Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
LinkBack Thread Tools
Old 4th December 2007, 12:25   #1 (permalink)
tushakh
Default Issues in Mahindra Logan
I have bought Mahindra-Renault Logan 1.4 GLX about a month back. I found some issues with it:
1. The Right side rear fog light is in RED while the left side has it is WHITE (I noticed that it is same with all Logan variants..) Any clue on is this product feature or a manufacturing defect/oversight?
2. When I engage the Right/Left indicator, both indicator LED's on the instrument panel start blinking. According to me only the correct indictaor LED should blink.
3. The car headlight intensity is very dim, but when you engage the high beam it is OK. Accordingto me, the intensity should be better?
4. After I drive for few kms (more than 7-8 kms) and park the car, I find the Fan in the bonnet still runs, even after switching off, for few minutes. Is this normal? If not, what could be the problem.
I would like to know any of the Logan owners had these issues? Were you able to get it rectified?
share any information you have!
I will be anyway taking the vehicle to service centre for getting above issues problems (if it is indeed a problem) fixed.
tushakh is offline   Reply With Quote
Sponsored Links
Old 4th December 2007, 13:59   #2 (permalink)
achopraa
achopraa's Avatar
Thumbs down
Found the same thing in SX4 also. Still unable to solve this mystery...
__________________
Main Aa Gaya....Main Chaa Gaya....
achopraa is offline   Reply With Quote
Old 4th December 2007, 14:01   #3 (permalink)
benbsb29
benbsb29's Avatar
Thats an attempt at cost cutting, and thats how it is on all Logans. Nothng to be bothered about. There is just one rear fog lamp, while the other one in white is the reverse indicator.
Correct. Get it checked.
Are you sure about this? Did u check how the lighting is on a dark road, are you saying this based on your experience on a lit road?
Nothing to worry about.
Please find my comments inline in bold. Hope that helps.
__________________
"You can discover what your enemy fears most by observing the means he uses to frighten you." - Eric Hoffer
Old 4th December 2007, 14:07   #4 (permalink)
Rocky_Balboa
Rocky_Balboa's Avatar
Since Benny had answered all Your queries, I would restrict myself to suggesting You to read your user manual completely.
__________________
It ain't 'bout how hard you hit; it's about how hard you can get hit, and keep moving forward - Sly in Rocky Balboa.
Rocky_Balboa is offline   Reply With Quote
Old 4th December 2007, 14:13   #5 (permalink)
abhilashvk
abhilashvk's Avatar
I dont remember how it was in Logan when I took the test drive: what if the dashborad has a single indicator for both the turn lamps - some thing like a CORSA - where a single LED blinks for both the L and R signals?
__________________
Abhi
Any man who can drive safely while kissing a pretty girl is simply not giving the kiss the attention it deserves.
abhilashvk is offline   Reply With Quote
Old 4th December 2007, 14:15   #6 (permalink)
snaronikar
snaronikar's Avatar
Take it to the service station and get it examined regarding the defects. Balance Benny has already said it. BTW read the OM a bit more carefully and completely.
__________________
Love your job but Never love your company
because you never know when your company
stops loving you-NRN
snaronikar is offline   Reply With Quote
Old 4th December 2007, 15:01   #7 (permalink)
RishiSuri
True Corsa has only 1 indicator to show for left or right indicator
As for fan still running after switched off.. the same happens in palio 1.6 as well.
I think thats for cooling down the engine ;-)
RishiSuri is offline   Reply With Quote
Old 4th December 2007, 15:13   #8 (permalink)
benbsb29
benbsb29's Avatar
Since i havent taken a TD of the Logan, i cant be sure here.
I can understand if such a funda was followed in the case of bikes (eg CBZ) where you can look at the indicators blinking on the bike just in case you wanted to see which one was turned on. On car, that would not really make sense, and so i would assume there were seperate indicator LEDs.
__________________
Old 4th December 2007, 15:44   #9 (permalink)
sastradhar
Default Dont think they are problems
My reply is in bold and I own a Logan DLS
Logon has only one reverse light and one rear defogger by design. I dont think your model has a rear defogger so it may never glow. Manual is crapy so it may not clear your doubt . As per the website I think your model does not have a rear deffoger so it must be a dummy. Just check the website.
For Logan there is only one combined LED indicator which glows when you put on the left/right indicator and it is designed such that it looks like you have put on the hasard lights, so it is normal you dont need to get it checked. Some times it confuses if you have put on the blinkers on the hasard lights. Give it some time you will get used to it.
Ok what you think is the high beam is the normal beam (indicator must be green in color but looks like a high beam) pull the stick towards your self and then you see a blue color indicator which is the high beam and also try the beam level adjustor.
I dont think it is the fan you are hearing it must be the fuel pump which I people are complaning can be observed in the 1.4 and Diesel but on in the 1.6 but just to be clear get it checked.
sastradhar is offline   Reply With Quote
Old 4th December 2007, 15:50   #10 (permalink)
jkdas
jkdas's Avatar
1)Like you have with old Fords and Indica? Only two lamps for reversing for high end models?
2)wiring problem I guess
3)change bulbs maybe to 90/100W
4) Maybe its like that for Logan. Check with other owners.
__________________
Audio, video, disco
Tat tvam asi
Old 4th December 2007, 16:30   #11 (permalink)
trrk
trrk's Avatar
The lamps are designed to European norms where there should be atleast one rear fog lamp.
__________________
Rajesh
Marina LS, Oct 05, 69167, 13.82
Manza QJ Aura+, Mar 10, 8900, 16.34
Figo TDCi Titanium, Apr 10, 4072, 15.22
10/07/10
trrk is online now   Reply With Quote
Old 4th December 2007, 16:59   #12 (permalink)
deepakhon
I own a Palio and it has the same two characteristics that you are mentioning. It just beats
me on how Fiat/Renault can save great money by not providing one separate LED for each
indicator. Even Maruti 800 has two separate indicators IIRC.
The fan running for some time even after the engine is switched off is a very common phenomenon in Palio and it is designed that way. Apparently, it is to cool the engine faster. It can be for a very similar reason in Logan too. It will be good to check with people who own Logan.
Actually, Corsa had something more unique; the speedometer readings started from 20 instead of 0. On inquiring, I was told that it should not matter much as anyways, readings from 0 to 20 are not accurate
__________________
Deepak Honnalli.
deepakhon is offline   Reply With Quote
Old 4th December 2007, 17:06   #13 (permalink)
jerish666
jerish666's Avatar
That is normal.If you are still confused you can check with the dealer.
jerish666 is offline   Reply With Quote
Old 5th December 2007, 11:18   #14 (permalink)
tushakh
Hi Folks,
Thank you all for your inputs!! It really helped.
@sastradhar
Pt 1. According to the website, Logan 1.4 GLX (in fact on all variants) do have rear fog lamp and reverse light.
Pt 2. It would be nice to have the LED indicators work properly
Pt 3. Can you tell me how the beam level adjustor works?
Did you check with the dealer/service center on any of above problems, what was their reply? Did you get them fixed?
@Everybody... (and Logan owners specifically)
Please list any other problems you have encountered in Logan and possible solution / workaround for it...
Old 5th December 2007, 12:06   #15 (permalink)
ajmat
better?
Renault's were notorius for hot start issues (restarting a hot engine). This is due to fuel vapourising in the fuel line leading to air locks (not applicable in diesels but they may be lazy to change wiring loom). I used to use a Renault 5 GT Turbo and it would hum for quite a while after a good work out
__________________
Rice is cheaper than German Potato's
Thread Tools
Mahindra Renault Logan In Oman - 23 people stuffed inside 1 Logan serpente The Indian Car Scene 34 19th April 2010 19:03
Mahindra Logan: To buy or not malgudi Sedans 22 26th May 2009 00:23
Mileage of Mahindra Logan nicejits Test-Drives & Initial Ownership Reports 2 24th September 2008 17:50
Mahindra Logan sumantab20 Sedans 1 4th April 2007 05:55
Powered by vBulletin
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©2000 - 2010, Team-BHP.com
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698
