Old 29th November 2007, 15:57   #1
Thanked: 20 Times
Default Low rev problem in M800 (Carb Model - 1996)
Have a M800 carb one that has done 91K kms.
The car was given to Surakshaa in Dec 2006 (at around 83K or so) for 'general service' and when I got it back, the engine tuning had changed. The smoothness was gone, and the car was not happy in lower revs (kinda starved). I ignored it, thinking that it would get better with time. Wasn't a difference in smoothness that anyone else other than I would have noticed.
Then I went out of town for a long time in late Jan 2007 when my brother used it until Aug 07. When I came back in Nov 07, I found that the car was now not at all happy at lower revvs (it kind of gives me a feeling that it is starved at lower revvs).. even at 40 kmph on fourth gear on flat roads with no load, the engine begs for mercy.
However, if I step on gas (Open the throttle) even at lower revs, the engine happily pulls off so I believe the engine is not getting sufficient 'air'. Is that right?
I am planning to give it for another 'full service' where the carb and air filter will be cleaned. Hope to get it resolved then. My fear is, has the timing belt/chain gone kaput?
Jeep is offline   Reply With Quote
Old 29th November 2007, 17:24   #2
humyum's Avatar
Thanked: 2,503 Times
Sounds more like a too rich or too lean airfuel mixture.Go to the service station and ask them to insert a puc machine and tune airfuel ratio accordingly.
Old 29th November 2007, 17:44   #3
Thanked: 20 Times
Thanks humyum..
Must be too rich since the mileage also has dropped to pathetic levels (about 10-11 kmpl or so in city with a/c off!)
santro zip plus engine over rev problem althaaf Technical Stuff 13 23rd December 2014 17:31
M800 1998 carb model Experiences. km120 Technical Stuff 12 10th July 2010 13:32
Tak Tak Tak Sound from my Enfield Bullet Standard 350 1996 Model navin_v8 Motorbikes 5 13th May 2010 10:45
