Old 8th November 2008, 11:11   #16
Swifty2008's Avatar
I got my injectors cleaned from Sai Service MASS, Funkewadi recently. I would advice to get the injectors and engine decarbonization done together at MASS.
Swifty2008 is offline   Reply With Quote
Old 10th November 2008, 02:34   #17
Shakensoul's Avatar
Thanked: 221 Times
Can anyone tell me how this additive is supposed to be used, I could not find any instruction for this Liqui Moly Jetclean Fuel System Cleaner. Can this be added directly to petrol ?
Shakensoul is offline   Reply With Quote
Old 10th November 2008, 10:16   #18
amit_mechengg's Avatar
Thanked: 1,538 Times
its Phugewadi not Funkewadi. well how much did they charge you for injector clean and the engine decarb. earlier the charges were too high.
Old 10th November 2008, 10:29   #19
Thanked: 244 Times
No instructions on the product itself gives an indication that this product is not a DIY but to be used by professionals.
Look here. But what are you trying to do ??, clean the fuel system ??.
Old 10th November 2008, 10:36   #20
Attachment 68345
have you grabbed this from the A.S.S ? i think i have seen this/ similar ones with M.U.L people for which they use a machine to pump in the engine. please dont experiment with this unless and untill you know the procedure.
i think the link above says it should be mixed with fuel , after the jet clean procedure.
well how much did it cost you?
Old 10th November 2008, 15:08   #21
Shakensoul's Avatar
Thanked: 221 Times
Heck, I thought its a injector cleaner like IFTEX System G, just mix with fuel and use it.
I got this from a spare parts shop, cost was 220 rupees.
Old 10th November 2008, 15:19   #22
Thanked: 244 Times
Return it and ask him to give you BG44k(for petrol). Put that in your tank and let the deposits wash away
Old 10th November 2008, 16:25   #23
Swifty2008's Avatar
@dadu
What is BG44k?
What was that in the picture?
Old 10th November 2008, 16:42   #24
Thanked: 244 Times
@dadu
What is BG44k?
Its a proven deposit remover(fuel additive) from BG company, a modern treatment, which is simply added to a full tank of petrol, safely cleans away accumulated deposits in parts of the engine fuel system (including injectors) and from the intake components, intake valves and combustion chambers. Recommended every 15000Kms.
Just got recommended by Maruti (as the distributor told me) for use in their cars.
The picture was of a different additive.
Old 10th November 2008, 17:59   #25
Shakensoul's Avatar
Thanked: 221 Times
Too late, I already opened it and poured about 10ml into the tank
Old 11th November 2008, 09:34   #26
Swifty2008's Avatar
Vow. That was fast. Did you find any difference in the engine noise or between shifts?
Old 11th November 2008, 09:44   #27
Thanked: 244 Times
10ml is too low a measure to show any difference specially when these are supposed to be used directly using the cleaning apparatus.
He should be happy that he didnt pour all of it as its effect on the fuel pump etc cannot be determined (damaging or neutral).
Old 11th November 2008, 10:35   #28
Swifty2008's Avatar
He is lucky.
@dadu:
What kind of damage will be there if he had poured more into the tank?
Old 11th November 2008, 11:36   #29
Thanked: 244 Times
He is lucky.
@dadu:
I dont know, since this product is not meant for use with the fuel you cannot determine if it will cause anything wrong. The only component it could damage was the Fuel pump, rest anyway is getting burned in the CC.
Old 11th November 2008, 11:37   #30
Shakensoul's Avatar
Thanked: 221 Times
No difference felt till now.
My Fuel injector cleaning with carbon clean enigmatictech Technical Stuff 17 15th May 2014 20:36
"Sucking" sound after Throttle Body and Injector Cleaning abhipuru16 Technical Stuff 14 26th September 2010 20:48
Injector cleaning in mumbai Rice_tuner Technical Stuff 8 1st November 2008 13:08
Injector Cleaning Fluid n_aditya Modifications & Accessories 12 20th March 2006 16:40
