Old 4th December 2007, 18:25   #31
guys now days all ice cream wendors of walls n vadilal use dry ice to keep their ice cream frozen. u can buy it in bricks from refrigeration shops or the icecream wallahs
badman_in3 is offline   Reply With Quote
Old 4th December 2007, 18:28   #32
pjbiju's Avatar
Location: Karamattom, Aluva, Kotagiri, Yercaud, Hospet, Indore, Nashik, Pune (now)
Thanked: 465 Times
Originally Posted by emkay456 View Post
Is dry ice sold commonly in shops ? Any suggestions for availability in Mumbai ?
I want to experiment on the dent in the hatch of my Swift.
You can go to Naturals (or is it Natural) Ice Cream parlour and ask for a take away pack to be packed in dry ice (since you presumably will not reach home before a couple of hours). They do keep dry ice (at least in Pune). I sometimes get dry ice that way just to see it turn into smoke. They should also be able to tell you where they procure their dry ice from. But be careful in handling them. Best not to touch the dry ice pieces with your bare hands.
pjbiju is offline   Reply With Quote
Old 4th December 2007, 19:34   #33
maddy42's Avatar
Thanked: 536 Times
Infractions: 0/1 (5)
Guys i waited an entire day to see if any one had tried it out but what have we got here...still people thinking if it is possible???
Well what happened to the guys whos swift was their trial machine?
maddy42 is offline   Reply With Quote
Old 4th December 2007, 22:43   #34
Sankar's Avatar
Thanked: 4,639 Times
I don't think it works. It seems like a very very easy method to fix a dent, and i don't believe in anything that's too easy.
Sankar is online now   Reply With Quote
Old 5th December 2007, 03:05   #35
rocksterraghu's Avatar
Thanked: 96 Times
For all those thinking about Ice cream, Ice and refrigerators, dry ice is frozen carbon-di-oxide. Correct me if I am wrong.
Old 5th December 2007, 22:54   #36
kryptik83's Avatar
could not find any dry ice till date..so the dent remains
kryptik83 is offline   Reply With Quote
Old 6th December 2007, 08:37   #37
arunkumar_rec's Avatar
This may work on very minor dents probably. I am not sure about this method though. The moment the dent is deep enough, the sheet metal gets stretched which leads to thinning of the metal at that place. ie if the sheet thickness is originally 0.75mm, the big dent will thin it to say 0.6mm. In such cases, it is impossible to use this dry ice method to bring it back to normal. I have searched the net and found that the success rate of this method will be hardly 0.5-1% that too on very minor dents where the thinning of metal hasn't taken place. This should clarify the doubts lingering in people's mind.
arunkumar_rec is offline   Reply With Quote
Old 6th December 2007, 10:25   #38
Originally Posted by kaushik_s View Post
I'm unable to understand how would DRY ice corrode metal ? Dry ice is nothing but solidified CO2 and as we all know corrosion happens because of water and oxygen. This repairing dent may or may not be true but I'm sure there won't be any corrosion because of CO2,otherwise all the cars/metals would have anyway corroded when we breath out ;-)
Kaushik,
Can we try it out on your car? I'm willing to get the dry ice, and I'm also willing to make a few dents in your car for testing purposes if need be.
sidkun is offline   Reply With Quote
Old 10th December 2007, 14:04   #39
Default dude
dude go to walls agency in tolly , or ballyask for 1 cake if dry ice. when u bring it home ask someone to hold in a plastic bag near the air conditener to help it maintain a low temperature and not evaporate. and u can use it how n wherever u want . also u can take ur nicked car and use it instantly
Old 10th December 2007, 15:54   #40
It works guys.. i tried on my Zen ( there was coconut fall on my car ) tried with Normal Ice as could not get Dry Ice , I kept Normal ice everyday for 3 days and it worked ! Noticabale diffrence,,,, Need to apply more Ice
nicejits is offline   Reply With Quote
Old 10th December 2007, 18:01   #41
Jaggu's Avatar
Thanked: 8,684 Times
would be great if you can post some pics also.
Old 10th December 2007, 18:27   #42
kpzen's Avatar
Thanked: 1,655 Times
If its so, then the cars in places of extreme snowfall will become dentless if its parked with a snow cover for a few days ???
Please explain.
Old 10th December 2007, 19:06   #43
rkg
Thanked: 543 Times
Hi all
dry ice is solid CO2 as posted by many.it is -72 C
salt + ice @ of 30:70 will get you approximately -30 C
liquid nitrogen is -192 C. available @ Rs20/ltr.there are many LN plants.but one need special container to take it.
rkg is offline   Reply With Quote
Old 10th December 2007, 19:54   #44
kuttapan's Avatar
Thanked: 12 Times
ANd I thought dry ice was -57 deg C?
kuttapan is offline   Reply With Quote
Old 10th December 2007, 19:55   #45
condor's Avatar
Thanked: 4,897 Times
kpzen : If its so, then the cars in places of extreme snowfall will become dentless if its parked with a snow cover for a few days ???
Please explain.
@kp, good point. If this method works under normal weather and not when snowing, then one possible explaination would be that it needs a relative difference in temperatures between the dented area & the area surrounding the dent.
Using dry ice will provide cooling where the ice is kept. More cooling than when using regular ice. This would also explain why nicejits is seeing a slower rate of repair when using regular ice.
body stickers/decals for Safari to cover up small dents himanshugoswami Modifications & Accessories 3 7th February 2009 13:34
Do you know whether your brake light is ON even when you are not braking? headers Motorbikes 31 12th July 2008 14:23
Passport Details : Not Secret haryan Shifting gears 13 22nd January 2006 00:13
Fixing dents. Pankaj9 Modifications & Accessories 5 29th August 2004 21:58
Small body dents Rudra Sen Technical Stuff 1 5th June 2004 19:29
