Old 19th October 2009, 06:53   #16
Thanked: 49 Times
Originally Posted by sudharma View Post
For the last 20 years I had my Maruthi running without this valve. And no problems so far.
The engine will have problems at cold start (will have to work at cold temperatures for longer). Emissions will (consequently) be worse. FE will also suffer.
If you don't think those are problems then yes - you won't have any problems.
CrackedHead is offline   Reply With Quote
Old 19th October 2009, 09:37   #17
sgiitk's Avatar
Thanked: 3,884 Times
I full agree with Crackedhead. In the days of eh Amby & Fiat cars often were shipped with no thermostat. Also, often at the first sign of any overheating, or when installing an AC the thermostat (and also the radiator cap rubber) were removed by mechanics. This was a bad practice as very nicely put by CH.
Remember the function of the thermostat is to bypass the coolant flow (away from the radiator) to allow the engine to warm up fast. Then it opens and the normal flow through the radiator is available. I will replace a faulty thermostat rather than dump it!
Old 19th October 2009, 14:51   #18
Raccoon's Avatar
Thanked: 105 Times
Exactly! The point should never be that it works; rather HOW it works.
It works! But how? And at what cost?
If the mechs/supervisors where indeed so smart as to overrule what the company has put there, they would more likely be seen in the company designing cars.
Old 19th October 2009, 15:06   #19
sgiitk's Avatar
In my experience the thermostat on the Hyundai has the needle barely moving once the desired temperature is reached (i.e., it is between the two dots). On the Marutis it moved around quite a lot. Whether it is better temperature control, or a less sensitive gauge I do not know.
Old 21st June 2010, 12:03   #20
Thanked: 436 Times
Originally Posted by Raccoon View Post
^^^ Topping up should not be done thru the radiator cap!! Please maintain the level only in the reservoir tank when cold.
Flushing is to be done only once in 2 years for most cars. I don't know 800's coolant capacity or your brand and its dilution ratio, so can't answer those questions.
What to do if the radiator is not filled to the brim? After replacing my coolant at the service center, I found that the level in the radiator had dropped when I reached home (and the engine had sufficiently cooled). So I topped up the radiator till the cap.
I had to do this because the radiator was not full (till the cap) even after sucking the coolant back from the coolant reservoir tank.
jinojohnt is offline   Reply With Quote
Old 21st June 2010, 21:26   #21
ghpk's Avatar
Thanked: 193 Times
There's a min and max mark, you don't need to top it up to cap.
Also mention what you filled to make it top up, water or coolant ?
Old 22nd June 2010, 10:14   #22
Thanked: 436 Times
I have seen a 'min & max' mark on the coolant reservoir, but haven't noticed any 'max' or 'min' mark near the radiator cap. Is it harmfull if I fill the coolant till the brim (till the radiator cap)?
I keep a mix of "Coolant + Water (1:2)", which I use for topping up.
Old 23rd June 2010, 00:52   #23
Raccoon's Avatar
Thanked: 105 Times
^^^Dude, brief answer - leave the radiator cap alone. Just maintain the reservoir level between the min. and max. marks.
Old 24th May 2016, 13:05   #24
Default Need help on engine coolant checking
My car is Toyota Vitz 2010 a.k.a Yaris hatchback. I am not a car expert so pardon my novice question. I want to properly check engine coolant (locally called radiator water here in Bangladesh). A local mechanic is telling me that my car needs to be added engine coolant. I have checked the user manual and it suggests that I need to check engine coolant reservoir to check if it needs more fluid. On the whitish reservoir box the pink fluid is above 'full' mark but if I open the radiator cap than the pink fluid is not visible. Should I top up engine coolant?
Nahid is offline   Reply With Quote
Old 24th May 2016, 13:20   #25
Thanked: 880 Times
Default Re: Need help on engine coolant checking
Is there any reason why you want to check the coolant level?
If any fluid is above full mark, you have no reason to top it up.
If you are facing any troubles such as engine temperature shooting up (warning comes up in dashboard), then approach your service centre for the same. If you have no problems such as that, then your car is hale and healthy - your engine coolant level is fine, and you can drive on!
hybridpetrol is offline   (3) Thanks Reply With Quote
Old 24th May 2016, 13:22   #26
.anshuman's Avatar
Thanked: 9,159 Times
The reservoir box will have minimum and maximum markings, the coolant level should be between these markings. Top up is done to the reservoir and not directly to the radiator.
Also, check your car's service book to see the recommendation on coolant replacement.
.anshuman is offline   (1) Thanks Reply With Quote
Old 24th May 2016, 13:34   #27
Thank you both for confirming. I follow the user manual and since the coolant is up to full mark I personally think there is no reason to be worried. But local mechanics and employed drivers has a tendency to fill up "radiator pani" periodically. In fact recently an employed driver opened the radiator cap and since he did not see any water there he directly poured raw water without my knowledge.
Old 24th May 2016, 13:43   #28
sanjeevgpc's Avatar
Thanked: 24 Times
You have mentioned that the pink fluid is not visible if you open the radiator cap. If there is no fluid inside the radiator, something is really wrong. If the radiator is empty, you need to add the fluid/coolant asap or you risk damaging your car.
sanjeevgpc is offline   (1) Thanks Reply With Quote
Old 24th May 2016, 13:50   #29
Ouch! Now I'm confused again. Should I open the radiator cap to check coolant or should I check the reservoir marking?
Old 24th May 2016, 14:32   #30
Thanked: 436 Times
I remember that when the workshop changed the coolant for my car, the radiator was filled first. Then the coolant reservoir was filled till max. I remember the mechanic saying that the coolant reservoir should be filled 'only' after the radiator is filled.
jinojohnt is offline   (1) Thanks Reply With Quote
Coolant level low, but no symptoms? Ravich Technical Stuff 53 13th November 2016 18:14
Coolant spilling out of reservoir after I switch off the engine Irfanulla Technical Stuff 91 21st August 2014 21:37
engine coolant-does concentration levels affect operating temparature. deetee Technical Stuff 5 7th February 2008 21:02
best gear oil & best coolant & best engine decarb: please cyneverdie Technical Stuff 7 19th October 2007 03:57
