Thread Tools
Old 5th May 2008, 10:41   #106 (permalink)
adityamunshi's Avatar
Someone please reply to my previous query.
Originally Posted by adityamunshi View Post
My indica seems to be losing power in the afternoons when its very hot. Is this normal ?
__________________
And Michael Schumacher is actually in a very good position to win the race. He is in last place. - Murray Walker
adityamunshi is offline   Reply With Quote
Old 5th May 2008, 11:54   #107 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Losing power means that engine is overheating.
Overheating can be due to a number of causes.
1.Cooling system issues
Either your fan has gone kaput or some fuse has gone kaput or thermostat has gone kaput and its not telling the system to start the fan. If your temp gauge does not go above half way mark and the fan does not come on its a thermostat problem. It could also be some issue with radiator
2. Engine issues.
Mixture setting, gasket issues blah blah. But thats rare. How much has your car run?
__________________
Reclaiming.....!
Old 5th May 2008, 13:43   #108 (permalink)
I dont think the engine is overheating, the temp indicator remains just below the halfway mark, occasionally crossing it. And I can hear the fan starting when it does.
Another thing i've noticed is that the steering becomes very heavy when this happens.
2. Engine issues.
__________________
Old 5th May 2008, 13:52   #109 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Could be the power steering/alternator belt overloading the engine.
Get your power steering pump checked.
And how much as your car done?
__________________
Reclaiming.....!
Old 5th May 2008, 14:00   #110 (permalink)
It is just about to cross 70 K. I think the power steering belt/pump is more likely to be the problem because lately the steering is behaving erratically. Sometimes its light, and at times very difficult to move.
__________________
Old 5th May 2008, 14:23   #111 (permalink)
Team-BHP Moderator
tsk1979's Avatar
I suspect the power steering pump is loading the engine.
This often happens due to faulty bearings.
Get it checked as ignoring this problem can lead to power steering failure which is expensive repair.
__________________
Reclaiming.....!
Old 5th May 2008, 16:05   #112 (permalink)
Okay, thanks Tanveer.
__________________
Old 13th May 2008, 14:21   #113 (permalink)
Default revs dropping
My 04indica lsi..barely done 19k,has been acting damn weird recently.
On starting the car,at idling(which is normally 1k)..the rev drops to abt 700 800 n goes back up..the engine basically stuttering.
its like this periodic fluctuation which stops,after driving for a bit.
another thing is that the fuel level drops to zero on its own..randomly,n slowly comes back up.cant figure out what the issue is,gotta go get it checked..any leads??
the third issue is while takin a slow left turn,the car jerks..with weird noises comin from the front left side.The mechanic said its a axle hub issue when he just heard me describe it..is he right?
bonnetsup is offline   Reply With Quote
Old 15th May 2008, 17:33   #114 (permalink)
indivic's Avatar
I have the same problem that @adityamunshi has plus a couple more and I have done only 30K on my Indica
I have to always upshift at over 30 km/hr to 3rd and keep it there and similarly for 4th , I have to make sure I am above 45 km/hr, otherwise even going downhill the car starts jerking at the slightest throttle input
Another problem is that there is absolutely no damping from any of the shocks even though I have treated the car well, TASC says that I need to replace both the front struts - how can I confirm that indeed they are kaput.
For the rear, I am asked to replace the rear wheel bearing since one of them is broken, this I have to believe them. But can I also fit a better shock for the rear, any idea if there are gas charged shocks for the Indica
thanks,
ramna
indivic is offline   Reply With Quote
Old 15th May 2008, 19:58   #115 (permalink)
Aditya, has your power loss problem been solved?
Eager to know the outcome.
anupmathur is online now   Reply With Quote
Old 16th May 2008, 01:43   #116 (permalink)
iraghava's Avatar
My car has a similar power loss problem, becomes a pain to drive during hot summer days with the A/C on. Diagnosis? Faulty compressor close to the end of its life.
Solution (i.e. changing the compressor) is going to cost around 25k all inclusive so I think I'll live with driving with the A/C off whenever needed!
__________________
There is a very fine line between "Hobby" and "Mental Illness".
Old 16th May 2008, 08:24   #117 (permalink)
There was nothing wrong with the Power steering except a leaking pipe. Havent got that corrected yet but surprisingly, the problem has disappeared recently.
__________________
Old 16th May 2008, 09:14   #118 (permalink)
Team-BHP Moderator
tsk1979's Avatar
New Surbos compressor costs 7800 in sec 16 noida
__________________
Reclaiming.....!
Old 16th May 2008, 10:31   #119 (permalink)
indivic's Avatar
Could somebody please help me out with some answers for my query ?
Thanks,
ramna
Old 16th May 2008, 12:16   #120 (permalink)
wolfinstein's Avatar
Would a Subros Comp be Plug and Work for a Ford Ikon, or does it need a completely new system, A friends Ikon has a faulty comp which needs to be replaced.
__________________
" When was the last time, You did something for the first time "
wolfinstein is offline   Reply With Quote
Thread Tools
Tata launches New Indica, Indigo CS, Indica V2 DICOR, Sumo Grande, Xenon. Details.... ashutoshb The Indian Car Scene!! 100 22nd June 2008 14:56
Starting problems Indica DLG vfmanuel Technical Stuff 19 13th December 2007 23:09
Diesel Indica - 2 questions/problems kaustubh_vaze Technical Stuff 7 8th June 2007 17:39
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
