Old 3rd December 2007, 12:10   #16
shuvd's Avatar
Am going to try this out as soon as I get my hands on the dry ice thingy. But AFIK, ice is something you put in your drink. Yeh dry ice kya hota hai??
shuvd is offline   Reply With Quote
Old 3rd December 2007, 12:13   #17
condor's Avatar
Thanked: 4,904 Times
Come to think of it, do our local garage owners & tinkerers even know of such a thing ?
Old 3rd December 2007, 12:31   #18
ram_hyundai's Avatar
Thanked: 48 Times
maybe after putting ice the metal portion would start rusting too.are we in for trouble.ram
ram_hyundai is offline   Reply With Quote
Old 3rd December 2007, 12:32   #19
Thanked: 7 Times
Is dry ice sold commonly in shops ? Any suggestions for availability in Mumbai ?
I want to experiment on the dent in the hatch of my Swift.
emkay456 is offline   Reply With Quote
Old 3rd December 2007, 14:18   #20
kryptik83's Avatar
me too. dent on my Swift's hatch too
kryptik83 is offline   Reply With Quote
Old 3rd December 2007, 15:54   #21
bblost's Avatar
Thanked: 6,979 Times
OT:
if you do get dry ice, (I got it once from a icecream vendor) then try this prank.
take a glass of water and drop the dry ice into it.
It will start giving out a thick white smoke.
now think of something interesting to do with the smoke without fire.
I did that once, my mom was not amused.
Old 3rd December 2007, 16:01   #22
Thanked: 33 Times
my chemistry is quite rusted(though never liked it), but i guess dry ice is solidified CO2. Its called "dry" because from solid state, it never goes to liquid state...directly to gaseous state( unlike ice->water->steam).
I dont think dry ice will be available of the shelf at ur neighbourhood icecream wala, but neverthless, its a very common form of CO2...should get it without problems at some perticular stores(not sure what type of stores).
A word of caution: Dry ice has a freezing temp of abt -70 or -80 deg, so should avoid getting ur body in direct touch with it(otherwise u may get forst bite kind of thing)
amohit is offline   Reply With Quote
Old 3rd December 2007, 17:29   #23
sqwall's Avatar
Originally Posted by team suzuki View Post
just take a slab of dry ice and rub it slowly across the dent the dent automatically gets repaired,there is a science on how this really happens,the size of ice slab depends on the size of the dent
The scientific logic holds true but it wont quite work as magic.
It will probably work on a shallow dent but in case of deeper dents it could actually make things worse, reason being that the metal will have larger surface area (dented) and wont quite regain its original form.
sqwall is offline   Reply With Quote
Old 3rd December 2007, 18:15   #24
sumitkalindi's Avatar
Thanked: 13 Times
It does give you a frostbite and you can source it from the Icecream depots only, they use this thing to cool the small rikshaw icecream vendors.
sumitkalindi is offline   Reply With Quote
Old 3rd December 2007, 18:27   #25
Thanked: 539 Times
Infractions: 0/2 (10)
well when are we getting the results of this experiment...something new to discuss btw
maddy42 is offline   Reply With Quote
Old 3rd December 2007, 18:31   #26
Akshay1234's Avatar
Thanked: 7,242 Times
its actually solid co2. i think co2 is cooled and pressurized. then the pressure is removed quickly leaving dry ice. it sublimes.
Old 3rd December 2007, 18:33   #27
Thanked: 397 Times
I have a theory. Most likely the dent is getting fixed because of the contraction of metal from the extreme cooling. So if we take normal ice in a polythene bag and then mix it with salt, and then rub the bag on the dent it might work as well. Though your normal ice melts at 0 degree celcius i remmber from my school days that mixing it with salt drops the temperature to -22 deg celcius. May not be as good as dry ice but may work.
JediKnight is offline   Reply With Quote
Old 4th December 2007, 11:09   #28
arunkumar_rec's Avatar
I feel this may not work. Once the metal crosses the plastic limit, then there is no chance of regaining its original form applying dry ice unless it is subjected to some external forces by tinkering etc. Any comments?
arunkumar_rec is offline   Reply With Quote
Old 4th December 2007, 11:13   #29
Edsel Rulez!'s Avatar
Thanked: 9 Times
Sounds like an urban legend to me. If something sounds too good to be true, and you see people falling over themselves in their eagerness to propagate the myth, it's a safe bet it's a load of hogwash. I suspect the only thing this treatment would do is corrode the sheet metal.
Edsel Rulez! is offline   Reply With Quote
Old 4th December 2007, 18:13   #30
kaushik_s's Avatar
Thanked: 156 Times
I'm unable to understand how would DRY ice corrode metal ? Dry ice is nothing but solidified CO2 and as we all know corrosion happens because of water and oxygen. This repairing dent may or may not be true but I'm sure there won't be any corrosion because of CO2,otherwise all the cars/metals would have anyway corroded when we breath out ;-)
kaushik_s is online now   Reply With Quote
body stickers/decals for Safari to cover up small dents himanshugoswami Modifications & Accessories 3 7th February 2009 13:34
Do you know whether your brake light is ON even when you are not braking? headers Motorbikes 31 12th July 2008 14:23
Passport Details : Not Secret haryan Shifting gears 13 22nd January 2006 00:13
Fixing dents. Pankaj9 Modifications & Accessories 5 29th August 2004 21:58
Small body dents Rudra Sen Technical Stuff 1 5th June 2004 19:29
