Old 6th January 2010, 02:16   #31
ghpk's Avatar
Thanked: 193 Times
I am a santro user, and i do a oil, coolant, brake fluid, steering fluid, air+petrol filter check up at every 5k kms, while full service at 10K by A.S.S.
This much is enough for 5K run until you are experiencing some problems.
Old 6th January 2010, 09:58   #32
vigsom's Avatar
Thanked: 605 Times
Originally Posted by swiftsuzuki71 View Post
Hey Guys, Still holding the confusion whether to opt for the 15K service or not. This is the service suggested by the dealer and not the manufacturer. The engine Oil should be able to sustain 10k Kms of drive and the as said the air filter should only needs to be cleaned, where the car has been driven in dusty area needs a cleaning. I would go for 10k Service for my Swift Diesel though recommended for 5k by the dealer. Happy driving
Please go by what the manufacturer says.
Also please remember that brake fluid must be changed every 1.5 years(in the larget interests of the brake components) as brake fluid tends to absorb moisture and then polymerise.
Old 6th January 2010, 10:07   #33
clevermax's Avatar
Thanked: 445 Times
Trying to match up with Punto's manufacturer recommeded service interval of 15,000 Kms?
You should go by what the manufacturer says. Service guys want to reduce the crowd in their place I guess.
clevermax is offline   Reply With Quote
Old 6th January 2010, 14:24   #34
mechanik's Avatar
Hi - I own a Swift petrol. I was asked to come in for a service at 15K, but since I was out of town I could not take the car to service during this time. Once I came back, I replaced the engine oil, oil filter, and got the wheels balanced and aligned. I suppose that would be enough until you take it in for the 20K service.
All said and done, it is your discretion whether to service at 15K or not, although it is not recommended.
TC - Kiran
mechanik is offline   Reply With Quote
Old 6th January 2010, 15:13   #35
DieselFan's Avatar
Thanked: 234 Times
You can be pretty safe by following Manufacturer's recommended service interval. I have done so on Swift D and have been servicing every 10000 kms since 20K kms service and now at 52K I do not have any issues with the car.
DieselFan is offline   Reply With Quote
My Tiny Requires a New SQ Sub jatinpatel In-Car Entertainment 27 27th February 2011 20:45
Scorpio CRDe @ 70,000 kms! 5,000 of Agony & 65,000 of bliss smats Long-Term Ownership Reviews 17 8th May 2010 17:37
Does a Aug'07 Palio Stile 1.6 requires coolant top up every 200 km? soumyob Technical Stuff 12 25th July 2008 19:04
US Army requires more capability than the HUMMERs! GTO The International Automotive Scene 10 28th February 2007 14:54
