Old 27th November 2007, 15:09   #1
subbusos's Avatar
Default LPG conversion for Maruti Zen LXi 2004 model
Hi all,
I am thinking of converting my Maruti Zen LXi 2004 model to LPG.
Here is the current stats of the car:
Current Kms run: 35000 kms
Current mileage: 13-14 in City/15-16 in highways
My usage: Mostly highways
Average run per month: 1500 kms
Its MPFI.
Please advise is it a right choice to convert it to LPG, if yes, which LPG kit to go for. I am thinking of a budget of not more that 20k and is it worth spending this amount so that I could save cost on fuel.
I am ok for 5-10% power loss. And also dont want to do any harm to engine.
Please help me...
Thanks in advance
- Subbu
subbusos is offline   Reply With Quote
Old 27th November 2007, 22:50   #2
wolfinstein's Avatar
A little search would help...!!!
The running is fine to convert, but LPG gives you a slightly lesser mileage than Petrol, you save on the cost difference-but then saving is saving.
Good kits are Lovato,Minda Impco,Bedini,Land Renzo,Tartarani.
Ensure you buy genuine OEM Equipment,Pref check Manufacturing date on each component-Reducer,Solenoid,Emmulator,LPG Control ECU if installed as a Closed Loop system.
No harm as such documented,but do run in petrol occassionally,pref start in petrol drive for a KM and convert to LPG-Same for Shutdown.
You will need to have New Airfilter,SparkPlugs,Throttle Cleaning done for the proper setup and efficiency.
Also look at using Castrol Magnatec or Mobil/Shell Synthetic for smoother and protected engine over regular mineral oil.
wolfinstein is offline   Reply With Quote
Old 28th November 2007, 09:52   #3
subbusos's Avatar
Thanks Wolfinstein,
Your advise is helpful to me. I will look for the items you said.
Subbu
Zen 2004 Lxi- Long term Ownership Maxwell Arthur Long-Term Ownership Reviews 17 14th January 2012 03:36
ZEN LXI 2004 October model available for sale amitlead Shifting gears 5 11th October 2008 12:49
LPG for Ikon Flair Oct-2004 Model. snaronikar Modifications & Accessories 0 14th September 2007 12:22
Wagon-R: VXi+LPG OR LXi+Upgrades+LPG? EDIT: Now booked LXi sohu9 Hatchbacks 14 16th January 2007 13:37
