Old 11th March 2017, 17:21   #61
Thanked: 1,315 Times
Default Re: Engine Coolant Level
Distilled water by definition should have a pH of 7.0 neither acidic nor basic.I guess 6.5 to 7.5 or so will still qualify it as neutral
That's precisely what we are referring to as VERY mildly acidic water which is better used for battery top ups than other purposes.
What would I have done without team-bhp!
Having exhausted my stock, today I bought a bottle of distilled water from one of my usual shops. The composition, as indicated on the label, is as follows:
PH - 7.5 to 9
Electrical Conductivity - <10us/cm
TDS - <2ppm
Not really suitable for use as/with coolant.
I have been guilty of adding this very liquid to top up my coolant reservoir in the past .
On enquiry, I was informed that all brands/variants of distilled water available in this and other shops are all of the same composition.
The search for the elusive neutral liquid continues .
dailydriver is offline   Reply With Quote
Old 11th March 2017, 17:53   #62
R2D2's Avatar
Thanked: 1,208 Times
Originally Posted by dailydriver View Post
PH - 7.5 to 9
TDS - <2ppm
Good grief! If that label's information is to be believed a pH rating of between 7.5-9 gives you water errr..a solution that is a mild to strong alkali! In which case forget about using it as a coolant but how can you use it in a battery when it will work on neutralising the acid?!
This is the opposite of what I expected at the liquid being mildly acidic.
But seriously, this goes to show just stay away from bottled battery water for top ups. Clean filtered tap water is much safer. Or shift to a premixed coolant + DW solution.
BTW if you want pure DW please contact a lab supplier in your city.
R2D2 is offline   (2) Thanks Reply With Quote
Coolant level low, but no symptoms? Ravich Technical Stuff 53 13th November 2016 18:14
Coolant spilling out of reservoir after I switch off the engine Irfanulla Technical Stuff 91 21st August 2014 21:37
engine coolant-does concentration levels affect operating temparature. deetee Technical Stuff 5 7th February 2008 21:02
best gear oil & best coolant & best engine decarb: please cyneverdie Technical Stuff 7 19th October 2007 03:57
