Thread Tools
Old 29th November 2007, 10:31   #1 (permalink)
rakowli's Avatar
Exclamation Ikon Problem
I have a Mar 07 Ford Ikon. whenever i drive the car with or without AC the front passenger seat floor mat gets wet underneath. i dont know from where is the water sipping in. first i thought maybe the AC water is leaking in. But when AC is off still it persists. I try showing my local mechanic but he is not able to find out. we removed the flooring under mat and saw but it is not at all wet there. it is like something is heating from down and vapourising. I am afraid that it may get rusted from down which i dont want. Has anybody faced this problem. please help me with some solution.
rakowli is offline   Reply With Quote
Old 30th November 2007, 11:13   #2 (permalink)
rakowli's Avatar
please help me out.i require ur help teambhpians.
Old 30th November 2007, 13:32   #3 (permalink)
Jaggu's Avatar
Remove the tube that connects the ac coil drainage to outside the car, (its in between passenger and driver side floor board towards the firewall) clean the hole and get the carpets dried. You should be fine.
Once the carpets are wet it will take some time to dry off and hence you are getting the dampness inspite of running without AC.
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 30th November 2007, 14:51   #4 (permalink)
snaronikar's Avatar
Show it to Ford Dealer. My car had a problem of leaking at FR LH seat leg resting position. This was because of the hole the made by the ICE installer. Asked Ford dealer (Cauver Ford) to check them same and now the thing is arrested. Take the vehicle to an authorised dealer and your problem will be solved.
__________________
Love your job but Never love your company
because you never know when your company
stops loving you-NRN
snaronikar is offline   Reply With Quote
Old 16th January 2008, 09:47   #5 (permalink)
rakowli's Avatar
forgot to thank u all for the advice. the problem is solved.thanks jaggu i cleaned the AC Drainage tube and the problem is solved. Thanks once again.
Old 17th January 2008, 18:23   #6 (permalink)
Absar's Avatar
Hello,despite the problem have being solved,I faced the same problem in my Ikon during the previous service,in october or september.
It was exactly in the FR LH seat leg place. I showed this to Ford,they said the drainage pipe must be blocked,and it shall be changed. But already by the time (2-3 months of this happening) we changed it, the carpet had an ugly looking patch due to the dampness,even if dry. Nuts at this pipe.
cya
A
__________________
Ford Ikon 1.6 Nxt ZXi, 2005
I cried because I had no VTEC, until I met a person who had no 1.6 ROCAM.
Absar is offline   Reply With Quote
Thread Tools
Ford Ikon - Fuel Pump problem gr8guzzler Technical Stuff 11 12th October 2008 15:05
Ford Ikon 1.6 stalling problem gaurav_diavolo Technical Stuff 29 5th October 2008 16:03
Problem: Ford Ikon vibrating (almost shaking) when Idle. Eddy Technical Stuff 25 31st May 2008 18:28
Electrical Problem with my Ikon! anachronix Technical Stuff 12 14th February 2008 13:56
Ford Ikon Starting problem blueraven316 Technical Stuff 2 15th March 2007 18:38
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
