Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
Thread Tools
Old 4th December 2007, 16:04   #16 (permalink)
tsk1979's Avatar
I left my car unused for 2 months.
All I did was
1. Disconnect the battery
2. Overinflate tires to 34psi
When I came back and plugged the battery, the car started immediately. I let if idle for 5 minutes. The fuel tank was 1/4th, I got her tanked up at the station 3kms away
The tires were at 28-29PSI(Tubeless tires).
the big problem? The drivers seat was covered in mild fungus, had to get interior washed.
I had kept silica gel in all pockets etc.,(got a huge 1kg bag of silica gel for car and house for 95rs) and the dashboard. No issues or molds there.
you can sprinkle anti fungal talcum powder on the upholstery.
I had kept the car covered, so no dust issues either.
__________________
Reclaimed, wrung dry and recycled....!
Old 4th December 2007, 20:28   #17 (permalink)
Rehaan's Avatar
Note from Mod - Threads merged. Please see the first 2 posts in this thread.
Please do a search before creating a new thread.
Also check out these threads > http://www.team-bhp.com/forum/techni...an-1-year.html (What things can go wrong if a car is kept idle for more than 1 year?)
http://www.team-bhp.com/forum/techni...os-don-ts.html (Long term parking dos and don'ts)
cya
R
Old 4th May 2009, 19:06   #18 (permalink)
Default Precaution for putting the car for prolonged non use of car
One of my relative is going to US for about 1 year. During this period his i10 (Era irde) will not be used. He has inquired at the Authorised Dealer about precautions to be taken and he has been told that nothing is required except disconnecting battery cables.
Is this sufficient? What about tyres and engines. What else is required to be done?
@Mods:
I tried to search but could not find any topic on such issue. If this is not the right section kindly transfer it to suitable section of the forum.
Thanks.
__________________
Present : Innova - Wagon R - i10 Auto
Past : Santro XG- Honda City (1G) - Zen - Maruti 1000 - Maruti 800
rutvij is offline   Reply With Quote
Old 5th May 2009, 01:37   #19 (permalink)
SirAlec's Avatar
have you gone through the whole thread.?? if not, now is the time.
__________________
Still! Living Life a quarter mile at a time.....post being Dad.
Old 8th May 2009, 01:14   #20 (permalink)
Originally Posted by carlover98 View Post
The best thing you can do is ask your friend who knows driving to take out the car once a week for 5 - 10 Kms. Whatever precaution you take, if the car is left idle, it is sure to cause some problem or the other. This is the best and most practical solution.
Cheers!!
Really Good Idea.
Pretty old thread coming alive. I think 2-3 months should not create any problem other than battery if car is parked properly in shed and covered and its not rainy season.
idea1979 is offline   Reply With Quote
Old 4th November 2009, 08:15   #21 (permalink)
username's Avatar
Default Swift VDi - Long term Parking
Hi Guys, I have recently traveled abroad and had planned to leave the car with my parents. Unfortunately, there is not much need for them to drive the car...
Looks like the car will be parked for about 3-4 months min. How bad will it impact the car?
Any pointers?
Thanks in advance.
__________________
2009 Swift DDiS
username is offline   Reply With Quote
Old 4th November 2009, 08:23   #22 (permalink)
dinu2506's Avatar
I do not think 3-4 months will have any adverse effect on the car. You can disconnect the battery to ensure the battery does not drain out completely. It will be good to change the engine oil on your return. If possible, you can also remove the wheels and keep the car on jacks, though I don't think that is really required if it is for only 3-4 months.
Have a good trip abroad and don't worry. Your car will be just fine. I hope the car is parked in a covered area.
__________________
What we are today is a function of the future we are living into, not our past.
dinu2506 is online now   Reply With Quote
Old 4th November 2009, 09:26   #23 (permalink)
I would second what dinu says below, but also, if there is a possibility that someone could start and run the car for five minutes once a week, that should keep the car perfectly ok.
__________________
Baleno Vxi 05
Ritz Zxi 09
filcord is offline   Reply With Quote
Old 14th November 2009, 13:58   #24 (permalink)
inder_s1's Avatar
Hi Guys,
I had to leave my Bimmer standing for 2 months and I see signs of fungus... Could any Bangy Boys help me where to find Silicon Sachets or similiar setup?
Indy
inder_s1 is offline   Reply With Quote
Old 14th November 2009, 14:10   #25 (permalink)
rr_zen's Avatar
Any pointers?
Thanks in advance.
As a person having gone through this experience (my car was not used regularly for 2 years) one of the after effects I saw upon my return was the impact on the tyres. Since it was very sparingly used and the car was parked most of the time, the tyres had deformed a little (albeit not visible) and this resulted in increased road noise. It took me more than 4K of regular use for the noise to subside.
Since the period you are referring to is only 3-4 months, I dont think it should be a great deal but I would still urge you to have someone do the following:
1. Take the car out at least once a week and drive it for a few kms.
2. More importantly, it is better to maintain a higher tyre pressure when parked. This is the key in maintaining the shape of the tyre when parked.
Hope this helps.
__________________
Life is a learning and Change is the law of nature !
rr_zen is offline   Reply With Quote
Thread Tools
Which is the Best Car Battery Brand? Max Technical Stuff 429 21st November 2009 15:34
Long term storage effect on new Car Bullfrog Technical Stuff 25 5th November 2009 19:29
Want to create a storage device Bass&Trouble Gadgets, Computers & Software 51 18th October 2008 15:35
Car is my extended personality... Cartel Introduce yourself 7 22nd September 2007 22:24
Lack of storage space in Innova dash -- possible to modify? kousik Modifications & Accessories 4 6th February 2007 09:42
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608
