Old 16th May 2010, 13:32   #31
asdon's Avatar
Thanked: 293 Times
Guys any idea where some of these can be done in Bangalore? I have a Alto, last year my car carpet had to be removed, as I was stuck in a water logged road and water came insied the car. from then till now, I have not put the carpet back(I mean new one), after reading this thread, if I can find a good solution to inner noise reduction, I will go for it.
asdon is offline   Reply With Quote
Old 26th May 2010, 13:58   #32
ST7677's Avatar
Thanked: 45 Times
Any place where you get spectrum sludge in India?
Or any economical way to import it?
ST7677 is offline   Reply With Quote
Old 26th May 2010, 14:29   #33
nick17s's Avatar
Thanked: 93 Times
hi guys, i have a small issue, but it becomes highly irritating sometimes:
1. i get a noise from the seat belt pillar from inside
2. door is locked but still it makes noise like wehn the door is properly not shut
(both happens when i drive on bumpy areas, speedbreakers) how can I stop this noise??
nick17s is offline   Reply With Quote
Old 29th May 2010, 14:05   #34
Thanked: 41 Times
i have got my door sof ANHC damped ( noise kill) and they have reduced the road noice to some extend.
now i will plan to damp the floor of the car. to my knowledge the damping will not cost more than Rs.4500 @ 120/sqft
monty9991 is offline   Reply With Quote
Old 29th May 2010, 17:20   #35
DerAlte's Avatar
Thanked: 2,879 Times
Originally Posted by nick17s View Post
... noise from the seat belt pillar from inside ...
May not be from the B-pillar, even though it seems it is coming from there. If it really does, it would either be the slack in the seat-belt, or the capping is not stayed down properly.
... noise like wehn the door is properly not shut
(both happens when i drive on bumpy areas, speedbreakers) ...
Must be the door opener cable, the glass mount or even loose length of speaker or other cables. Take out the door pad, and stay down any long lengths cables by wrapping closed cell foam around the cable and sticking it down with hot melt glue or synthetic rubber adhesive. Check for play in the glass holder or the support arms and get it fixed. It could also be possible that the door lock is actually loose, you can check that by shaking the door vigorously after closing it.
Old 31st May 2010, 17:00   #36
nick17s's Avatar
Thanked: 93 Times
thankx man alte: i will definitely get all of those checked, but just 1 think i coundt understand, what is "slack in the seat-belt, or the capping is not stayed down properly" ??
How Indian car manufacturers are profiting by reducing weight of the vehicles ghodlur The Indian Car Scene 46 29th October 2011 23:40
Reducing the Safari's incabin noise vivek.singh.73 What Car? 10 1st June 2009 23:16
Need some input on reducing rattling noise in the rear due to the oval speakers partypest In-Car Entertainment 4 5th January 2007 07:49
Wind noise or Aerodynamic noise vivaid Technical Stuff 15 2nd July 2006 19:58
