Thread Tools
Old 29th November 2007, 21:32   #1 (permalink)
Default Improve the FE of a 4 BHP engine?
i have a small 4hp engine (honda GC135series) that i'm using for a university project.
i have to make small modifications to it so that i can improve the fuel consumption of the engine...any suggestions?
i has told to look at the carburettor as a starting point!
perhaps replace the jet for a smaller one? would this work!
i also thought maybe polishing the intake manifold!
neglible budget restricts the modifications that i can make?
any suggestions will be of great assistance
ag501 is offline   Reply With Quote
Old 1st December 2007, 17:58   #2 (permalink)
Team-BHP Moderator
Rehaan's Avatar
Im not sure what the final goal of this project is... but you could try the following which might make small / negligible differences :
- Change the jet
- Make sure the carb isnt leaky
- Lower the amount of oil in the engine towards the minimum suggested mark
- Clean the ports / valves / seals
- Run at optimum RPM
- Clean / choose ideal sparkplug
cya
R
Old 1st December 2007, 18:08   #3 (permalink)
Harbir's Avatar
From what I understand, the GC135 engines are already quite highly optimized so the gains available may be small and make your project look less than a success.
Harbir is offline   Reply With Quote
Old 1st December 2007, 18:24   #4 (permalink)
iceman91's Avatar
also you can increase compression and run it a little lean but you have to remember any modifications will reduce its life
__________________
...91 is back !!!!
iceman91 is offline   Reply With Quote
Old 3rd December 2007, 14:29   #5 (permalink)
thanks!
my supervisor suggested that i look at the carb,increase compression ratio,perhaps valve timing and or spark timing. the last two modifications sound pretty complex to do?
Old 3rd December 2007, 17:39   #6 (permalink)
iceman91's Avatar
the last two are the easiest and can be easily reversed
try them first but they affect performance as well
__________________
...91 is back !!!!
Old 4th December 2007, 22:02   #7 (permalink)
if i was to increase the compression ratio...would i be looking to 'skim' the cylinder head and replace the piston with a domed piston?
any useful sites that will help me????
Old 4th December 2007, 22:33   #8 (permalink)
drpullockaran's Avatar
Default Reduce air intake resistance.
From the very limited budget that you have the easiest would be to reduce the air intake resistance by straightening the air intake plumbing and by polishing the intake piping.
The other more expensive options are to shave the cylinder head mating surface or reduce the thickness of the head gasket.
After doing the above you will have to change the valve timings and the spark ignition timings and the fuel jetting. Since fuel efficiency is upper most on your mind get the engine optimized at the pollution control center on the cheap.
Bye and wear your seat belts.
drpullockaran is offline   Reply With Quote
Old 4th December 2007, 23:41   #9 (permalink)
Sankar's Avatar
1) Increase the compression (skim the head but check for valve clearances)
2) Run the leanest mixture you can without overheating the engine (do a plug chops to determine how lean you could go)
3) Those iridium spark plugs should help to burn that lean mixture efficiently.
4) Dont go for a freer flowing filter (yes it would lean out the mixture but do it the other way round)
5) Valve timing and ignition timing are easy to do but a bit complicated. You will have to read up on it. Or do it by trial & error. Reducing the valve overlap would help theoretically in yielding a better fuel efficiency, but since your cam seems to be a one peice affair it's not that easy to do.
Retarding the valve timing is also an option, but without an adjustable cam sprocket it's hard to get the degrees right.
Are you gonna be running the engine on a bike or is it going to be a bench warmer?
__________________
Never argue with idiots. They'll drag you down to their level and beat you with their experience.
Old 11th December 2007, 00:15   #10 (permalink)
Default hi
hey guys
the engine is part of a generator set.the engine may get used for other projects in the future,but just now i am looking to make the suggested mods to it to improve fuel consumption
Old 11th December 2007, 17:07   #11 (permalink)
DirtyDan's Avatar
Default No box
I do not think there is a "Petes box" for this one.
A smaller jet will also cut down the power, I think, but it seems like it should improve fuel consumption. A cleaned carb might help. Polished...maybe. Synthetic oil will give you a little gain, it is a slipperier lubricant. How about your air filter and intake? I used to just throw out the air filter and put a woman's nylon stocking over the intake for better air flow and no, I am not joking. You have to make sure it does not get sucked into the motor. Use a clamp or tie it tightly. What kind of ignition do you have? You might tinker with that.
__________________
The only tyrant I accept in this world is the still voice within. -Gandhi
Old 17th January 2008, 02:48   #12 (permalink)
Default ????
hi all
it appears that the GC135VHE engine that i have does not have a cylinder heas & head gasket so it is impossible to increase compression ratio!!!
would considering the valve timing make an improvement to the fuel consumption?...if so, is there any useful websites that might have a suitable camshaft for this small engine?
cheers
Old 18th January 2008, 18:11   #13 (permalink)
has the engine been hooked up to the generator ? if yes , please do the tests under load as mere idling might not give you the correct efficiency . Why dont you try playing with a 100 cc motorcycle carb ? you might have to design the constant throttle lever for use with the motorcycle lever as well .
also ,will you be running the engine on gas or with kerosene as well ?
Old 18th January 2008, 18:32   #14 (permalink)
Sankar's Avatar
Originally Posted by ag501 View Post
hi all
Oh, your engine sound like one of those with unitary cyl&head construction. But you could still increase the compression by skimming the base of the barrel.
__________________
Thread Tools
FIAT Potent little engine: 1.3 Multijet now with 105 BHP extreme_torque The Indian Car Scene!! 14 2nd March 2007 14:34
How to Improve the Ride Quality - Ikhanna Technical Stuff 10 6th January 2007 23:03
How to improve brakes in baleno? RoaringEngine Technical Stuff 22 21st May 2006 16:45
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
