Old 19th November 2007, 16:25   #1
rohit_dce's Avatar
Thanked: 18 Times
Question General query about MPFI sensors
I want to know what is the procedure by which the sensors of MPFI engine can be tested that they are working fine?
Also how does one get to know that certain sensor has gone faulty? Is it some warning signal or erratic behavior of engine only tells ?
rohit_dce is offline   Reply With Quote
Old 19th November 2007, 17:18   #2
Psycho's Avatar
Thanked: 95 Times
The only way to check the sensors is based on the following:
1) Specified tech manual and sensor calibiration data
2) Use the engine fault codes to analyse where the problems are.
Old 19th November 2007, 18:34   #3
Jaggu's Avatar
Thanked: 8,670 Times
to add to what psycho has posted, usually the ecu light should light up if there are any major issues
Onboard Tyre pressure sensors suren181 Tyre & Alloy wheel Section 121 20th March 2018 12:16
Finalized Swift: How useful are Rear Sensors? lambuhere1 Hatchbacks 3 12th July 2007 22:46
General query _re Servicing shbhrao Technical Stuff 3 10th July 2007 13:52
Dumb question about sensors....but i gotta know rohan_fonseca Technical Stuff 6 19th April 2007 03:38
Read about how Oxygen Sensors work Rehaan Technical Stuff 2 13th March 2006 02:51
