Old 19th November 2007, 19:10   #1
Default Second gen Gypsy (1000cc) compression ratio & oil consumption question
Folks,
Anyone know the stock compression ratio for a 1993 Gypsy (70k kms)? I googled but only found specs for the King which is 9:1.
My new to me 93 is running great but consuming oil at an alarming rate of 1 liter per 100 km while doing 80-90 on the highway. I did a compression check at my friendly neighborhood maruti dealer, but want to make sure how to interpret the numbers. I am getting the oil seal, gasket and intake manifold changed anyway, just want to make sure if that is good enough to slow the oil consumption. Thanks a lot for the insight.
xxaarraa is offline   Reply With Quote
Old 19th November 2007, 21:38   #2
humyum's Avatar
Thanked: 2,186 Times
Also check if its smoking from behind.Could be worn out piston rings and hence the oil consumption.The compression test would have given a fair idea about the health of the engine.Do put out the figures here.
humyum is online now   Reply With Quote
Is it possible to increase the compression ratio pratheesh Technical Stuff 30 10th April 2010 17:58
Changing Compression Ratio & Gear Ratio adheesh Technical Stuff 7 3rd October 2007 09:54
Variable compression ratio engine! amitoj Technical Stuff 8 20th December 2005 21:01
Compression Ratio and NOS Ford Rocam Modifications & Accessories 9 28th June 2005 03:13
Vtec's compression ratio!!! Shan2nu Technical Stuff 8 7th May 2005 23:07
