Thread Tools
Old 23rd November 2007, 08:15   #1 (permalink)
Default Engine Noise in my Santro 2001
hi,
I have santro june 2001 model. The engine is not silent. It makes some sort of noise. Although it is not at all weird & very loud, and Huyndai ASC confirmed that there is not problem at all and engine is absolutely fine. My ODO reads 42K.
H'ever I have seen Santros older than mine making very less or no sound at all when thet pass by me. LocaL mechnic says the sound it of belts, and one should not be bother about it, as it is quite common.
Guys, I need your advice on this. I really want to have a silent engine, please guide on how to achieve it.
Please advice. Thank you
__________________
Warm Regards,
Aashutosh
Aashutosh is offline   Reply With Quote
Old 23rd November 2007, 11:46   #2 (permalink)
Extract the service records from the service centre and see if all routine relacements were done. If not you can do it now, if yes, nothing more can be done.
The engine noise depends on prior usage and how it was handled/ maintained.
dadu is online now   Reply With Quote
Old 23rd November 2007, 11:50   #3 (permalink)
I too had this problem with my 2001 Santro. I checked with the dealers and they said its normal. However it has improved drastically after I moved to Shell for fuel and engine oil.
appuchan is offline   Reply With Quote
Old 23rd November 2007, 12:05   #4 (permalink)
I can also suggest an STP engine flush, if not done already, it smoothens the car drastically.
Old 24th November 2007, 08:10   #5 (permalink)
Default Engine sound in my santro 2001
dadu, cost for STP engine flush? how long does it take really? Also currently I am using speed as my fuel, shall I try switching to shell, which is expcted to improve engine sound?
__________________
Warm Regards,
Aashutosh
Old 24th November 2007, 21:07   #6 (permalink)
wolfinstein's Avatar
STP flush is available at an MRP of Rs 210/- and usually sold for Rs.190/-.
Flushing does not take much time, However since the engine is now 42 K old and perhaps never been flushed before, check out the condition before use. Since you may risk the Oil seals which will now become clean of any carbon covering and might induce Leakage if they were weak or defective. But I don't think it might be the case if you have maintained the car service schedules.
You need to run the engine in Idle mode for the first few minutes till the Ideal Temp is reached.Then shut off and add the STP flush from the Engine Oil Filler Cap. Start and Run the engine for 10 Min, Do rev up the RPM to 2000-3000 From Idle RPM once or twice keeping it constant for 2 min or so. Then Let the engine Idle again and turn off the ignition, and Drain the Oil immediately.
Replace with new oil and filter, And a much improved engine is available at your use.
You can choose Castrol Magnatec for good performance and quiter engine. If your pockets run deep then Mobil 1 or Shell Synthetic Oil is for you.
__________________
" When was the last time, You did something for the first time "
wolfinstein is offline   Reply With Quote
Old 25th November 2007, 12:03   #7 (permalink)
Like wolf described, flush might help(it did for me), speed fuel is anyways better.
Old 26th November 2007, 10:31   #8 (permalink)
Thank you guys for quick responce. I will surely work on this and give my feedback. Thanks again.
__________________
Warm Regards,
Aashutosh
Thread Tools
2001 Hyundai Santro LS khanak Long-Term Ownership Reviews 34 7th April 2008 06:54
Wheel Balancing for my Santro 2001 Aashutosh Tyre & Alloy wheel Section 3 18th December 2007 08:48
Difficult to diagnose noise from Santro dj_2006 Technical Stuff 2 2nd July 2007 23:28
Help needed on choosing a 2001 Santro tigerji Hatchbacks 3 30th March 2007 08:15
Engine noise DaCentaur Motorbikes 0 19th August 2006 23:30
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
