheel cylinder assembly, can you please clarify?
AutoIndian is online now   (1) Thanks Reply With Quote
Old 20th November 2011, 00:19   #892
johnruben's Avatar
Thanked: 52 Times
Yes, this is how i check, I check in the morning before starting the engine, but never ever have both sides of dipstick level been equal, i have tried many times, front part is below max, but when i check the other side it is above normal, this happens always.
Note from the Team-BHP Support: Post edited. Please note that it is now imperative for you to upload pictures directly to the Team-BHP Server. Click here to view our simple help article on uploading pictures.
Old 20th November 2011, 07:52   #893
condor's Avatar
Thanked: 3,551 Times
Total bill came to 10k + for vehicle which is still under extended warranty and which has clocked only 36k km :(
Please share the invoice details. Wonder what could make it cost 10k even with extended warranty ?
.. mistake they did is overfilled engine oil,
A.S.S often do this. They would have also billed you for the "excess" oil. Next time you go for servicing (anywhere):
1. Check your owner's manual for qty of oil required.
2. Insist (when JC is being prepared) that put in half liter less. Make them write it there.
3. When taking car back, check engine oil. Ensure it is not above max.
4. Since engine will be a little warm (due to trial run etc), it is quite normal to check oil level at this time.
5. If required, ask them to top up the oil. Then proceed for billing.
Checking of Oil level should be part of checking the car before accepting it after service.
Btw, who was the service Advisor you met ?
Old 20th November 2011, 12:03   #894
AutoIndian's Avatar
This is quite strange. Have you tried reversing the sides & then inserting the dip stick? Is the yellow bulb (solid plastic round) at the bottom of the dip stick intact? If not then the stick is likely to rub against the walls of the oil well & pick up some residual oil from the walls when it is being lifted.
Please reload the pictures as suggested by the mods. I made my first ever rear wheel bearing change at the recently done 100K service, that too only for the LHS rear wheel. The mechanic showed me the rollers on the taper roller bearing had some brownish yellow marks on the circumference (unfortunately don't have pictures) & suggested me to change it as a preventive measure, to which I readily agreed.
Old 20th November 2011, 14:23   #895
kcj3b's Avatar
Thanked: 42 Times
Well that a great news for people like me, will trouble you if needed!
Also do write about your experiences with Indica since urs has clocked the maximum here....
The morning start issue is gone, turned out that the hand pump was leaking air changed it.
Sometime back my Gearbox acted weird enough and Gear 1 n 2 were not engaged at all..got stuck up in a jam and got my clutch plate burned royally. Had to replace the clutch and comp plate set, although still feel the same are not as easy to engage,fear the same thing might catch me again,please comment
kcj3b is online now   Reply With Quote
Old 20th November 2011, 14:41   #896
AutoIndian's Avatar
No issues at all, you are most welcome anytime.
Don't know if you have already visited my ownership thread, if not then below is the link. I joined TBHP pretty late (Aug 2010), when my car was 6+ years old. So you won't find the initial experience in the thread, but the experience from 80K kms & beyond. However in the first page of the thread I have my car log attached. You can refer that for any further details.
http://www.team-bhp.com/forum/long-t...ms-beyond.html
Hmnn starting trouble could be quite tricky to diagnose. I have faced almost all the scenarios. Car not starting due to:
1. Air leakage in fuel line, priming pump replaced
2. Air leakage in fuel line, fuel filter replaced ("O" ring gone)
3. Glow plugs gone
4. Battery down (replaced)
5. Starter motor not able to take the load when engine pretty hot (starter motor overhauled, armature winding changed)
This is not uncommon for Indicas. The first & second gears are quite notchy to engage (especially if you are downshifting). You need to shift with a lot of patience. Sorry to hear about your clutch getting damaged. Fortunately I am still on factory fitted clutch (touchwood). Always make it a habit to press the clutch pedal fully before changing gear & don't force the gear lever, give it a gentle push.
Old 20th November 2011, 22:32   #897
kcj3b's Avatar
Thanked: 42 Times
Yes true abt the Gearbox but what about on highways like in J&K where the terrain is hilly and needs a full gearbox workout?
Again i feel every indica is unique especially in the shares of problems,big or small.Some have wheel bearing issue ,some oil tank and so on.
For example the hot cranking issue which i faced resolved automatically after my battery change last year.inside mirrors of ovrm is something which still is not available in original .i still dont undertand why aucostic dampner - the plastic cover on the engine was included in dlx n dlg but not dls but helps a lot in reducing engine noise, was too interested in installing it but could'nt get it. Glow plugs is another thing now which i have learned how to check and change myself.
Old 21st November 2011, 00:13   #898
johnruben's Avatar
Thanked: 52 Times
@condor, i have already attached the invoice, its above in post #890
@AutoIndian, i had earlier provided the links for cylinder and bearing from google, since i threw the old one's given by TASC, if you google under Google-Images you will find them.
Regarding the plastic part in the dipstick seems ok, i dont know why excess oil is shown in the opposite side, hope everything is ok.
Old 25th November 2011, 21:29   #899
kcj3b's Avatar
Thanked: 42 Times
Update: electrical ghost just struck!!!!!
Seems the Alternator regulator is gone,hope alternator is safe. Will get it checked in the morning
Clock is gone too only lits up wen headlights are on and get reset everytime lights are switched off n on, very annoying especially when you depend on it since so many years.
My driving his car behind me told me that only centre high brake light is working on brakes although tail lights are working fine with headlights.
Old 26th November 2011, 12:55   #900
NOTORIOUS's Avatar
Thanked: 86 Times
is there a way to check weather all four cylemders are firing properly or not ???
asking because one of my friends xeta is vibrating a lot , if they are engine mounts then vibration must distort while accelarating or deaccelarating . but thats not the case.
i am confused , please help !!!
NOTORIOUS is offline   Reply With Quote
Indica Vista - list of Known problems greenhorn Technical Stuff 1418 20th June 2017 17:13
Tata Manza - List Of Problems jkdas Technical Stuff 188 4th January 2017 14:01
Tata Indica Vista- Technical Specifications & Feature List Stratos Technical Stuff 2 24th June 2011 19:47
Tata Indica V2 DLS customized vs Tata Indica V2 DLX karikrishni Hatchbacks 20 12th November 2009 10:59
